For the price fo $1400 just for the Greddy plenum, you can save that and buy an rb26 head like i'm doing.
The rb26 heads also flow better.
Thats also my thinking. Its not so much they flow better its the better factory cams + the added bonus of the solid followers = higher ramp rate. higher lift for a given duration.
Providing you can pick up a rb26 head and manifolds for a reasonable price.
Edited by Cubes
Every 6 months i end up in the same position...I want the thing to look completely std, heat shields and all. So what is so difficult about getting a few offset braces made wo that it goes behind the throttle body??? Does it clear the actual manifold.
Be great is someone could put a telescopic aeiral on their rocker cover and measure the height to the top of the plenum & top of throttle body. Then close the bonnet and measure the ehight to the underside of the bonnet. Liek to know the clearance to th eunderside of the bonnet as well:)
I've done a few measurements.
Just in front of the throttle body the plenum has 20mm with the motor lowered 13mm.
If you drop to your knees on the drivers side of the engine bay you will see where the cross over pipe is higher than the throttle body and plenum, it almost v's up a little, I had a good look at the cross over pipe, its not touching the under bonnet lining but must be damn close as it too sits 20mm higher than the plenum section where the strut brace would pass over.
The strut brace will no way fit over the throttle body and cross over pipe. I suspect one of those flat tubular style strut braces will fit providing it passes in front of the throttle body/cross over pipe.
All else fails you could always grab a r33 rb25 or rb26 stuffed bottom end (piston oil squirters a must for cast pistons that see track work), Rebuild that with cast pistons and throw a r32 rb25de head on it. That would look 100% stock.
Edited by Cubes
It really is a hard decision.
When purchasing my head I found a 26 head and inlet manifold for 2.5k.
The 25 head was $750 + $1100 for rebuilding and port/polishing.
I decided the 25 head rebuilt was a better option for reliability. I didn't want to try my luck with a second hand head even though it would have no doubt been fine.
I wonder which would flow better, a 25 head that has been ported polished, the suitable valve jobs, inlet valve deshroud, port match and 260duration exh. cam or a stock 26 head.
The reason for a 260 duration exhaust cam... From flow tests i've seen its the exhaust side of the rb that has issues. Not the inlet.
I could be wrong. Its only my observation.
Thats the thing, CUbes and myself were looking for the heads for our motors almost 3 years ago now...a lot has changed in that time for skylines. Especially prices for parts.
Saying you can buy GTR heads for $1500 now doesnt reflect the almost $3k price tag back then :P
The only difference between the two looms (being an r32 without vct) is the inlet air temp sensor addition.
After all all you need to do is route the existing loom plugs to the new rb26dett locations. Not too hard at all.
Edited by Cubes
Warning!!! ACL PRODUCT WARNING. Were supplied new race series forged ACL pistons, rings and bearings for an rb30/25 hybrid. Engine built buy a reputable engine builder and run in by ex Perkins engineering mechanic/tuner. Rattled from new and finally pulled it down at 2000Klms to discover massive wear on the drive side of the bore. Piston to bore clearances measured at 7 tho and within spec. ACL denied refund/replacement and rolled out these excuses in this order. 1. Detonation (cleared after hardness test) 2. Foreign substance in bore (brand new engine run in on dyno with standard air box and new filter) Cleared after excuse number three. 3. Over boosting causing rings to break down and cause abrasion on bore. (Stat decs signed by engine tuners stating run in boost set to max of 14psi). ACL now tell me that there FORGED race series pistons are only rated for 10PSI. This engine has a comp of 8.2:1. Standard engine runs 9:1 with cast factory pistons at around 9psi...do the math. Currently taking legal action. Any questions regarding this "race designed product" PLEASE contact me @ [email protected] .This is not a rant, but an opportunity for other people to learn from my experience.
Theres a reason why they are rated at 10 PSI, they aint forged pistons!
I've been selling ACL parts for years and they are yet to make forged pistons. Someones been feeding you bs.
Alot of people take the RACE series brand to be forged when they are a better grade of cast.
Edited by retrotec
on a side note, i find it hilarious that a piston can be "rated" at 10psi.
does that mean the piston will be okay on a motor with 10psi, huge back pressure, poor camshaft design and 14:1 compression? or does that mean that the piston will be okay on a motor with 10psi from a blower, with no back pressure, a perfectly selected camshaft and 7:1 compression?
it's a bit like wankers who ask you about your car and their first question is "how much boost u running bro?" :blink:
But I think this guy is talking about the acl hyperlite series of pistons, I was considering them for my conversion, but my engine builder talked me out of them.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
