There's some guy on calaisturbo trying to flog off an N/A Rb25 head if people are looking, he only wants a few hundred dollars for it!
gday i am wondering what sort of prices engine machining cost to you guys when undertaking the rb30 conversion namely acid bath, bore, honing, decking, and grind and balance crank
Quick simple question, didnt want to cramp this thread but wasnt sure where to ask:
Are these these RB25DET transmission supports suitable for the RB30 block?
If so, can I pull them off any RB30 powered car at the wreckers?
I seem to be missing them.
I think you will need to use the RB30 gearbox supports.
The R32 RB20DET Transmission supports are suitable for the RB30 -> RB20DET/RB25DET gearbox.
Hows your little monster coming along Ben? :P
Bu5ter is running 272duration cams in his RB30DET, the same as you I believe?
Edited by Cubes
I've noticed several people are running Mitsubishi TD06-20g's and pushing ~250RWKW+ on ~1 bar - what are the specs on these things like? Im guessing they are rather large?
Seeing as people are running as high as 270RWKW on internally stock RB25DETs, what are thoughts on similar power outputs on RB30DETs?
Im also curious as to the limits of an internally stock bottom-end.
Im looking at getting the head ported, I have some RB26 valve springs to go in, maybe some bigger cams, stock exhaust manifold (sandblasted/beadblasted?) and then a decent exhaust.
Turbo wise im thinking perhaps GT30R with .63 A/R?
Either that or spend the dollars on forged pistons and rods, and go a GT3540R with .82 A/R?
I have a 0.82 GT3040R in my DET. Currently running only 9 - 10psi but this is reached at 2600rpm. It still feels like it's pulling well at 6000rpm. Excellent street turbo methinks :)
What RPM does it start to make boost?
I take it your running in the engine, but have you ran anymore boost than 10psi, im interested to know what RPM it can make 15psi, and 20psi at?
Starts to make boost somewhere around 1700rpm from memory.
Engine has been in and running for 12 months now. I've had a few teething problems though - internal fuel pump was shagged, some sort of restriction in the return line inside the tank (it's in a VL), cooler pipes popping off, too much oil fed to the head, cam timing out, lack of cash, etc......
so no i haven't ran anymore than 10psi through it. They are all sorted now, i just need to dyno it again.
Manifold is a stock RB20DET unit. I made an adapter which 1) serves to position the turbo in the stock position and 2) mounts the external 48mm ProGate. On the last dyno session this adapter got red hot and started spitting little flames off it. At the same time power dropped off and the engine temp went through the roof. I found that both cams were aboout 7 to degrees retarded! This was the result of my cam tensioner positioning.
stupid non-OEM belt setups! :)
what did you do wrong? i'm afraid mine will be a fair whack out too, you just can't tell with any degree of accuracy. the inlet cam appears spot on, but the exhaust cam looks a little advanced on mine, doesn't line up perfectly with the spot on the timing backing plate. might be a good idea to get an adjustable gear there i reckon.....
What trans you running in your car Auto/ Maanual??
How did you fix your cam timing?
I ran 2 adjustable tensioners... Adjustables new are so much cheaper than fixed.
so did i, but only because i had easy access to two from a few RB30 blocks i had lying around :blink:
when i get my manifold back off my mate, i'll bolt the plenum, turbo and manifold on and post some pics up for ya.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
