I have 2 adjustable tensioners, but no matter which way i adjusted them, i couldn't get them right. The first hole i drilled went straight into the water gallery so i drilled and tapped another further from the centre of the block. In hindsight, the first probably would have been ok with some locktite, but i didn't want to risk a water leak at the time.
I have an R33 head and the VCT gear is adjustable from behind, and i bought an adjustable exh gear. Hopefully problem solved. Well i spent a weekend dialling in the cams, so it better be solved!
Sky30, it's a 5 speed manual.
RB25 n/a head, GT35/40 turbo, 19-20psi
Youve got to be kidding me right ????
What specs are you running ? 270k km and 20psi with gt3540 ???
I got my rb30det which has done about 30,000km so far with a smallish turbo now I too am going the GT3540 .82 with tial 38mm gate with a top mount manifold and 740cc injectors (still off the road)
Got some questions for ya...
When does boost come on ? is it laggy ???
How does it sound ? :P
got any pics??? be very keen to find out more
Do you have .82 rear ? when do you get full boost by ???
whats you fuel economy like??
tell us abit about it..
thanks
How does it sound ?  :)
thanks
Why would i have to be kidding???
Its .82 rear housing, makes 20psi at about 3400rpm.
Can anyone help me find a set of forged pistons for RB30 that can give me a CR of 8.3:1 or more?
was looking at ARIAS but not even rocketindustries have them in stock atm, they only have the flat top piston that give 8:1 CR, any idea how this would drive?
Anyone selling these or CP, or Wiseco?
Im thinking of adapting the rb25 oil squirters to the rb30 block. Im just asking if anyone had any pics, of a rb25 block with the oil squirters removed showing the whole location. (I have looked at Cubes guide).
Or do u think I’m wasting my time trying to make them fit or is it just impossible.
It'll be in an R31, heh.
Anyway, I have an R32 RB25DE loom and RB20DET ecu on the way.
Should be able to get the RB25DE loom if necessary.
so the rb20det computer will be able to be tuned to suit the rb30 with no problems whatsoever?
i suppose the rb25de runs top feed injectors also? will this also be fine if you upgrade to gtr injectors? and i then presume a z32 afm is necessary (if not a q45)
the rb25de injectors are them same style as rb20 and rb26 injectors!
Rb25de injectors are rb20det injectors. :P
Same part number, same flow.
I ran my RB30DET in on the stock RB20DET ecu, it couldn't handle any more than approx 6-7psi as it would fuel cut.
What did you do loom wise with the conversion? I thought the extra capacity of the head may confuse the power fc
Cars are very simple.. The measure how much air enters the motor then puts in say 1 part fuel for every 15parts air.
As a result.. the car runs fine on the stock ecu. Obviously limited as the RB25 head flows so much more air, as a result I was hitting fuel cut.
The PowerFC handled it quit well. AFRs were pretty much spot on, light load didn't need touching. WOT required a small tweak of afr's around 3500rpm - 5000rpm. Ignition timing had to be pulled out a little due to the back pressure the stock turbo caused on the 3ltr.
After putting the VG30DET BB turbo on its taken another 6-7degree's ign. timing at wot.
With regards to the higher RB30 block, how much of this affects the piping around the engine. For example, intercooler piping, exhaust manifold and dump pipe, radiator coolant piping. How much of these needs to be modified due to the higher RB30 block?
My std IC piping actually fitted much better; like it was meant to be. :P
Radiator hoses are not affected.
Exhaust manifold is not affected, how can it be?! :P
Dump pipe obviously needs modification as the motor sits slightly higher. I paid $60 or something and had them cut and weld in a little spacer so to speak.
It all drops in and bolts up much easier than you would expect.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
