Just had the VL on the dyno and thought i'd post my results. A bit of background......
Stock RB30 block
Stock R33 RB25DE head, VCT hooked up.
R33 RB25DE oil pump
GT3040, 0.82 rear
RB20DET ex. manifold
550cc mazda 20B injectors
600x300 cooler
Bosch 044 pump
258rwkw on 13psi
800ish Nm (can't remember exactly)
Don't have a dyno printout ATM as the dyno keyboard shat itself, but he saved it and i should see it sometime this week.
I honestly didn't pay to much attention to the RPM/power relationship while it was on the dyno. My eyes were glued to the power figure! Like i said, the graph wasn't able to be printed at the time, so i'll have to wait till he e-mails it through.
Wastegate is an external 48mm progate mounted on a custom adapter between manifold and turbo.
ECU is a Haltech E11v2 with a 2 bar MAP sensor. The boost cut is set at 2 bar absolute (obviously) and even though the wastegate solenoid is set to provide 13psi, it occasionally spikes and hits the boost cut. Hopefully closed loop control will sort this out.
quick question guys.
If i were to do the RB30 upgrade on my RB20 equipped R31, would i be able to use the microtech i already have in it on the RB30? Also, would everything else wire up as is? or will i have to go through a huge auto electrical drama?
Also, what would redline be if you get the RB30 crank propperly prepped and balanced?
Im using a microtech with the stock RB20det loom, no problems, just use the stock RB20 sensors.
Hey,
Just got the power tune done and very happy with the results.
The car is so responsive it's not funny and I _______ mean it !
We're all quite surprised with the power output and especially the turbo.
Having the high-flowed stock turbo was always questionable, but even more than before the conversion, it spools up so quick and holds 18 psi efficiently.
I've been considering a GT35/40 onto the stock manifold but I'm now reluctant to change anything given the instant boost.
The accelleration is just exhilarating and I _______ mean it !
Tuned to 15 psi due to stock injectors we got 294 rwkw / 508 fwhp.
Next service, will go for Sard 550's and push the turbo as hard as possible.
Nengun will deliver for $674.00 !, bugger high flowed injectors..
Dyno graph posted in the RB30 results.
God bless Nissan and everyone who's been part of this conversion.
Edited by conan7772
15psi = 294rwkw yet with 3250rpm full spool?
Almost sounds too good to be true, if thats really the case stick with it as a GT35R will be laggier and will require more boost to make that power.
What fuel are you running?
Turbo specs?
What fuel pressure are you running? :O
could be running bigger cams to help bring down the boost level, dont really know specs of the engine..
im getting 294 rwkw with teh std RB25 @ 18psi, but with tomei pon cams..
maybe some more details on the motor will help make that tune results make more sense.
Thats good power also.
What spec cams, and what other parts on your motor (aftermarket plenum, exh manifold, etc?)
plazma man plenum, custom highmount setup, HKS GT3040 1.12 rear housing. tomei pon cams 256 /8.5 power FC and 550cc sards, sard 1:1 fpr, Z32 afm
laggy now, but will be better suited once the rb30det is completed. full boost of 18psi at 4700rpm.
wheres the std rb25??
what did you mean by? -
std bottom end was what i refering to...
main thing was with Sky30's post refering to his 35/40 cracking 300kw @ 18-19 psi... and thats a rb30det.
there are things that can help reduce the psi required for certain power levels..
Edited by Craved
Read again mate..
"Having the high-flowed stock turbo was always questionable, but even more than before the conversion, it spools up so quick and holds 18 psi efficiently"
He said he got 300kw at 18psi on the high-flowed stock turbo ...
Stock hi-flow making near 300rwkw on 15psi............. are you sure?
My 35/40 only cracked 300rwkw on 18-19psi.
It looks like stock housings to me.
The dealer I bought it from said it was a T3/T4 Hybrid.
I don't know for sure. See pics...
It was bored out to the max on the compressor housing. Bugger all meat left on the intake.
Also, before I blew up the RB25DET with this turbo, it had 247 kw.
That dyno graph is also posted.
Read again mate..
No
294 kw at 15.2 psi
Power graph and pressure graph was the same test
Yeah, that looks very similar to the hi-flow i had on mine, but i only made 235rkw on 17psi with similar mods.
Have you had yours on a dynodynamics dyno?, be interesting to see the difference compared to the dyno you used.
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
