I did change that hose clamp :) so thats not the issue the bonnet was touching in a few places, my cross over pipe to intake, and my plenum right at the edge near the coolant screw, and also to the left of it a bit, it is acutally touching on where i have already cut the supports off so i would need to cut a piece of the bonnet out for it to clear :D , your right cubes i do have two manifolds TIME FOR THE GRINDER :D
Edited by FOOLBOOST
anyone here seen a 3 way adapter that would fit in the oil pressure hole in the block?
i need to run the std sender, aftermarket guage sender and the VCT oil feed from here.
options are ;
to make one up
to run a twin adapter then another twin out of that
find one that has 3 oulets already.
What size is it?? Thats a lot of oil lines :D, i would go to gauge works they have all those fitting so you could make whateva you like up :D
pretty sure that are all 1/8th NPT..
have to measure the guage's sender and see what that is .. the VCT line will be custom so it can be anything i want..
hahah they are really line, just the little sender units from the guage and the std ECU/dash . then the feed :)
options are ;
to make one up
Hey - I got one for mine, VDO make a brass fitting... really sorry I threw away the packege with the model number in it! The guy I talked to knew straight away what I need though. The stock oil pressure sensor screws into the end of it, and it has a hole in the side for your oil line. I just used some speedflow fittings and some teflon/braided lines for the VCT. :D
edit: sorry, saw you need 3 :D maybe two of the above would sort it out... do you really need the stock gauge AND the aftermarket one?
Edited by platinum
yeah i dont want the oil light and stock guage to not work. hate having guages not work in the dash :)
i think the 2 double adapter things will work fine.
cheers
Hey - I got one for mine, VDO make a brass fitting... really sorry I threw away the packege with the model number in it! The guy I talked to knew straight away what I need though. The stock oil pressure sensor screws into the end of it, and it has a hole in the side for your oil line. I just used some speedflow fittings and some teflon/braided lines for the VCT. :)
Be careful, the brass fittings hanging off the side of the block vibrate and can crack, particularly if they have heavy sensors screwed into them increasing their weight. If you piggy back them it would just make it worse. When they crack oil goes everywhere, it’s very messy. To stop the vibration, I use a short piece of braided hose screwed into the block and then mount the brass adaptor solidly so it doesn’t vibrate and the weight of the sensors is taken up by the bracket, not the fitting itself.
:) cheers ;)
hey guys i know its been discussed but im unsure what to search for and 180+ pages is alot to look through.
so if i was to get a stock rb26 head and a stock rb30e bottom end and bolt em together what comp ratio would i get? and what about using the rb30et bottom end, what comp ratio?
i want to use the entire rb30 bottom end complete without touching it as a bit of a cheap engine build and see if it will last. i would love to put my rb26 head on it with the t04z and big cams and see the lag differences compared to my jun 2.7L stroker.
what sort of power would i be able to run safely with the stock bottom end and stock head, if the external parts were all suitable for big power?
is 300rwkw possible for extended periods or is that about optimistic?
also whats the ideal comp ratio for a rb30/26 setup for response and drivability?
any info appreciated and sorry for bringing up the same questions, i just havent got 3 hours to read through at the moment and find it myself :D
thanks
Brad
Edited by CruiseLiner
Stock rb30 bottom end + rb26 head is around flat to low 8:1.
Sky30 has pushed slightly over 300rwkw on a second hand $50 rb30e that had done 270,000km's. I believe he did ~20,000km's at around 240rwkw then went on to do another 20,000km's but with a shade over 300rwkw. Its now off the road as he's dropping the motor in to a GTS4.
Many underestimate the ol' rb30. They are a tough motor.
I am 100% with Sk on this one... 9:1.
I run around 8.7:1 and there is a noticable (not huge but noticable) difference compared to an rb30 running 8:1, all though the rb30 was fresh..
FOOLBOOST, what do you think? Much of a difference in initial off idle torque between ours?
Probably best to wait until yours is tuned.. :D
thanks
Brad
rb30et bottom end is around 7.1 and the rb30e with the head 8.3. With the block planed slightly assuming other factory figures are correct you can get 8.5.1
300rwkw for extended periods yes is possible. One guy here in nz ran a season of racing on an rb30e bottom end with 25de oil pump with 450rwkws
I have a quick and important question regarding piston/bore lubrication. We have aftermarket rods and pistons, obviously no block mounted oil squirters and the rods dont have any holes in them for external oil squirting. The motor has been assembled already and were just doing external fittings and ancilliary bits before it goes in. The thing thats playing on my mind is, is there enough oil lubrication from just crank splash to sufficiently lubricate/cool the bore and pistons? The bore was machined on the tighter side of the piston spec sheets tolerance which will make the situation worse. Now will it be a big problem like this or are others running their rb30s like this with no dramas. Would be good to find out now before motor goes in so we can easily pull it apart and rectify the problem. It is a race motor too.
Thanks in advance.
Thanks in advance.
Conrod oil squirters are essential
:w00t: cheers :D
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
