Originally posted by 2fardown
I have read the entire thread and would like to ask a few questions:
1.  Will the engine fit straight into the engine bay or will there have to be modifications of engine mounts etc etc?
2.  If this conversion is so easy and the end result a powerful engine....why didn't Nissan ever develop and include the RB30DET in one of there cars?
Cheers.
1. Yes, it will drop straight in, so the story goes.
2. The story I've heard is that Holden agreed to buy 3L engines off Nissan, if Nissan never sold them in Japan, which led Nissan to find something else to power their GTR's with... hence the RB26DETT.
Originally posted by -scooter-
Hey all.....
Now my QUESTION is, how do you tell the difference between the series 1 & series 2 blocks????????
easiest way is to look on the exhasut side of the block. down the bottom , pretty much the middle of the block u will see a 1inch bung , thats the return line for turbo oil drain.
about 8inches above that bung , u will see another bung bout half inch , this is for the oil feed line.
and thirdly about the same height as the oil feed hole , but about 12inches to the right , almost at the rear end of the block u will see 2 holes both with bungs in em.
one of the is the water feed line for the turbo , the other is the coolant drainage hole , which is in all block though.
Arias pistons now makes a piston to suit the RB30 block to RB25 Head conversion, this is good news in regards to compression ratio problems with this swap
i think wiseco do aswell
Hi Trev,
Here's another idea, Total Seal make a good set of rings for the RB's. Top ring is ductile iron (much more durable), second ring is gapless & the the oil ring is 4mm wide instead of 2.5mm for graeter oil control. This means you have to machine your pistons.
Sanding the rods is a very good idea as long as you sand in the one direction & then weigh each rod for balance & then get them shot peened as this also adds strength.
I always skim the head & deck of the block (5 thou is plenty) as it gives a much better seal & I would also invest in a haed stud kit.
My 2c.
Nick.
1 more, (might have been mentioned, didn't read the 19 pages),
but getting everything cryotuff treated, @ only $5 a kg it's cheap insurance.
Contact LSW Group (02) 9773 0647.
Nick.
/que dumb question from dave
Hello all. Upon pondering my upgrade i just thought of this. How do you control/activate the VVT ? Like the people using the R32 ECU... the R32 didnt have VVT so how do you 'stimulate' the solenoid to open to allow oil pressure onto the cam bearing ?
just wondering how people with non R33 ecu's are activating the VVT if using it.
Can the VVT oil feed just be bunged up and not used? Any harmful side effects?
Cheers
Dave :D
You could rig up a little circuit that you make up from jaycar that reads the rpm signal and activates the vct solanoid at a certian rpm.
Regards to the 3ltr kit spacer plate.. You most probably could with custom rods etc.. :D
It would feel like an old 250 X-Flow ford motor then.. Making peak power at 3700rpm.. :D
hey guys
its not a myth!!!!!!!! The rb25de springs are softer coming at
39Lb and the DET coming in at 44 Lb!!!!
That is what i have been told (by a very reliable source)
But there is always that little chance that it could be wrong!!!
Thats my 2 cents worth hope it helps.
Dan
I've just got myself a set of tomei pistons 87mm... i thought of doing the conversion myself too but i am not sure where can i get a RB30 block from and how much would it cost. please help me. Can i do the conversion with a standard turbo? What are the things i have to replace? conrods? crankshafts? i have apexi power fc and avcr in my car already. Is the RB25DEt head a direct bolt onto the RB30 block?? please help.... thanks alot everyone..
have a read through the 20 odd pages of this thread, it answers all your questions and will provide more information that you haven't thought off
Standard turbo can be used, may be a little small
you can keep conrods and crank shaft, but you may want to get them strangthened/balanced. RB25DET head is pretty much a straight bolt on if you don't want to use the Variable Vale Timing... but i strongly suggest you read this entire thread.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
