1.Block off one oil feed in the block (RB26’s have this standard)
2.Fit an appropriately sized restrictor to the other feed. The size of the oil pump is one of the determinates for the size of the restrictor, ie; a high flow, high pressure pump needs a smaller restrictor. Constant higher RPM needs a smaller restrictor etc.
3. Fit an external oil return from the rear of the cylinder head to the sump
4. Drill out the oil return galleries in the head and block
5. Machine around the oil return galleries to facilitate access for the oil "
1. In ur head assuming its an rb25, ull have 2 oil restrictors there, make up a solid one and push it ontop, blocking one restrictor.
2. Refer to the table decribed in the previous post by r33_racer
3. If you look at the back of the head ther will be some welsche plugs, tap a fitting into one (cant remember which one, but its explained in the oiling in rb's thread) and and tap a fitting into ur sump, and run a line between the 2 fittings.
4. Do as it says, or send it to a workshop that knows what they r doing.
5. As 4.
Dont take this as gospel, but its near on correct.
wait till u get it tuned stocky then u will have traction issues.
ive owned and had the plesure to drive quite a few high powered v8 and turbo cars and its not a fun fealing when a big turbo comes on in 3rd or ya hit a bump or something on a upshift in the monro and it skips strait sideways not a fun thing when your doing over 100, or even thinkin it will be a great idea in the vl to go back to 3rd to overtake in the rain at 100 kmhr not fun at all.
that's cool man - the thing will be twincharged so the boost (and hence throttle response) will be perfectly linear at all RPM with respect to my right foot. makes it a hell of a lot easier to stay on the edge of traction when torque output is flat through the rev range, and perfectly proportional to throttle opening. i'm hoping it will be quite smooth and easy to drive quickly. hoping.
Time for a touch of realism and a genuine wish for good luck in tuning it. Some things to think about;
1. Torque x Rpm = horsepower.
2. Mechanical losses increase with torque output
3. Aerodynamic drag rises with the square of speed, but the horsepower absorbed rises with the cube of speed.
4. 50% of the horsepower does not arrive at 50% of the throttle opening, well not on any engine I have ever tuned. On an N/A engine it’s closer to 30%, a supercharged engine around 40% and a turbocharged engine around 55%.
5. This % varies markedly according to rpm
If you do achieve the magic of balancing the above, you will have achieved something that all of the automotive manufacturers in the world haven’t been able to despite 110 years of trying. The most recent attempts being throttle by wire, because a linear response throttle cable has no chance.
:) cheers :woot:
Edited by Sydneykid
Can some1 help me out with the front pipe & dumps for my 32 gtr rb2630 conversion.
I need some dump pipes and a new front pipe, in the next 2 weeks, but dont want to pay a rediculous amount (i.e ~$2000 CES quoted for a full custom job).
Would the best idea be to buy a pre-made one (like a Trust Extension Pipe) and modify it so the dumps dont hit the firewall?
What have other people done, and how much did it cost?
cheers, Shane
cheers, Shane
The 30mm or so really make that bigger difference?
I would say the cheapest would be to modify a current setup by far.
yeh good point. i rang up CES today for a quote, and he said that i could get away with running a stock position front dump, but the rear would need to be changed
prolly depends on how much clearance there is/isnt. i can see me putting the engine in and out a few times here *sigh* there goes the lovely new paint job
lol that's twice now i've been caught out using words that aren't 100% correct.
in my previous post, delete the word "perfectly".
but i am still expecting torque output to be very flat through the whole rev range, which goes a long way towards making a car easier to drive quickly.
the number are irrelevant, so long as power is fed in linearly to the wheels with respect to throttle position. at any given point in the usable power band i would hope to be able to control the throttle (and hence traction) with much greater ease than a conventional turbocharged engine. this is primarily due to turbine shaft speed taking a little while to "catch up" to the engine as you feather the throttle. a roots blown job might be better for this, strictly speaking, but as we know most roots blower setups have a rather sharp drop in torque at the top end.
bah anyway we're just being picky gimps now (i'm the pickiest of the bunch haha!) i guess i should get off my ass and build the thing already and stop arguing silly points.
p.s. cheers for the info man, i didn't know this either: "3. Aerodynamic drag rises with the square of speed, but the horsepower absorbed rises with the cube of speed." happy to learn new things!
Edited by StockyMcStock
hi guys what a thread!!
i have a mid level drag gtr
last time out i blew a side out of the block(to greedy with the nos)
so ive been thinking about building a rb30 baised short block as a temp replacement untill i can get the funds together for another full counter bottom end
so i have a few questions
is block flex a problem at higer outputs?
if so anyone maid a stronger crank/block gurdile?
if so was it incorperated into a 4wd adapter?
how hot do they run with a filled block?
as my 26 head/cam setup makes maximim power at 9500rpm is there any way to make the things rev
anyone tryed a rd28 crank in a rb30?
is there any way to work out the first/second order hamonic vibrations on a crank(rd28)
will my rb26 ati harmonic balancer work on a rb30 or rb30/rd28 hybrid?
is there anything else i need to know about the rb30 in extreme power aplications
the general idea is to use a rb30 early block(iv been told they are a little stronger correct me if im wrong) rd28 crank with some custom rods and a set of ross rb26 pistions i have lying around
what do you thing it could rev to (not paticulaly safely)
the donor rb26 has the following specs
gt42r
nos six port flogger
hks manifold
trust drag spec intercooler
geady plenium
50mm x 6 thottles
full tomei drag spec head
extensive porting
tomei drag cams 280 in 288 ex 11.25 lift
ti buckets/retainers
big valves/springs
ati damper
os tripple clutch/flywheel(will it bolt up?)
motec m800
we were running 2.5 bar in a filled rb26 group a block will a rb30 block take this?
anyone give my trust dog box a chance with the extra touge?
am i playing with myself with the rd 28 crank idea would i be better to run a rb 30 crank and use smaller cams and only rev to 8000?
thanks in advance
Edited by magicfingers
gt42r
hks manifold
geady plenium
50mm x 6 thottles
extensive porting
big valves/springs
ati damper
motec m800
thanks in advance
So many questions, the answer really depend what power output that you are chasing. Let’s try a numbered approach;
1. Why do you want use an RD28 crank, they are no stronger than an RB30 crank
2. Nizpro make a full width crank girdle, damn expensive though. We have used the standard crank and girdle up to 950 bhp. That using ARP main bearing studs.
3. RB30 harmonics are GROSSLY overrated. To cure the tiny harmonic that they really have, you can use your RB26 ATI damper or simply overbalance it.
4. Off the shelf Argo I beam rods will do the job, as per #2 above.
5. The 4wd sump adaptor adds a fair bit of lower block rigidity
6. Sorry I have no idea about temperature and block filling. Since engine temperature it is a factor of horsepower X efficiency I can’t see why an RB30 would be any different to an RB20/25/26 at similar power levels.
7. I can’t say as I have ever seen any differences in early/late/turbo/non turbo/ Skyline/Commondoor blocks. They have all measured up the same for me.
8. You won’t need 2.5 bar (like you did in the RB26) to make the same power in an RB30. It’s actually pretty linear, so around 2.1 bar should do it.
9. The extra 500cc’s takes away some of the “bigness” in the cams. What’s a lumpy overlap in a 2.6 litre is quite a bit smoother in a 3 litre. I’d give the 280/288’s a go.
10. Always keep in mind that an RB30 will make the same power at 7,500 rpm as an RB26 does at 9,000 rpm.
I think that about covers it (tip = number the questions, it makes it easier to repond)
:D cheers :O
i've gone thru 207 pages i cant find anything.
i'm running an rb30dett
using
rb25de R32 head
rb26 plenum
rb26 turbo and manifolds
i cant seem to find any pistons to get my comression up so i have good responce.
any help would be good.
cheers
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
