  slo-a31 said:
i've gone thru 207 pages i cant find anything.
i'm running an rb30dett
using
rb25de R32 head
rb26 plenum
rb26 turbo and manifolds
i cant seem to find any pistons to get my comression up so i have good responce.
any help would be good.
cheers
Machine the head and block to get the compression ratio you want. Mine is 9 to 1 with a slight dome piston and 0.8 mm head gasket. The combustion chambers are 62 cc’s (standard is 64-65 cc’s). I retained the standard squish.
:( cheers :(
  slo-a31 said:
what pistons are you running sydneykid?
JE Pistons in mine.
But it doesn't matter what brand.
You need a slight piston dome, so look at the spec sheets and pick one.
Then select a head gasket thickness and machine the head & block to achieve the target compression ratio.
:) cheers ;)
Edited by Sydneykid
  Sydneykid said:
JE Pistons in mine.
:P cheers :wub:
the ACLs i bought are are flat top. everything considered is dome top preferable with respect to creating the correct squish etc?
The ACL's run positive deck height, so same result as the JE's.
:) cheers :P
I'm thinking of making a 3L RB26. Most likely by taking the crank and so on from an RB30 and putting into an RB26.
What are peoples thoughts?
I've heard that RB30 bottom ends have different mounting points to the RB26 hence why I was considering going down this route.
Thats already been done mate...an engine builder posted about it on here a few months back now...used the rb30 crank in a 26 block im pretty sure it was and after alot of machining and customised work it became a rb29 or something. But i remember him saying there was alot of work in it.
Edited by r33_racer
Has anyone here used a JUN oil pump collar on an RB30 crank?
It came with 2 grub screws and instructions, in Japanese of coz :rofl: is anyone able to translate?
I'm aware machining is required but are only 2 grub screws going to be safe?
Pics attatched. :laugh:
Edited by Alf
whats there to translate mate?
It gives you the machining diameter needed to fit the collar on. Its very straightforward. We took ours to the machine shop down the road and they fitted it for us...we just loctited the grub screws in. Some people use a interference fit and heat the collar up, and freeze the crank and let them normalise onto eachother and then put the grubscrews in, ofcourse the crank will need to have recessed holes for the grub screws to lock in, making sure they go in just under flush.
I think it cost us like 90 bux to get done and its still working :)
I think it cost us like 90 bux to get done and its still working :P
That's the go;
1. machine to the dimensions
2. heat collar and cool crank
3. press collar onto crank
4. drill holes for grub screws and tap threads.
:happy: cheers :)
Ok the race car is going in for another tune and this is what it has..
1997 R33 S2 GTST RB25/30 Race Car.
RB25 Head with VVT
Mild Port n Polish
Tomei Type A valve springs - not fitted
Greddy Intake Manifold w/ Q45 Throttle Body
S/S Exhaust Manifold - 6Boost fitted
Tial 38mm Wastegate - 48mm Turbosmart Gate fitted
GT35/40 0.82 Rear AR
3" Straight through Exhaust, Dumped PS infront of rear wheel
Screamer to ATMO
Q45 AFM
850cc SARDS
POWERFC PRO w/Datalogit
AVCR
600X300X76 PWR I/C - Soon to be 110mm ARE I/C fitted
Turbosmart BOV
CP 25/30 Pistons w/CP Chromemoly Rings 8.3:1 CR
ACL Steel Headgasket
REV I Beam Rods
ATI Super Damper - fitted
044 Bosch Pump/ 40ltr Fuel Cell
ACL Bearings all throughout
ARP Main & Head Studs
Tomei 256 Poncams IN/EX
NI Oil Pump with JUN Crank Collar
4.5l Custom Catch Can
PWR 50mm Core Radiator
High Energy Circuit Sump
Exedy Twin Plate Clutch w/ Chromemoly Flywheel
So previous tune at Charlies saw us making on 18psi 240rwkw. Cranking the boost right up (25psi) and were hoping for about 300rwkw. The figures seem low in comparison to everyone elses for the mods done. What would you guys think it should see power wise? They dont tune or power run the car in shootout mode, they think its a wank for some reason.
Edited by r33_racer
hi guys
i read somewhere in this thread
i think it was earlier on in it
it mentioned something about R32 GTST gearboxes i think being too weak and not being able to take the power which some of these hybrid engines produce....
i am just curious to whether this is the same issue for the R32 GTS4 gearbox?
or would i need to change to another gearbox?
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
