No, most charge a few hundred more.
SPS in Melbourne said yeasterday they can make whatever you want if you give them all your specs.
Approx $1700-1800 incl rings and pins. Im pretty sure they use Cosworth blanks?
Thats what I thought!! I did a quick calculation and got 9.4 and was confused! Hmmm
Edit:
I just did a calculation on that webpage:
Arias
2 - 9.83:1 --> I got 9.1 ??
What c/r are they meant to be Cubes??
I dont know if any other pistons brands make a RB30/2# specific piston in 8.0+ compression and I cant be stuffed reading thru all the thread again! :sleep:
EG: JE, Wiseco, Mahle.
How did you get 9.1?
See attached pic of the values I used for Arias piston 2 that gave me the 9.83:1 comp ratio.
I put in 86.5, 85, 87 HG bore, 1.2 HG height, 65cc for RB26 (was a guess, some say they are 70cc? although CP measured some at 64.5cc avg) and 13cc dome.
= 9.12
Im picking up my RB26 head later today so i'll have to measure the cc's!
= 9.12
cubes and my rb25de head cc'd up around 62
With regards to exhaust manifolds...
Its written in the guide:
In order to bolt up the exhaust manifold of your choice you must grind down the water galleys protruding lumps that run from the front to the rear of the block. They must be removed as they foul the exhaust manifold.
does this apply to stock exhaust manifold as well? silly question, would it work if I grind down the manifold instead of the block?
Yes, this applies to the stock manifold, you are better off grinding the block, ,as it is only a small amount, and if you grind the manifold you will risk causing it to crack. P.S. im pretty sure an R34 manifold doesn't have to be modified, as it must be slightly different to an r33 one.
Im also interested in this, just about to order the acl ring set but wich set do i get? obviously the RB30ET rings would be beter as they are almost twice the price. can the RB30ET rings be fitted to the RB30E pistons?
Cheers.
Can anyone answer this? i asked it on page 230 but got no replies.....
im going to be running the RB30ET rings on the RB30e pistons, waiting on a ring compressor so i can put them in
im sure i'll be posting if they dont work
which head gasket can you use.
im buyin a rb25 metal head gasket off the forums, would it compatible.
also what sort of comp ratio would a 1.5mm head gasket give me on std pistons? and with 20thou over pistons? with a standard head.
RB25 gasket if you have a R33 RB25 VCT head.
RB25, RB26 or RB30 gasket if you have R32 RB25 or RB26 head
http://www.csgnetwork.com/compcalc.html
Use this link from the previous page and work it out with what ever head you have.....
Edited by VHR32
I was talking to a guy today who has just built a RB25 race engine and he suggests 9.0:1 is too high and I would only be able to run 15psi with 98 octane boost and not alot of timing. Is he full of it???
Is a GT35/40 with a .63 external gate way too small for a RB30/26 (9.0:1) track car? Im wanting 300rwKw.
This guy uses a .63 GT35/40 on his RB25 8.5:1 making 340rwKw on Elf fuel. He was running a .82 but was bit too laggy for him. (Seems a high power figure......)
Edited by VHR32
thanx for that VHR32, awsome site. but i dont know any of teh following values.
head is rb25det VVT out of r33.
Bore/Stroke Designation Type?
1 = Inches 2 = Millimeters
Cylinder Bore Size
Piston Stroke Length
Head Gasket Bore Diameter
Compressed Head Gasket Thickness
Combustion Chamber Volume In CCs
Piston Dome Volume In CCs Negative For Dished Pistons (Use '-')
Piston Deck Clearance Negative If ABOVE Deck (Use '-') :
No one that I know of has really played with a .63 GT35r. But given the turbine maps on garretts web site the gt35r .63 flows roughly the same on the exhaust side as the gt30 .82.
The GT30 .82 I know can make 330rwkw odd on a built motor 9:1 on decent fuel, cams, plenum etc; made 580hp on the engine dyno.
So quite possible.
well we had 365rwkws before we spun a few bearings. But with full slicks same size as supercars use 280X680X17" we could spin them in 1st, 2nd and 3rd that was with a gt35r with .82 rear running 1.5bar. Thats when the tyres were upto operating temps too...the power was really savage in that it was coming on really really hard, also had the water inj too. We run shell 100 octane, stage 1 tomei cams, greddy plenum and 6boost hotside.
And you want to run a .63 rear gt35r. I think the best variation for a track car would be the 1.02 rear for the gt35r, unless there is something slightly bigger from hks above the .82 but below the 1.02 cause its still abit snappy when you have descent power. Plus some form of throttle controlled boost as stated a while back would be great.
I want to run a .82 with my RB30/26 but the guy who uses the .63 on his RB25 said his .82 was too laggy out of corners and the .63 fixed that.
A 1.06 would be good to make some big power though....
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
