Finally got around to getting some pictures of the dry sump setup in the race car....its still not finished yet...but its making progress. We gotta mount the ally pipes under the car after i tig on the -16 ends and then mount the tank and finish off that end of the hoses...check out the mass of speedflow crap!
post-12828-1166694939.jpgpost-12828-1166694960.jpgpost-12828-1166695006.jpgpost-12828-1166695026.jpgpost-12828-1166695046.jpgpost-722-1129090407.jpgpost-12828-1166695087.jpgpost-12828-1166695111.jpg
Last one is just a new power steering reservoir i fabbed up. Shiny!
Fun making that all fit. Try it with 2 more lots of fittings on the pump. Nightmare.
so does anyone think it could be anything else the symptons are no smoke in 1st 2nd or 3rd hit about 120km in 4th and she just blows smoke absolutlely every where and will continue to trail smoke in 5th, after this it will some times blow smoke in lower gears but only when giving a squirt, it seems to run quite well untill it dumps all the oil in 4th, any chance this could be a problem with the way the motor was setup? or most likely valve guides.
if it is valve guides is it worth while to upgrade to gtr valve springs or are the r33 rb25det springs more than adequate? and lastly on head gaskets any dramas with a nismo 11044-rr590 Gasket Cylinder Head - 0.9 mm x 87mm
try doing leakdown test, that might provide some clues but won't show worn guides. if its a bit of an unknown quantity it's worth checking as much as you can so you know what you've got. if the mech says valves then I'd go with that, if it's still at the same place those guys seem pretty good . gtr valve springs are not as good as a set from Performance Springs for $250. nismo or cometic metal head gasket will be fine as long as it's the right thickness. head off will give you a good opportunity to check CR also, no point running 7.5:1
as R33 racer said oil returns are gravity feed and can cause problems if not plumbed correctly. all of the hoses should facilitate flow by 'pointing downwards' if that makes sense ie don't have a hose that tries to make the oil run up hill.
valve guides only blow smoke first thing in the morning as the oil drips down overnight then burns off when u first start the car in the morning. If it was valve stem seals u shouldn't see smoke after that initial start.
This was one of the reasons Cubes and myself spent extra to get the head recon'd before the bottom end was built. No point having a fresh bottom end then slap on a 100k+ old head on it
Try a leakdown test, then look at the turbo.
Edited by Bl4cK32
If the inlet valve guides/seals are worn, it will blow smoke when accalerating after decel, such as after going down a long hill, as the inlet manifold vacuum sucks the oil past. Exhaust guides/seals will blow smoke on startup, but not leave any residue on the plugs. Is there oil in the intercooler piping, any residue around the exhaust housing. Have you done a comp test, or is there much blowby out the breather under load?
yeah there's plenty of oil in the intercooler piping, i've also changed the turbo over with another stockie that was the first thing i did and yeah didn't fix it.
The car is running quite well needed a car to drive the other day but on a 30min return trip it went through heaps of oil which was surprising cos it's wasn't blowing to much smoke, put a bottle of stop smoke in it just for the hell of it and it's has actually lessened the smoke but it's still quite bad so it got parked straight back in my drive way
the oil line from the head is pretty much a straight T into the turbo return line the oil never travels up only horizontial but it does have to do a 90 degree turn
had my mechanic drill and tap the head, then put a grub screw inplace of the original vct feed, then drilled and tapped into the front of the gallery behind the inlet cam gear and put a fitting in there for me, all i need now is some braided line to go from the oil hole behind the oil filter to supply it with oil, as the rb25 oil cooler assembly houses the std oil pressure sender, where as the rb30 used the hole behind it.
dont have pics here though
did you have to weld shut the oil feed port on the block, and did you modified the coolant port on the block to match the r33 rb25 head?
guys i need some help with find a bloody timming belt, ive try'd just about every place in australia.
Ive put my second tensioner in stock position, motor is together so i dont want to drill and tap holes.
All i need is a timming belt: 1200 long, 150 Teeth with a 8 mm pitch 25 mm wide to fit on the rb cam / crank gear.
Sound symple? well its not!
The gates powergrip 1200 8mgt belt is an industrial belt and does not fit on the cam and crank gears. All automotive belts have a tooth number but no length and no pitch information... so how the F$@* do you find a belt?
P.S Both the bosch and Dayco belts on the SAU PDF are 152 tooth for use with relocated tensioner
Edited by kaige
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
