Hey everyone, I have got a timing belt that was sold to me by a local performance shop. They did an R32 with a 30DET in it using an RB25 head and they told me they rang gates and organised a belt with them that works with the idler/tensioner the same as TWINVL was setup but its a shorter belt so it doesnt run so close. The belt I was given is 25mm wide, its a Gates Racing powergrip belt. It has T1592R on it and the numbers 102 through to 106 and 5-25.
Not sure if this information will help anyone in anyway, ive seen belts setup so many different ways its not funny, so what ever works go for it!
Kaige posted:
TWIN VL... 'now using the same belt p/n T306 due to the gates not fitting properly so should be all fine!'
RB Calais posted:
...same as TWINVL was setup but its a shorter belt so it doesnt run so close...it's a Gates
So I'm assuming that TWINVL has used the 'close' set up. BUT he appears to have moved to using the T306 belt (his website still indicates that he used the Gates) presumably due to the perceived problem with the Gates tooth profile.
Edited by Scooby
Scooby.. He's a dude on ct.com.
Just did a comp test. Motors done 50,000km's. 158psi exactly through out. I did 2 tests on each cylinder. The tests only varied 1psi. I took the highest reading.
So same as last time. Exactly the same across the board.
The motors running 0.0040" bore to piston clearance with a set of rb25 wiseco's.
the rb30e sump is slightly deeper than the rb20e sump. my engine went into a cefiro and we needed the space as the 30 sump would have hit the crossmember
my brother overfilled the engine and i can report than an rb30 can hold more than 10 litres :-)
hah yeap i was incredibly suprised when my 10 litre bucket didnt have enough space
what pistons does one reccomend if the acl ones arent suited?
S3_girl (Darren) is running Precision Hyperutetic pistons in his 370rwkw odd rb30 with std rods.
talking about pistons... I am quite sure that the dirty old VG30 has a slightly larger bore than the RB30. if i remember rightly, it is 0.5 mm. i'll check that..
Anyway, i havn't actually seen it for myself, but i've been led to beleive that they are a flat top style piston. I you bored the RB30 to suit it get you closer to the 9:1 comp ur after. most know that the VG also had a turbo version, so use that piston! wouldn't be the most ideal setup for making bulk power, but a good sound setup for a mild streeter..
Its worth the consideration and checking pins fit and deck height and all the usual stuff...
That help??
Hell thats good Cubes, well done. I still reckon your motor is one to aspire to. I went with RB25 Super Techs 8.98 according to software comp; .0025 coated and thats what they recommend.
Still want to get to the bottom of the timing belt issue. My preference is to run the 'close' set up using the same belt Kaige is using. The issue with the Gates belt profile has got me wary.
Edited by Scooby
is that the brand? im in nz so havent heard of them before
i was going to go with acl ones with the chromoly ring but you guys are doing very well at putting me off
I assume so.. Precision is what I remember he said.
I can't find much on them via google.
Hey cubes....you ran 4thou piston to bore clearance in your motor, with wisecos and you said you get some piston slap when its cold. I ran acls in my personal road r33 when i rebuilt the rb25 not long ago, i ran 3 thou piston to bore clearance, which was 2 thou tighter then what acl specs stated. Even so i get absolutely no audible piston slap, not even straight up in the morning on cold start.
Out of curiosity what was your ring end gap clearance?
I do get some slap but its not audible unless you pop your bonnet and really listen. Even then it only sounds like a little top end noise. So definitely not what I'd consider 'piston slap' but its definitely there for the tuned ear. :huh:
I have No idea what the ring end gap clearance is.
The bloke who built my motor said never to let it sit and idle on cold starts. Simply get in and drive it lightly to bring the engine temps up quickly. He also did something funky with the bore hone to reduce leak down and speed up run-in.
hmm i wonder if he washed the bore down with shellite and sprayed inox or wd40 to quicken up ring bed in. I know thats a common practice these days for some workshops to help speed up the run in. Normally you just wash down the bore with hot soapy water after honing and then coat with oil until its fully assembled and started up.
Would be interesting to know how many people/workshops actually use that method after boring and honing and if there has been any noticeable effects from it, good or bad.
If precision hypereutectic are no stronger than factory pistons then there's no need to run forged pistons until you're over 400rwkw. :huh:
There's a few words over at calaisturbo on the precision pistons.
http://www.calaisturbo.com.au/showthread.php?t=28737 - Post 5
http://www.calaisturbo.com.au/showthread.php?t=66415 - Post 3
I noticed there's a few reports of failed hyp acl pistons over at ct.com.
4 thou seems standard for forgies, unless they're coated like Mahle or Super Tech which run around 2.5 thou recommended. Not withstanding that you ran the ACLs tighter, which could have helped address a tendency towards slap when cold, I know the ACLs have a different skirt design that combats slap.
Cheers
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
