Cubes Posted August 19, 2003 Share Posted August 19, 2003 Also remember people... When you are quoted a price it ALWAYS ends up being more. Its rather frustrating actually, as origionally I was quoted: Head Reco: $415 Head work: $310 Total ------: $725. I droped the head in and it ended up costing an initial of $830. The head was in perfect nick no welding etc required. Where the extra $100 came from I don't know. After everything was assembled the total was/is $890. Others quoted me $900 etc.. which is pretty close to $890 obviously, I wonder if they also would have jumped in price. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-491745 Share on other sites More sharing options...
Skyrine-Dave Posted August 19, 2003 Share Posted August 19, 2003 i just got quoted $495 + gst to have my head crack tested, surfaced, cleaned up, valves reseated and timing set up... then i have to supply the VRS kit on top of that price. these guys will weld my vvt oil feed for free if i want them to, they also did a vac test on it and checked for warpage for free. It vaccums up alright and has very minimal (normal) degree or warpage. so thats all good news for the head Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-491906 Share on other sites More sharing options...
alkaline Posted August 19, 2003 Share Posted August 19, 2003 How about a whipple in the RB30DE engine I am looking at building an RB30DE with a supercharger instead and aim for over 250kW although I am more interested in a smooth torque curve so the power feels like n/a. Is this possible with say 5psi and about 9:1 comp ratio? I would retain the VVTi too... Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-492837 Share on other sites More sharing options...
JNR24 Posted August 19, 2003 Author Share Posted August 19, 2003 Very possible, you could probly run a slightly larger pully and goto 10 or 12 PSI. (Considering the turbo RB25 runs a 9:1, why couldnt you run the same boost as the turbos?) just a thought, Trev Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-492957 Share on other sites More sharing options...
Steve Posted August 20, 2003 Share Posted August 20, 2003 I want to put a blower on mine too, how much can you pick up a whipple for over there, and what sort of flow? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-493733 Share on other sites More sharing options...
alkaline Posted August 20, 2003 Share Posted August 20, 2003 So 12psi at 9:1 is ok then? What ratio would be good for just n/a with vvti... 11:1 ? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-493735 Share on other sites More sharing options...
sik32 Posted August 20, 2003 Share Posted August 20, 2003 well the engine and r33 gear box are in my 32, all that is left is one piece tailshaft, custom plenum, ta51/to4 turbo, custom in/ex manifolds, turbosmart 45mm wastegate, new dump, new intercooler, oil cooler with remote kit, 650cc injectors to bolt on. hoping to race at Jamboree in a few weeks Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-493937 Share on other sites More sharing options...
Cubes Posted August 21, 2003 Share Posted August 21, 2003 Originally posted by Skyrine-Dave Anyone know if i can just push top feed injectors into the RB25det fuel rail? like could i straight fit a top feed Rb20 injector straight in ? Why use the Rb25DET fuel rail?? use the RB20 fuel rail. Steve has recently performed this. Do a quick search. It requires a simple modification with how the fuel rail bolts up. Apart from that they slide straight in. I'm glad I am using the RB25DE head it makes things so much easier. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-494964 Share on other sites More sharing options...
Clicks Posted August 21, 2003 Share Posted August 21, 2003 I currently have a R33 25T Skyline and am looking to do this conversion as well. Friend of mine is sending me up a rb30 short motor with the vvt oil outlet put in for me.. Also going to clean it up a little for me port the exhuast and intake ports a little. And move the Tensioner. From what I have read here I will be able to pull my motor out (with help from friends) and bolt on/hook up the rb30 bottom end to my Rb25DET top end. hook it all up - dial in some advance timing (25-27 degrees i belive i read that was what 25T is using) and drive away. happy boi as well as geting the gasket kits. From what I can tell the Rb25det injectors and oil pump will be fine with it all. Joel your how to guide is awsome. Congrats to you on the job well done. This is a extreamly helpfull thread! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-495046 Share on other sites More sharing options...
OVL-747 Posted August 23, 2003 Share Posted August 23, 2003 i dont know about a skyline , but that is some pretty advanced timing mate u will wanna have a great fuel system to match it so as to not ping like a little hoe Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-497880 Share on other sites More sharing options...
Cubes Posted August 23, 2003 Share Posted August 23, 2003 Yer I wouldn't be dialing in that much timing until its on the dyno, even if it has got a low comp ratio. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-497975 Share on other sites More sharing options...
alkaline Posted August 23, 2003 Share Posted August 23, 2003 its actually 4 to 6 degrees to get better low end torque, then when the rpm goes up the VVTi retard the cam in sync in order to keep the torque right up through the rev range. Up at a certain ammount of rmp the VVTi will stop retarding the cam at about 10 degrees at which point air speed falls behind the engine rpm speed. A turbo will increase torque at higher rpm due to the fact that at such high rpm it becomes inefficient for air to fill the cylinder before the valve closes. As air is forced in under higher then normal atmospheric pressure, the engines highest torque level will shift to a higher point in the rpm range. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-497978 Share on other sites More sharing options...
Cubes Posted August 23, 2003 Share Posted August 23, 2003 alkaline.. We are talking about ignition timing. Well I think we are.. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-497982 Share on other sites More sharing options...
alkaline Posted August 23, 2003 Share Posted August 23, 2003 So he wants to do the 1/4 mile in reverse? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-498031 Share on other sites More sharing options...
Cubes Posted August 23, 2003 Share Posted August 23, 2003 say what??? Here's a quote from the post I thought we were talking about.. hook it all up - dial in some advance timing (25-27 degrees i belive i read that was what 25T is using) 25T did the conversion and when on the dyno required this much timing. I think he made just over 200rwkw on 14psi and a stock ecu. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-498035 Share on other sites More sharing options...
alkaline Posted August 23, 2003 Share Posted August 23, 2003 But advance timing is only required at higher rmp right? at low rmp I guess the engine may not even start? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-498038 Share on other sites More sharing options...
Cubes Posted August 23, 2003 Share Posted August 23, 2003 Ignition timing is different to cam timing. Ignition timing is the spark fire timing at TDC. It is what you set via the CAS, it sets the base ignition timing. The ECU then adds or reduces timing depending on various variables i.e if you are running to much boost the R33 ecu will pull timing and richen up the fuel map in turn creating a power dip. The CAS sets the base ignition timing for the ecu to work from. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-498044 Share on other sites More sharing options...
alkaline Posted August 23, 2003 Share Posted August 23, 2003 Yeah I know, I was being sarcastic because if you advance the timing too much the engine will ping / backfire. Thus force the cylinder in the opposite direction... (thats what I mean by doing 1/4 mile in reverse) Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-498048 Share on other sites More sharing options...
darkstar Posted August 26, 2003 Share Posted August 26, 2003 Ok im in the process of reading all 25!!! pages (upto page 8) Just like to clarify that Series 1 non turbo blocks, have blanks for the turbo fittings. All series2 non turbo blocks (even some late 86 series 1 blocks) have bungs in place of the usual turbo fittings. You will have 3 fittings on the block, 1oil in, 1 oil drain (big bolt near the sump) and 1 water drain. The water feed comes off the heater hose fitting via a T peice from factory, peice of cake. True turbo blocks are stamped with an A8 at the end of the engine number. Non turbo blocks (even with the bungs) are stamped A6 at the end of the engine number. The engine number is on the exhaust side, near the bell housing at the bottom. Ill add some more comments when i get thorough it all. Pretty great info at the moment, but it needs to be all trimmed down to the relevent bits for the conversion, perhaps in a document or a modified version of the thread. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-503100 Share on other sites More sharing options...
Roy Posted August 27, 2003 Share Posted August 27, 2003 Question for the ppl using Arias pistons. If using std head gasket, and assuming any headwork doesnt bump up compression ratio, what CR do the forget Arias pistons leave you with. Thanks (Yes i did read the whole thread before asking question... now im taking an asprin and laying down... my head hurts) Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/23/#findComment-503233 Share on other sites More sharing options...
