yeah they finally released it, actually useful data for once
pitty it needs to much damn turbine speed to get anything useful from it
whats a realistic rpm we are talking to get a 0.70 a/r housing fast enough to make the compressor flow 1.5 bar. is there a way to mathematically work this out?
given that we know required turbine speed and pressure ratio ?
72% efficiency for 65 lbs/min of airflow for 1.5 bar boost at just under 100,000 rpm is pretty damn good.
A ball bearing turbo will last forever at those sorts of loads.
The only turbine map I have seen is for the 0.84.
:P cheers :D
i think we figured out why ours isnt holding boost. To do with a lack of backpressure in our exhaust system now haha. So yeh..hopefully find out in a day or so if the fix will work.
Spoolup...what manifold are you running again? Is it one of Kyles? Ok so i just backchecked last page...and you do run one of kyles. Well i just got back from seeing kyle at Mercury before. With our situation, because we put a 4" system on now there is virtually no backpressure whatsoever and because his manifolds are so efficient and now our exhaust system is super efficient, the exhaust gas is bypassing the wastegate completely as soon as gas velocity starts to skyrocket. Kyles fix, for us atleast, is to modify the rear housing so the wastegate is mounted straight off the turbines feed so exhaust gas is forced into the wastegate and cannot bypass thus letting us control boost pressure perfectly. Ive got a modified housing with me now, which will go on tomorrow hopefully or asap and we will know how it goes, but im highly confident it will fix the problem.
Unfortunately I dont think that will fix your problem Spoolup. :)
Edited by r33_racer
Hey all. You may of covered this already but 241 pages is alot to read lol. What crank is everyone running on the conversion. I found out today my the crank i got with my rb30 block is no good. Do you think its worth the money and finding a performance crank or just put my money elsewhere go find another crank from the wreckers and just get it checked over?
Hi pal, depends what you want out of your engine.
stock rb30 should be fine. Thats what i'm using for my build.
simon
yeah funny enough I was talking to Kyle today about my problem also, he said he had a 60mm hks gate like mine there that had a 3mm gap between the valve and the seat, and it was new. So Ill put some plasticine on the seat and put the gate back on, then pull it apart to see if the valve is actually seating on the seat ( it should have approx 1 mm of preload ).
Oh the joy of it all :-)
ok sweet thats what ill end up doing just with a different crank pulley. does anyone have any info on the oil gallery in the head i have to weld up. Or something about mods i have to do to make the vct work
Here are some photos of kyles manifold, it shows the wastegate pipe setup. These are for Sky30 more so, but it may be of some interest to everyone else.
post-12828-1171280712.jpg Just for you cubes :D
Edited by r33_racer
Interesting.. Kyle has gone all out with preventing reversion.
Very nice exhaust manifold. I have never seen the collector of one.
Awesome Pics. Thanks. :D
You didn't grab any of directly down the throat of the collector did you? :laugh:
ok guys, just finished dummy fitting the engine in the engine bay, what a farking task, as its been out for about 8 months now.
Ok its in and sitting on the engine mounts, however, the front is sticking up in the air far too much, and the bonnet is no wear near closing. I'm using the std RB26 engine mounts, and i've tried to fit them and the rb30 ones in all sort of combo's but the only ones that fit r the std rb26 ones. I had a quick look underneath, and it seems to me that part of the sump, is resting on the cross member, has anyone dealt with an rb26/30 in a gtr before? Oh and in regards to if the dumps clear the firewall, yes they did, only just however, as i've removed the aircon, the drain pipe that comes out of the firewall was removed, and the dumps JUST fitted down there, i had to force it a bit to get the pass. engine mount in the hole, but it fits.
heres the pics i took:
Hi Shane, not sure what's going on there. Cross member clearance shouldn't be a problem, the deck height is increased at the upper end of the block from the top of the water pump upwards. And the bonnet should well and truly close if you can fit a strut brace under there, the're a lot higher than 38mm above the cam covers. The engine is supposed to be on a bit of an angle but the clearance should still be good. Try looking on the GTROC UK site for comparison pics
http://www.gtr.co.uk/forum/upload/52458-rb...ight=r32+combat
at the risk of stating the obvious it seems that the whole engine is tilted way to far up at the front and that's what is causing the sump to hit at the rear.
The GTR/GTS4's run a block/sump adaptot plate so it also lowers the sump down slightly.
Anotonys GTS4, everything is VERY close. The bonnet had to be cut as the cam belt cover was touching.
This is so farked. I have an RB26 bottom end with Eagle rods ready to go with an RB25DE head when i find one. I was planning on using a 3076R 56trim with the HKS manifold and wastegate i have. I also have SKY30's old Apexi cams.
NOW, here is the problem. I thought a 3076R with 2.6L would be very puncy. But on the weekend i went in an RB25 with 270rwkws from a HKS GT-RS, headwork and Proncams. I was expecting it to have more grunt and pull.
Now my problem is i was planning on using a turbo bigger then the GT-RS and i now doubt i will get what i want from the RB26. :laugh:
I have looked through the RB30 results and i cant see anyone using a 3076R on an RB30. Can anyone point me in the direction of an RB30 with a similar setup so i can get an idea of the mid range it will have?
Troymeister,
This is an old dyno sheet i've kept since the early rb30det days.
I believe it was a GT3040 .82 running 1bar. Both were tuned to optimal afr's and ignition, std plenum nice ext gate hotside.
I believe it was this bloke that later went the gt35r .82, he said he's never looked back. I've actually had a couple tell me that. GT30r to GT35r and never looked back.
For the track I really think the GT35r .82 is a really nice match. I'm going a GT35r .82 with the xr6 .5 comp cover, as suggested by the local turbo bloke (ATS). It should be good for up to around 350rwkw. Why the .5, well I suggested it and he said most definitely, it improves streetability without killing top end for the power levels you are looking at.
Also.. Antony's Rb30DET gt35r .82exh .7comp. Loaded up on the brake I saw 15psi by a shade over 3000rpm!! I was quite impressed. Its slowly being all sorted and turning in to an awesome package. As should mine be after I stop this damn mig wire sticking to the item I'm welding. :laugh:
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
