you'll find that dyno RPM boost thresholds don't mean shit in the real world, especially with a manual vehicle.
for example, my car made full boost at 3700rpm or so from memory when it was on the dyno.
on the street, it's like this if you mash it from idle:
1st: full boost 4500rpm
2nd: full boost 4000rpm
3rd: full boost 3600rpm
4th: full boost 3000rpm
so dynos aren't really very accurate when you compare it to a real-life situation.
the only reason to be concerned is if the car feels bad on the street, or doesn't do what you want it to do. then you know you need to change things around to suit your driving style. for example, next time i get the car tuned for more power (up above 400whp) i'm strongly considering going to a larger supercharger drive pulley to push the turbo up to a faster spool and get full boost down to around 3000rpm on the dyno. after driving the thing for near on 2000km now, that's the only real change i have even considered making.
y do all the tuners use speed as one of their axis? god it gives me this shits!
Not my dyno - its my mates.. i just change what i needed to - just to get it how i know how to use it :P
yeah, but why dont they just change the bottom axis to rpm? seems farking stupid to me :laugh:
How do you do it on a dyno dynamics dyno ? tell me how and il do it next time ! - considering i do all my tuning by myself it does not really bother me if its in km/h
Guilt toy, what pump you using and do you run a rising rate regulator?
I made 312rwkw with 550cc injectors with 044 pump and rising rate reg, only running around 75% duty cycle from memory.
I am using a Walbro 550hp pump - i wired it to a 12v relay etc etc... im using a sard fpr - i dont know if its a rising rate or what the rate is.
Funny thing is that at 317rwkw my injector duty is only up to 75% - its because it completly runs out of fuel - on the fuel pressure / flow tester it was going down to .5 litres a minute returning to the tank. So i am using pretty much all the fuel thats being pumped down the line. Need lots more flow and more reliable pressure.
Might get another walbro pump and stick it in the tank OR get a surge tank and a 044 and use the walbro to supply the surge tank.
Edited by Guilt-Toy
Not my dyno - its my mates.. i just change what i needed to - just to get it how i know how to use it :laugh:
no idea mate, but there should be a variable you can change somewhere...
Not my dyno - its my mates.. i just change what i needed to - just to get it how i know how to use it :(
Use the rpm probe on the dyno, it goes on the ignitor loop, where the timing light goes.
Or input the tyre size and diff ratio into the DD computer and it will work out the engine RPM
Piss off that Walbro fuel pump, they are shyte. The 550 bhp rating is for an N/A engine, they don't handle boost, as soon as the FPR compensates for boost pressure, the fuel flow drops of dramatically. Go Bosch, they are rated for flow at 73.5 psi, so plenty of head room for boost.
:sick: cheers :laugh:
Thanks Sydkid
Could i use the walbro to feed the surge tank and use the 044 from the surge tank?
Just wondering if the walbro would be good for a pre pump.
Cheers
:D cheers :D
If the dyno doesn't have the rpm input(they are a rip off), then i set the speed to 101kph, and hold the car under gentle load at 100, look at the rpm on the handset etc(not the tacho) Then press "Control R"and set the ratio tacho in the top left hand of the screen to say 31.50 if it was doing 3150rpm at 100. when in power run mode, press control down and set the axis to rpm. you may then have to set the parameters using shift down to say 2000-8000. Im a bit rusty, but that should be right. The dyno should have a piece of cardboard that sits above the function keys and explains all this, but its probably sitting in the draw.
Thanks Sydkid
Cheers
I have my 044 mounted intank(it JUST fits in the stock bracket), not loud, and no surge tank needed.
im sure my emanage will be as good as a power fc ...? at the time i didnt have the cash fot a micro tec and got the emanage ultimate cheap and brand new so i didnt complain
Unfortunately its impossible for the emanage ultimate to be as good as a powerfc as the emanage has limitations due to its design and its piggy back nature (stock ecu limitations, fuel cuts etc).
You'd be better off having the stock ecu remapped. That is providing you don't want to utilize the vct.
cubes i think ya missing some info on my motor /progress
i have a rb25de non vct head with performance springs at 90lbs i was told also been faced and ported.
i have gtr 444 injectors with resistor pak a kkr480 q45afm<= not fitted yet a bosch 910 and surge tank.
hoping for 400rwhp if i can make that with the emanage..?
as it was tuned last time at boost works
as a rb2030 yes a 20 head on a 30 block with vlt pistons no combustion chamber change just water jackets moved 3mm over to fit the 30 ... the problem i had is vlt pistons and rb20 head makes 180 psi cylinder pressure and add 12psi makes pistons fall apart espically after 380,000 ks old pistons made 150 ish and wasnts able to make any more due to rb20det afm neerly maxing out .. pluss 38 degree days didnt help
but my loss .. and ill start again
Thanks Sydkid
Cheers
Yep, Walbros are fine as long as they don't have to pump much pressure.
:P cheers :P
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
