Hey gary
I heard of people running a stock gtr pump or gtst pump in the tank feeding directly to a bosh 044 - is this a bad idea ? one guy has been running his gtr to over 400rwkw like this.
Reason why is because i dont really want to have the bosh pump outside of the tank cover to try and mask some noise and i want to put a xbox in its place instead of putting a surge tank there if i can.
Any suggestions or ideas on what can be done? i would prefer a intank system if i can.
Yep, Walbros are fine as long as they don't have to pump much pressure.
:) cheers :laugh:
Hey gary
I use a standard R32GTR fuel pump to supply my surge tank and 044. Works perfectly as it is pumping against zero pressure. Once you remove the requirement for the standard pump to work against pressure, their flow rate increases exponentially. If you are feeding an 044 directly, that’s even better because they suck, the standard pump is now pumping into a partial vacuum.
I use 044's in tank ALL THE TIME, and I NEVER have a noise problem. People get noise problems because they don't insulate the pump, let the pick up sit on the floor of the tank or let the pump itself touch the side of the tank.
:( cheers :laugh:
I picked up the engine yesterday and got home about 4pm.
Already have it ready to take the inlet system and manifolds. Only holdup will be that I forgot to order a cam belt so will have to get a courier if one is available. Hope to be in and running Monday.
you dont stuff around Geoff.
I finally got my new cat fitted and finished off the exhaust today.
What a difference, it now comes on boost so quickly for a big turbo. Im not going to gas it much until it gets tuned on Wednesday as Id hate to melt this new cat :D
excellent work geoff. Im keen to see it when its all done if its actually in brisbane at the moment? Or still down in mexico?
Hey brad, i pressure tested the pipework earlier on in the week and found a pretty bad boost leak...it could explain something lol. I fabbed up a new turbo to i/c pipe so it seals better and flows better also. No more leaks now, however its gotta go back on the dyno to see if that was the power stealing problem. Good to hear you got your exhaust all sorted, im interested in what power you end up making when it gets tuned. Keep us filled in mate.
Hey Shane how did you go with getting the engine to sit right?
yeah i did sort it out - the problem is my new carbon fibre bonnet sits too low :P i had a std one and placed it on, and bingo, as soon as the gearbox is bolted up she'll sit sweet as. so gotta get a new cf one that actually fits, sigh, more farken money :laugh:
oh and i can also note, there is ~10mm clearance between the front axles and the cross member! lol
shane your car is a never ending project. Its like that damn energizer bunny.
ur telling me. it seems that when i get something finished, another problem jumps and thats gotta be fixed
P.S did u change to a T04z?
just out of interest would there be much gain in doing a 25/30 in a relativly stock car usual mods which i have at the moment PFC, Exhauste, Cooler boost at 12psi.
the reason i ask is that a mate of mine that is a mechanic has a couple a rb30's hangin around and is trying to convince me to put one in (its not going to cost much to do as we will leave the engine as is)
I plan on going a highflow and injectors in the near future and think i will be happy with that for at least a year or so.
so in the end will it be worth it on a fairly stock car? more than anything im looking for torque and driveability
thanks!
Dan
The stock turbo will absolutely kill any top end you have, itll drive like a diesel topping out at 4k, Id wait till you can afford to do everything properly so to save on dyno time and everything else.
Edited by Rolls
What a difference, it now comes on boost so quickly for a big turbo. Im not going to gas it much until it gets tuned on Wednesday as Id hate to melt this new cat :wacko:
Brad, What Rpm does the T04z hit full boost, say in 4th gear? What rear housing you got?
Hi I have read a lot of the last 247 pages and searched as much as I can but still have a few unanswered questions I was hoping you guys could help me out with. Im putting the rb25/30 standard bottom end engine in a r32 and gonna use a TO4z turbo. The car will be used for track days, tarmac events, and the like.
So here goes…
1. If (can) I use a RB26DETT d-jetro power fc. Ive read its been done before but with what sensors? I’m hoping to use my rb20det sensors and loom.
2. If I use the d-jetro will it control the VVT solenoid in my RB25DET head? If not, can I remove the vvt pulley and cam and use a RB20DET cam with adjustable pulley.
3 If I can I would probably get it ground for longer duration and higher lift, I think SK recommends 264 – 270 duration – but what is the max lift I can use without having to machine anything.
4. Will the PFC run high and low impedance injectors?
5. If the vvt cam is removed can I supply the oil for the cam bearing via the vvt solenoid hole?
6. How do I get top feed injectors to fit an rb25det (side feed) plenum. Is there a seal or o-ring I can use?
Thanks heaps for the help.
Rob.
1. You probably can use the d-jetro but so long as you use the correct corresponding sensors and adapt them to the rb25 head. Whether rb20 ones will work only someone whose done that before will know. SK will more then likely know, as i think he may have used a rb20 loom with his 26/30 in his r32.
2. Highly unlikely as no gtr had or has the vct thats found in rb25's. Not sure on what cam you could use to replace it though. However StockyMcstock removed his vct and runs a normal 'non vct' camshaft i believe.
3.not a 100% percent sure on max lift but i think its something like 9.0mm maybe 9.5mm, i know poncams at 8.5mm clear but i think once you start getting higher then around 9 you need machining done so lobes dont hit the head. Perhaps someone else knows for sure.
4.one or the other unless you can run a resistor pack inline somewhere. Being a gtr comp you will probably have to run with low imp top feeds i think they are.
5.If you checked back alot of pages ago, StockyMcstock talked about how he blocked off the vct. The std bearing holes still provide oil for the camshaft and the front has its own supply i think it doesnt rely on the vct feed that bleeds off into the camshafts feed.
6. No there isnt, you will need a top feed fuel rail, aftermarket unless you can adapt a gtr rail to it somehow.
You should have gone through and read from start to finish all of the 247 pages and you would have come across almost enough to answer those questions. I was lucky, there was only like 160 or so when i started reading into it, took me about a 2-3 days of reading every night after work for a few hours.
    • Just as long as it's not those putridly disappointing RE003s.
    • I had this same experience going from a set of no name tyres that were on a set of good wheels (Enkei RPFs) to some Potenza RE-11s (this was a few years ago). The wet grip in particular was so much higher that it was almost scary considering how dangerous the old tyres were in comparison. The expense of the tyres also made me want them to last longer so drove accordingly. Wife happy. So now she only 'lets' me buy some flavour of Brigestones...
    • This. All of this. I am turning >$300 into small particles inside 20k km, because I like to be able to roll around any 90° street corner at the speed limit. Would my car be more fun with cheaper tyres? Possibly. When I swapped out the bald AD09s for new ones, the change in the car was massive. The obvious one was being able to put the power down instead of lighting up into silly wheelspin. But the corollary of that was that the lateral traction went from being fun to fast. It was more fun when it was loose. But the corollary to the corollary is that if I need to dodge a child in the road or emergency brake to avoid the arsehat who has just tipped a GWM on its side in front of me, then I've got a much better chance of that manoeuvre coming off without unintended "fun" meaning that I hit something else, or the original target.
    • Every time I have to buy new tyres I question what actual difference it makes between running $40 tyres and $300 tyres and whether it's worth it. Because that's a massive difference to the wallet. But then I did go to a driving training at some point which also included emergency braking and swerving in the wet. In part I think it was meant to show people how bad it gets. Funnily enough what I took away from it is that I can go much harder than I thought in my car. I presume mostly because of decent tyres. Some of the other cars there were shocking to behold. And a bit scary that cheap tyres are probably a lot more common on the road than decent ones
    • I'm pretty sure that is just straight AI generated word soup, where did you receive that ad (facebook)? They misspell Pirelli twice, no human eyes looked at that before it was posted. Incidentally, I am running the chinese pirellis on my V37 and they are.....OK....I didn't go looking for them, they were just what the shop had in stock in the tall size that car needs. LIke any brand, you really can't trust the brand's reputation to apply to every product they produce. Pirelli make good and crap tyres, all with the same logo stamped on them, and all with an attempt at price premium due to the brand
