i want to clear this up, if I use weisco rb25det pistons, what compression should i order, of the shelf version, suggestions?
Don't use the Wiseco RB30/26 piston, it's 7.0 compression.
Use CP or Arias pistons especially made for the 30/25+26 conversion :happy:
I used the RB25 wiseco piston in mine.
Its not optimal but it works ok. You end up with a highish static comp. Depends if thats what your after.
Either way.. CP's are the best option Im aware of.
Sk uses JE's I believe but I'm unable to find any info on part numbers and what static comp results. SK may have stated one time or another but I'd imagine its been lost in this huge thread.
I can confirm the off the shelf Wiseco's yeild low 7 CR.
They sit .020 inside the bore. The valve relief cuts are a little over 11cc's. I was looking for a 8.3 to 8.5 CR. Alot of decking and shaving needs to be done to acheive that. I do not feel comfortable cutting that much off the block and head.
They would be good for the high boost drag racer I suppose.
As per the PM, decking the block 0.5mm is no big deal, neither is skimming the cylinder head the same amount. We do it ALL the time.
They are SOME valve fly cuts, I can't imagine how much lift you would need on the cams to need that much clearance. Since 9.5 mm needs zero fly cuts.
:happy: cheers :D
The pig arrived in Brissy alive but didn't run well and only had 160rwkw. I think the cams need dialling in but will do it after Thailand unless Brad can get me the gears sooner.
Felt nice enough but the tuning was only to get it here. on temp internet and no email yet.
Hey Geoff,
Good to see you made it , and brought some rain with you :ninja:
Cam gears arrived today. Give me a call tomorrow and we can sort out how to get them to you.
Cheers
I updated my piston list from P221
Added a new p/n for a flat top piston from Arias and added compression ratios for the Arias pistons. Two are quite high for a turbo engine!
CP
All compression ratios are based on zero deck height, 1.2mm head gasket (7.13cc), RB25 @ 62.5cc, RB26 @ 64.5cc. They assure me they have done alot of work to make sure the facts are correct.
p/n= CP-RB30/26-.20
Flat top with no valve pockets
8.2:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
1.280" compression height
Only stocked in 0.20 thou oversize but can be custom ordered in any size.
p/n= CP-RB30/26-.20-9.0
6.0cc dome top,
9.0:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
*Care must be taken when using on RB26 with more than 11.5mm valve lift*
ARIAS
Suit RB30/26
p/n= AP332103
flat top
21mm pin
Only stocked in 0.20 thou oversize (86.5mm).
COMPRESSION RATIO 8.4-8.6
Suit RB30/26
p/n= AP332104
10.6cc dome top
21mm pin
COMPRESSION RATIO 9.2-9.4
Suit RB30/25
p/n= AP332105
13cc dome top
21mm pin
COMPRESSION RATIO 9.5-9.8
WISECO
Skyline RB30 w/ DOHC RB25det cylinder head
1.260" compresion height, 66.5cc head chamber, Dish top -11.3cc, 7.0:1 compression ratio, 21mm pin, 1mm gasket thickness, 1mm deck clearance.
K577M865 86.5mm
K577M87 87.00mm
ACL
6MKRY9608 (VL turbo)
87mm, -4.5cc dished top, 1.261" compression height, 21mm pin,
Standard RB30ET pistons are 7.8:1, with RB25 head it is 7.1:1
These are bumped up to 8.5:1 so with the RB25 head it may give about 7.5:1??
Using http://www.csgnetwork.com/compcalc.html I came up with 8.5 for VLT (spot on) and 7.6 with twin cam head with 64cc chamber.
I entered: 2, 87, 85, 87, 1.2, 64cc, -4.5cc = 7.6:1
BUT these have a lower compression height than the CP/Arias and im sure it stuffs up my calculations but its late and im too tired to look at it any more... :(
Edited by VHR32
