I updated my piston list from P221
WISECO
Skyline RB30 w/ DOHC RB25det cylinder head
1.260" compresion height, 66.5cc head chamber, Dish top -11.3cc, 7.0:1 compression ratio, 21mm pin, 1mm gasket thickness, 1mm deck clearance.
K577M865 86.5mm
K577M87 87.00mm
U might wanna ask cubes about this as he and i are running the m87 rb25 pistons and have around the 9:1 comp ratio
Edited by Bl4cK32
To do the job right you need to do the following:
• rebush the small end to suit 21mm or 22mm pins – whatever you are using
• clearance ( machine ) the big end of the rod and small end side clearances so they fit on the big end journal of the crank and in the piston – as they are wider in std form
• you need to have the big end bearing machined in the rod at the same time otherwise it sticks out past the rod and wont fit on the journal
• machine the big end of the rod so it fits down the bore – as they are wider than the bore in std form and wont go down the bore
• then resize the big end tunnel after all that machining – as it distorts the big end tunnel clearances
• grind the crank approx 7 thou ( from memory ) to suit the rods with 40 thou oversize chev bearings
Its not a cheap exercise to get it done correctly
please shed some info as far as bearings and or mods required for the rods?
Added a new p/n for a flat top piston from Arias and added compression ratios for the Arias pistons. Two are quite high for a turbo engine!
Suit RB30/26
p/n= AP332103
flat top
21mm pin
1.280" compression height
Only stocked in 0.20 thou oversize (86.5mm).
COMPRESSION RATIO 8.4-8.6
VHR32: Are these parts number off Arias catalog or is it a custom job part number?? I was looking over Arias current catalog and these numbers are not on the list.?!?
They are Rocket industries part numbers, they get them made from Arias and stock them here in Australia.
I have these, they also suit 25 as listed by Rocket industries.
All pistons suit 25 and 26 head, 26 has slightly lower compression due to the larger chamber.
What c/r did yours turn out to be?
What sort of boost do you run?
Has much timing been put into it?
Gary - what fuel filter is available that wont restrict the new fuel lines that Im about to install ? As most seem to be smaller than the 9 mm fuel hose ?
Cheers
From memory, Dash 6 fittings, they bolt straigh to the pump and 9 mm ID hose.
Under the car using the standard fuel rail clamps.
I use the standard feed pipework as the return and remove the standard return pipework.
On the R32GTST, I used the HICAS pipework, it was there, in the right place and plenty big enough.
:D cheers :D
Hey
Can you work out the ACL one please? i got ACL pistons on in mine and when i do a compression test it sits at 120 in each cyl. the numbers on the top are
RA9608x 0.50 RIB 0.10 SE
Id like to know how low it is - i dont know if these are VL turbo ones or not - they do sit right up to the top of the block though. here is some pics
CP
All compression ratios are based on zero deck height, 1.2mm head gasket (7.13cc), RB25 @ 62.5cc, RB26 @ 64.5cc. They assure me they have done alot of work to make sure the facts are correct.
p/n= CP-RB30/26-.20
Flat top with no valve pockets
8.2:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
Only stocked in 0.20 thou oversize but can be custom ordered in any size.
p/n= CP-RB30/26-.20-9.0
6.0cc dome top,
9.0:1 COMPRESSION RATIO with RB25 head and bit less with RB26 head
21mm pin
*Care must be taken when using on RB26 with more than 11.5mm valve lift*
ARIAS
Suit RB30/26
p/n= AP332103
flat top
21mm pin
Suit RB30/26
p/n= AP332104
10.6cc dome top
21mm pin
COMPRESSION RATIO 9.2-9.4
Suit RB30/25
p/n= AP332105
13cc dome top
21mm pin
COMPRESSION RATIO 9.5-9.8
WISECO
K577M865 86.5mm
K577M87 87.00mm
ACL
6MKRY9608 (VL turbo)
87mm, -4.5cc dished top, 1.261" compression height, 21mm pin,
Standard RB30ET pistons are 7.8:1, with RB25 head it is 7.1:1
These are bumped up to 8.5:1 so with the RB25 head it may give about 7.5:1??
Using http://www.csgnetwork.com/compcalc.html I came up with 8.5 for VLT (spot on) and 7.6 with twin cam head with 64cc chamber.
I entered: 2, 87, 85, 87, 1.2, 64cc, -4.5cc = 7.6:1
BUT these have a lower compression height than the CP/Arias and im sure it stuffs up my calculations but its late and im too tired to look at it any more... :D
yeah - you'd have to cc everything and then work out how much to take off the head to get the comp your after.
Higher comp gives better off boost respose, better fuel economy and if your tuner is good ( I know your tuning it - so no offense implied :D ) you should be able to make good power on lower boost.
Mine has no detonation at 18psi on 100 Shel V power, and Im hoping to run 22 plus psi.
after talking with steve from QRI he told me that for mainly street with occassional drag the p/n= CP-RB30/26-.20-9.0 would be the best ones to go for as with the rb26 head comp would drop down slightly which is where id want to go... ill just be using total seal gapless rings, as we've used them many times on other cars and prefer them
ben...
The motor is 95% complete.
Rocket/ARIAS are pretty much spot on when they say the AP332104 set makes 9.2 - 9.4:1 with a stock head, I calculated, it to be 9.3:1 based on 63cc bowls.
My R33 25 head has been resurfaced at least twice so when cc'ing the bowls they came to 58CC's, with a (1.3MM) stock head gasket the CR for my motor came to 10:1 comp.
I'm aiming for 9:1 so I'm looking for a MLS headgasket almost double standard.
The thickest I've found so far is this:- CMC4323-074 Cometic - Multi Layer Steel Head Gasket
Rb30det 3.0l 87mm Bore .074"(1.88mm) Thick. Which would make 9.5:1 comp.
At the moment the other option is to have one custom made. :)
Edited by Alf
Mines an interesting setup. :S
I run the Wiseco RB25 pistons with a supposive 14cc dome and 1.240" pin height. 0.051" Cometic Headgasket 62cc combustion chamber.
The rods have been resized etc. Unsure how this will affect how the piston sits in the bore.
The engine builder said he was decking the block 0.040" due to the rb25's lower pin height. (1.240 vs 1.280)
If the block has been decked 0.040" which would result in an expected 0deck height then that would achieve a comp ratio of 10:1. :S
But I'm sure thats not the case as all cylinders only have ~154psi and have done so since day one.
If the deck height is 0.040" that drops the comp ratio down to ~9:1. But still 154psi for 9:1? Sounds a little low. BUT the stock rb25de n/a cams will be bleeding a little of that compression off as they do run a little more overlap compared to stock turbo cams.
Either way my tuner believes the comp is down around 8.5:1 ish according to the amount of ignition he runs vs boost level and power.
So who knows lol. :S
It does return excellent fuel economy though. Local short trips etc i'm getting mid 10's to low 11 litres per 100km's.
It does feel a hell of a lot more responsive than a mates GTS4 rb30det BUT that is running a much larger turbo, 250kg odd heavier car + my head has had quite a bit of porting/polishing and valve deshrouding done all of which helps.
Kastin,
You are correct, as I said in my post cam shaft specs (overlap etc) influence the guage reading/dynamic compression.
So given 2 cars with identical static comp ratio's and identical cam shaft specs both 'should' read near identical on the same guage.
I'm interested to know what radiator, fan, mods to reduce heak soak etc... you guys use for your 9:1 +15Psi motors and how well is the heat controlled in traffic and when giving it some stick.
I'm paranoid as it is with the stock rb20 in peak hour traffic. :)
This is what I've got planned for mine:
Ceramic coated and dry lubed ARIAS pistons :- done.
Ceramic coated valves :-done.
EF twin 12" thermos :-done
19 row oil cooler with thermo fan :-done.
Alloy double pass radiator :-coming soon.
Breather tank : coming soon
Mod inlet manifold for 3 extra coolant lines. :- coming soon
http://www.skylinesaustralia.com/forums/up...9_514_47789.jpg
http://www.skylinesaustralia.com/forums/up...9_514_50972.jpg
Edited by Alf
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
