gday guys. im currently building an rb26/30 for my vl turbo, i will be using an autronic and a 1000hp ta45 turbo.
Just wondering which pistons to use? If I buy CP forgies that come in 9.1 comp ratio it should drop to the perfect
comp ratio once the head is on yeah?
also, do i need to run the oil squirters?
thanks
brad
Fair enough, i stand corrected
Just assumed a 20yr+ old motor would be more prone to failure, especially when almost every VL in the country has been flogged to death :dry: .
i've heard stories that the old school v8 boys looked for 300,000km+ blocks for thier mega hp builds, and wouldnt use fresh, new blocks, because the old ones have been well seasond and the like, dunno how true that is though
I thought that was due to holden putting an inefficient and undersized radiator in the vl...while nissan actually knew what they were doing...hence why vls have overheating problems and the r31 didnt....is that true?...i actually heard that from several holden nuts!
R31's still cracked the sohc heads. BUT it was less common as their cooling system was just that little bit better.
Just a design flaw of the SOHC head.
Overheat our DOHC heads and its very rare to crack one.
nah, they just become pourus and bend...:)
I thought it was due to the fact that the VL radiator sat lower than the top of the head where as the R31 didnt ?
This leads me to my next question:
As the head is sitting an inch higher, is this going to cause problems; just like the radiator issue in the VL?
Do i need one of those custom remote radiator fluid reservoirs, thats mounted higher in the engine bay?
Don't loose sleep over it. The head sitting higher than the radiator isn't a problem providing its bled correctly + I don't believe its anywhere near sitting higher than the radiator, those big rocker covers pump it all up to make it look like it sits higher.
The SOHC head cracking is simply poor head design.
If the SOHC gets a little too warm the heads crack.
R31's have a better alum. radiator that keeps things cooler, a better more open front end that allows more air to the radiator.
VL's biggest and most common problem these days is the radiator's baffle design that rusts allowing water to bypass the core; as a result they get warm and crack. Then there's also the failed viscous fan that fails; temperature creeps up and bang cracked head. Of which also applies to the R31's. I've seen a few also have blocked coolant passages in both the block and head/plenum/inlet. All of which are age/lack of maint. related. :D
Do a little google..
http://www.google.com.au/search?hl=en&...acked&meta=
Fear not, its just the crapo sohc head design; aus market... chances are it was a rushed job, why sink the development $$ in to a market that is so small. :(
yeah it was a pretty restless night. couldn't believe how quickly it caught, ran and idled smoothly - pretty much straight way, with instant pressure. at least if it's a dog on the dyno I can turn it into a giant water pump and use the RB26 to run it. just got to concentrate on the niggly things that are bound to arise. last night was filling it with coolant, then heard it hitting the floor - thinks oh fark what's that - and it was the banjo that goes into the block - about .5 of a thread too long and the washer didn't seal. running long dumps so getting it out was a bugger, but an hour later and with some judicious application with a hacksaw no more leaks.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
