202-4207 to suit RB26...
Yeah i will fit it out with the arp gear down below. Better safe than sorry :)
awesome, exactly what i've done :P
it's going to be interesting to see how long my bottom end hangs together for with the 8000rpm abuse :(
I was going to cap my rpm around the 7000 mark. I will wait and see how the turbo goes and see what the engine builder reckons as well. I felt bad revving my RB20 to 8000rpm... I just don't like big revs.
With those cams and if you run a shorter runner plenum it will most definitely want to keep making power past 7k well in to 8k. :(
I have the std GTR plenum.. ok i may be willing to rev to 7500 then :P
all you need is to not run an internal oil pump. 7500 internal, if external go 8 or 8.5 if it keeps making good power. If power dies off, then no point running the extra rpm obviously.
+1 for dry sump :action-smiley-069:
mine has std cams and inj, with a pfc and exhaust, and R34 N1s, and was still climbing at 7000 when we stopped it. 267 rwks @ 10psi.
I've found the biggest influence over where peak power lands and how power holds after peak is to use a shorter runner plenum the the std rb25 item. i.e GTR. Already being a gtr head = ftw.
Even the Rb25 head with its std cams is able to makes its peak close to 7000rpm and holds power basically flat without drop off until a shade over 7000rpm then by 7500rpm its begins to smoothly drop off.
Std runners/plenum power peaks and then drops off hard.
Mine with the port matched inlet and plenum, port matched exhaust manifold, mildly ported r32 rb25de head, valve deshroud and gt30 .82 iw made its peak 268 @ 6000rpm 15.5psi BUT it does drop off fairly hard after that. By 7000rpm its making 252rwkw. So 16rwkw over 1000rpm.
No point reving past 7000rpm BUT it does pull to 7000rpm comfortably.
Yes. :action-smiley-069:
With peak landing at 6000rpm I'm fairly happy with that so first up is a set of cams and then exh manifold and WI. :P
BUT.. I am running the GT3076 so it will most likely run out of air. They have pushed 320rwkw ish before so with WI I'd hope I could squeeze another 30rwkw out of it.
Surprisingly no boost creep BUT I do have next to no preload placed on the actuator to make use of all its travel. As a result the actuator is super lazy but it still makes good power in the early rpms despite. With the boost controller on it with my current tyre setup third gear was useless from 60km/h. :S So some work in that department also.
We found that descent suspension really helped...going from jap teins to Sks setup, some good shocks and matched springs really helped reduce wheelspin and got the power down. Suspension that actually lets the car squat can make all the difference even with poor rubber.
Looks like your well on the way to power town mate.
Joel you forgot to PM me the dyno results, and to give me a brief update :rolleyes:
Just reading what you have posted sounds awesome!!!
what is WI ?
Michael: What Teins did you have? I have just changed my suspension from "Hot Bits" to Tein-Super Streets (from Fulcrum-revalved for Aus. roads/conditions) with EDFC.
shit...i cant remember...they were your usual imported crappy shocks with super super super super stiff springs. For some reason 'HR' is sticking in the back of my mind, if that means something, possibly model or type. I think it even had street written on the sticker somewhere. Worst suspension ive ever seen.
Al....wi is codename for people in the know around here...those who have used it or are planning on using it. haha its water injection :rolleyes: Sorry i had just finished the bourne ultimatum before i came on..haha
Edited by r33_racer
TEIN HR are the height adjustable setup from a few years back - Jap spec run about 12kg springs
im running the HA with the damper adjust - super stiff with that range springs ... too stiff but still usable
chris i can assure you that for circuit racing they are by no means usable. Even with semi slicks or full slicks...hopeless.
Wait a sec...our teins had the damper adjustment screw on top too...maybe they were HA??? But they were also height adjustable.
Yep i understand that completely - HA are height and damper adj.
never had as much trouble shifting weight than with these things, but i had tannabe's in prior to these that were just as bad or worse.
been tossing up between the new super streets from Tein or the shocks and springs in the SK package.. cant decide :D (need new strut tops either way and the SK package dont supply them :O )
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
