we got sks package and then i pinched the tops off the teins and used them since they were spherical bearing, not rubber.
Before we changed to SK's deal, we put softer springs on the teins, and i must admit that helped a little bit but it was still stiff...which led me to believe that the shocks were still crap in terms of their valving, from them to the SK's was a massive improvement all round. Had to play with spring rates abit, but nothing too major. However the aussie spec ones seem to be loads better over the jap ones.
We are way off topic here, talking suspension in rb30 country.
Edited by r33_racer
A question for the guys that have been driving around with the RB30 hybrid motors....
Have you had any problems with the bottom end strength ??
I have been told by 2 experienced RB26 mechanics (one worked in Japan for Nissan) that the RB30 bottom end wont handle high boost and is the weak link. I'm not sure if this is just because they are RB26 biased or if its in fact true...
It wont stop my build, i'm just curious.
lol; no. Which has reminded me; its time to update it. :)
The blokes are Boostworx are top blokes; always done the right thing by me from the start so its well deserved.
There's so so many workshops out there that simply do not give a sh*t.
ok guys i need help im only a newbie....
i am currently rebuilding the rb30/25 to put into a lh torana 4 door.
i have read the first 86 pages in the last 2 days and i just need to ask one thing...
i am going to buy a rb25de engine for the head and bolt on acc, though can i use the non turbo loom in a turbo application with a power fc?? or should i lok at buying a rb25det wiring/loom for ease and better use.......
HELP!!
I am 90% sure you will need a turbo loom due to the knock sensors.
you may be better off looking for a power FC first and buying the correct loom for it.
it really depends on wich RB25DE head you are using 33 or 32.
if it was me I would buy a R32 re25de and use an R32 rb20det loom with an ap engineering pfc.
the loom and ECU will dictate wich CAS, ignighter and injectors you can run, once again in my opinion the r32 loom will be better as you can run top feed injectors.
Those of you with GTR's and or using GTR looms.
The knock sensors.
GTR
GTST
The GTR knock sensors don't screw in to the RB30 block as the thread dia of the GTR's bolt is too small.
What have you done/easiest way to sort the issue?
Brass piece chopped off and then drill/tap that brass piece to suit the GTR knock sensor bolt?
Or isn't there enough meat/difference in thread size to do such a thing?
i was goin to use a r33 rb25de engine for the conversion, tho im waying up weither to just buy a rb26dett head??
the only thing is price...
i was going to use the rb25de head with rb25det springs and maintain the vvt...
even though i get the de loom with the engine i will probably just hunt down a rb25det r33 loom or can i use the r32 rb20det loom???
cubes, i havent got to the knock sensores yet though what do u think would be the best approach as u have done it all....
thanks guys!!!
The knock sensors.
GTR
GTST
the bosses are there - on mine anyway - you just have to drill and tap them. the GTROC thread where R32 Combat / Andy shows his rebuild has good pics.
The knock sensors.
GTR
GTST
im not running them, simple lol (autronic SM4)
cheers champ.
Just a question before i buy it, am i able to use a rb25de NEO head??
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
