well it took me 3 weeks but I have just finished reading this whole thread. damn what a novel...
I had a bit of a busy weekend and the RB30det is well and truly under way.
I pulled the RB30E out of the R31 and stripped it down and removed the head. Stupidly i forgot to loosen the harmonic balancer before pulling the motor.
the engine has been rebuilt recently there are hone marks in the bores, pistons look like brand new no carbon, head gasket and timing belt aftermarket and a new tensioner :D so happy times! no piston slap and all in really good condition. I am going to use the bottom end as is.
the head RB25DE R33 is also in excellent condition and will be used as is. the springs are the same as R33 turbo ones. I have drilled and tapped a new feed for teh VCT. a M10 x 1.25 thread. I have also blocked the original gallery with a M8 x 1.25 once it was drilled and tapped and used locktite.
I am using the 149 teeth dayco belt with 2 tensioner s in the standard position.
things i need to know is.
1. where the hell have u guys got your oil supply for vct fittings? every car parts place i went to did note have 1/8 npt fittings. not even pirtek!
2. What is the best way of getting off the harmonic balancer and flywheel bolts? I am guessing a rattle gun? also what size is the ballancer nut? 26mm spanner JUST to small. 28mm to big? is it metric?
3. what is the best way to remove the current engine and transmission. I removed the gearbox and motor from the R31 in one piece with a crane and it wasn't to hard. but i did cut the front of the car off first :) am i better off removing the gearbox before i take the motor out? I am guessing putting it back in in one piece will be a hell of a lot easier.
I am hoping to have it all in and started in a month. so far it has been plain sailing. this is the biggest project i have undertaken yet and i am taking my time, my power goal is only 250rwkw. this is the maximum the turbo will supply anyway and I think that is enough in a responsive r32 with torque.
any help appreciated :)
cheers dudes!
CEF11E,
I bought a 27mm socket and used the breaker bar; it was on damn tight I can't see you removing it without the motor being in the car with a gearbox hooked up. I have used a rattle gun in the past; worked well but it does have to have some balls behind it.
When I dropped the RB30DET in I removed the rb20det with gearbox attached; bolted the gearbox to the rb30det and slid it in.
This was done over a pit which made life a lot easier.
Radiator was obviously out and had a piece of wood protecting the a/c condenser.
10mins max and the motor was in position. Ahh exciting times it was. :)
2GUUP,
I've never ran with 2 down low but even with 1 low 1 high the belt is really tight to get on. Near impossible. If I were to do it again I would position the tensioner 1mm towards the centre more.
To get mine on I have to position the cam belt with the lower tensioner loose and then slide the top tensioner on. There was no way I was able to slide the belt on with the tensioner already located in place.
BUT once all on the belt still had a little too much slack which required slight pinching up.
whos done the low low tensioner setup
ive got an issue with my belt tension
its seems really really tight
ive got two tensioners in the stock position
and the dayco 149 tooth belt
mate i tried it, as far as i'm concerned it doesn't work properly due to the belt being overtight. made all sorts of measurements and turned up a dummy pulley out of plastic to see if i could get an idea of what measurement would work with a 149 tooth belt and 30mm diameter seemed right. looked everywhere for that diameter tensioner but none of them were up to the load rating. suffice to say one tooth makes a ridiculous amount of difference to the pulley diam and a 150 tooth belt had so much slack that there was bugger all clearance left when it was tensioned.
it was 'pain in my a$$holes...'
even had the NSK bearing tech guys looking for me but they couldn't find anything either so in the end i went with the hi/low setup.
I think you mean 1mm further away from the centre to add a tiny amount of slack. Using the guide measurements mine is in the perfect location without having to tension the belt using one tensioner high and an idler low. When I install the belt I use a high tensile bolt instead of a stud and just locate the tensioner and start threading the bolt. Makes for less offset tension in the installation but the bolt does need to be well prepped with a quality thread sealer tape.
hey guys does the rb25de neo head water/oil galleries line up to rb30 bottom end??
despite vct though coz im going to keep it...
HELP!!
Mate, not everything has to be a massive drama so take it easy, think and do some more reading. Sure there is a lot to get through but it's worth it. spoolup is running a neo head so they must line up reasonably well.
How about get a head gasket and overlay it to see if it will line up?? Take photos and post them up to add to the knowledge base while you are at it.
cheers mate.. ive decided to go with an injected turbo 202 instead.. lack of funds.. should still get about 400 hp at the wheels though...
im going to keep my s2 block though to do this in the near future...
thanks for all your input, AWESOME thread guys!!!!
keep it up!!!
Guys quick question, my engine was built by Ricol Automotive and it looks like they've re-used the original RB30 oil pump. Since ive got the engine on a stand I figured I might as well bolt a new one up, but realise its too late to fit a crank collar. The RB30 oil pump from nissan is $1000 (just priced one) Can I fit an N1 pump and will it be ok providing I dont exceed 7k rpm?
if you use an n1 oil pump, change the relief spring to a std rb25 one or rb20 one. Something that runs a lower relief pressure, the n1 pump will provide way too much pressure and you will suffer like cubes said.
Edited by r33_racer
Only standard restrictors unfortunately :)
If you haven't got litres of oil in your catch can you don't really need the restrictors, just over fill the sump a bit to ensure a good supply of oil.
People have spoken of the n1 pump being brittle and more prone to damage by bad harmonics, so the n1 would probably break before the rb30 pump. A few people on this forum run rb30, rb25 without a crank collar, I think the rb30 pump will be fine for 7000rpm or maybe just put an rb25 one in, due to it having less age on it.
Edited by BAMR33
What have you done with regards to oil restrictors?
The N1 pump with std restrictors is a bad thing.
what size restrictors do you recommend? Ive got an N1 pump with collar & ATI balancer, I havnt got any restrictors yet. I have removed the old ones. why change the relief spring?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
