Adriano Posted September 10, 2007 Share Posted September 10, 2007 Wrong. The best choice is the one that suits your car (unless you have a 19th century technology R31 or earlier). Then you work around that. I have the 26/30 in the GTS25t with 26 plenum and throttles and TT's and run it all with the 25t PFC, and the only sensor changes were the z32 and the water temp sensor since the 26 sensor maxes the temp signal. Even as a TT I have it set up for single AFM. I also have a single O2 sensor at the split pipe join. If you have to use twin AFM's then you can wire it to supply an average input from the sensors. Cummon geoff, how is an s15 PFC going to run an rb30, just cut two cylinders off? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3338171 Share on other sites More sharing options...
GTRgeoff Posted September 10, 2007 Share Posted September 10, 2007 Good point, but I thought we were talking about cars and not silvias and the like..... Could be a bit of a pig to splice in, but that's the fun of it. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3338199 Share on other sites More sharing options...
shanef Posted September 10, 2007 Share Posted September 10, 2007 Good point, but I thought we were talking about cars and not silvias and the like..... Could be a bit of a pig to splice in, but that's the fun of it. admit it geoff, u farked up typical victorian Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3338206 Share on other sites More sharing options...
[200] Posted September 10, 2007 Share Posted September 10, 2007 So the head is from an R33 GTR, so I'll buy a Power FC for that right? The motor I got also comes with a loom so it should make it easy. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3338370 Share on other sites More sharing options...
Cubes Posted September 10, 2007 Share Posted September 10, 2007 Buy the Rb26 PFC. You can have it running single afm if you wish; once the power gets up over 350rwkw+ jump to twin afm OR I believe some sort of other maf that Adriano mentioned in another thread. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3338425 Share on other sites More sharing options...
[200] Posted September 10, 2007 Share Posted September 10, 2007 It will definately be running twin turbos. GT3240's to be precise. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3338457 Share on other sites More sharing options...
CEF11E Posted September 10, 2007 Share Posted September 10, 2007 it was tight as shit to get onbut once it was on and we loosened the tensioners it sat nicely tightened everything up and shes perfect As stated earlier the head is on, cams are in, water pump, oil pump and tensioners are in. I ended up buying new RB30 tensioner studs from nissan. the guy asked me why I needed 2 and the conversation ended up with the dude being very confused :0 till I said think 3 litre RB25 Same results here with the RB25DE R33 head. it was a bastard to get on but now it is on the tension seems fine. you can just twist the belt 90deg. I also read back something on cam journals seeming really loose. I have tightened mine up to 13.8nm. that is as low as my torque wrench goes. the specs say 9 to 12nm. is this going to be too tight? the cams will turn with some resistance. not much more than if there was 2nm holding the journals down. Also fitted new rear main seal tonight. that was a bastard to get out. the old one was caked in there pretty good and its a tight press fit to get the new one it. but its all done. The head I bought was a complete head that had been dissasembled and now I am getting down to the last few things I am starting to find little bolts here and there are missing. no biggie but i now have to find a few difficult parts. 1 cam journal bolt and washer 2 VCT cam wheel cover bolts (tiny m4? bolts) 1 exhaust cam wheel bolt thats about it. soon as I have those bits she will be a complete engine. I would really like to start it out of the car but I don't have a spare loom. Can't wait to get it in there. Bastardized R32 GTS FTW!!! If any of you guys have any of the bolts i need lying around please let me know Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3339167 Share on other sites More sharing options...
Al Posted September 10, 2007 Share Posted September 10, 2007 admit it geoff, u farked uptypical victorian Trust me Geoff is no typical Victorian Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3339319 Share on other sites More sharing options...
r33_racer Posted September 10, 2007 Share Posted September 10, 2007 bloudy mexicans! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3339761 Share on other sites More sharing options...
Scooby Posted September 10, 2007 Share Posted September 10, 2007 (edited) So the head is from an R33 GTR, so I'll buy a Power FC for that right? Geoff's head is from Victoria. You can't buy a PFC for it, goes well enough without anyway. Edited September 10, 2007 by Scooby Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3339774 Share on other sites More sharing options...
CEF11E Posted September 10, 2007 Share Posted September 10, 2007 on topic FTW!!! I am in a bit of a dilemma with my turbo and would like some advice. I am going to use my sliding performance RB25 hiflow with my 30det and am well aware the exhaust housing is WAAAAY to small. it makes 240rwkw on my RB20 and I would expect it will make 250 to 260rwkw on my RB30det. that figure is pretty close to my power target but i imagine it will come on way to quickly and choke around 5000rpm. so I have been thinking about getting a bigger exhaust housing. something around .80 I have no idea on the internal specifications of the turbo as it is a hiflow. if I could get 260~280rwkw from this turbo with good response and not choking untill 7000rpm that would be fantastic. The reason I want to stay with this turbo is that it is new and looks standard. the whole car is built to look standard and i want to keep it that way. so an aftermarket turbo is out of the question. What sort of housings can fit standard RB turbochargers. Thanks! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3339889 Share on other sites More sharing options...
silver gts-t Posted September 11, 2007 Share Posted September 11, 2007 hey CEF11E i should have spares, not 100% but ill check pm me with wat u need (just in case i forget) and ill take a look As stated earlier the head is on, cams are in, water pump, oil pump and tensioners are in. I ended up buying new RB30 tensioner studs from nissan. the guy asked me why I needed 2 and the conversation ended up with the dude being very confused :0 till I said think 3 litre RB25Same results here with the RB25DE R33 head. it was a bastard to get on but now it is on the tension seems fine. you can just twist the belt 90deg. I also read back something on cam journals seeming really loose. I have tightened mine up to 13.8nm. that is as low as my torque wrench goes. the specs say 9 to 12nm. is this going to be too tight? the cams will turn with some resistance. not much more than if there was 2nm holding the journals down. Also fitted new rear main seal tonight. that was a bastard to get out. the old one was caked in there pretty good and its a tight press fit to get the new one it. but its all done. The head I bought was a complete head that had been dissasembled and now I am getting down to the last few things I am starting to find little bolts here and there are missing. no biggie but i now have to find a few difficult parts. 1 cam journal bolt and washer 2 VCT cam wheel cover bolts (tiny m4? bolts) 1 exhaust cam wheel bolt thats about it. soon as I have those bits she will be a complete engine. I would really like to start it out of the car but I don't have a spare loom. Can't wait to get it in there. Bastardized R32 GTS FTW!!! If any of you guys have any of the bolts i need lying around please let me know Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3340831 Share on other sites More sharing options...
Adriano Posted September 11, 2007 Share Posted September 11, 2007 on topic FTW!!!I am in a bit of a dilemma with my turbo and would like some advice. I am going to use my sliding performance RB25 hiflow with my 30det and am well aware the exhaust housing is WAAAAY to small. it makes 240rwkw on my RB20 and I would expect it will make 250 to 260rwkw on my RB30det. that figure is pretty close to my power target but i imagine it will come on way to quickly and choke around 5000rpm. so I have been thinking about getting a bigger exhaust housing. something around .80 I have no idea on the internal specifications of the turbo as it is a hiflow. if I could get 260~280rwkw from this turbo with good response and not choking untill 7000rpm that would be fantastic. The reason I want to stay with this turbo is that it is new and looks standard. the whole car is built to look standard and i want to keep it that way. so an aftermarket turbo is out of the question. What sort of housings can fit standard RB turbochargers. Thanks! AVO do a .86 ex housing to suit a stock rb turbo, but i think they are about $800 Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3341156 Share on other sites More sharing options...
CEF11E Posted September 11, 2007 Share Posted September 11, 2007 AVO do a .86 ex housing to suit a stock rb turbo, but i think they are about $800 I just found those and after a bit more looking I spoke to precision turbochargers. the guy was a champ. he told me he could adapt a garrett internal gate .86 housing to my turbo for about $700. that sounds pretty good. either that or sell my hiflow for $800 and put another $800ish towards a newie. bit it will not look stock. I know I am living in dream land but I want a responsive 400hp pop the bonnet stock looking R32 I think for now I am going to put the hiflow on as is and see how it goes. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3341232 Share on other sites More sharing options...
Cubes Posted September 11, 2007 Share Posted September 11, 2007 You could always have the GT3076r fitted up to the .86 garrett IW and have the RB25det comp cover machined to suit. Be sure to grab the .6 comp cover and spend an extra $250-300 on machining the std comp cover. At a later date when you get hungry for more strap on the .6 comp cover. I'm almost certain the .6 comp cover would cost more than $250-300 so often when the turbo shop offers a 'deal' to machine your comp cover in return to keep the garrett comp cover its not really a deal that is good for yourself. That would look stock and push 450hp. Aim for 450-500hp; I find mines starting to feel a little slow. Which had me briefly thinking; I wonder if its lost power. lol I really do think the GT3076 .82 IW feels perfect for the street; instant off idle response in first gear; no lag just a strong off idle pull. The dyno sheet really doesn't do it justice how it drives in the lower gears at part throttle on the street. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3341362 Share on other sites More sharing options...
Godzilla33 Posted September 11, 2007 Share Posted September 11, 2007 who's using an ATI RB26 balancer? question I have is weather you can get away with using the std RB25 power steering pump/pulley which is only 3 grove belt with the RB26 harmonic balancer using 4 grove pulley. I know the std pump needs to be spaced forward roughly 6mm, anyone had success with this or do you have to have a 4 grove pulley?? anyone made up a pulley for the RB25 pump? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3342233 Share on other sites More sharing options...
Alf Posted September 11, 2007 Share Posted September 11, 2007 Is there any noticeable difference to the VCT when using an N1 oil pump with the 33 vct head? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3342546 Share on other sites More sharing options...
CEF11E Posted September 11, 2007 Share Posted September 11, 2007 who's using an ATI RB26 balancer? question I have is weather you can get away with using the std RB25 power steering pump/pulley which is only 3 grove belt with the RB26 harmonic balancer using 4 grove pulley. I know the std pump needs to be spaced forward roughly 6mm, anyone had success with this or do you have to have a 4 grove pulley?? anyone made up a pulley for the RB25 pump? I have used a balancer with 4 ribs for power steering and only 3 ribs on the p/s pump. it does work fine but took a while to get it right (3 power steering belts) It does not come off even at extended 7000rpm use hope this helps Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3342764 Share on other sites More sharing options...
Godzilla33 Posted September 12, 2007 Share Posted September 12, 2007 I have used a balancer with 4 ribs for power steering and only 3 ribs on the p/s pump. it does work fine but took a while to get it right (3 power steering belts) It does not come off even at extended 7000rpm usehope this helps Sweet, Thanks! I was thinkin it would be as long as it lined up spot on, thought id see what other people had done/doing. Guess I can only F@#k it up!!!!! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3344360 Share on other sites More sharing options...
fatz Posted September 14, 2007 Share Posted September 14, 2007 quick one kids spool rods and cp pistons $2090 are they any good kids??????????????????? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/277/#findComment-3349409 Share on other sites More sharing options...
