r33_racer Posted September 21, 2007 Share Posted September 21, 2007 yeh -10 weld ons and then 90 degree fittings have cleared. Shouldnt be a problem chris. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3366255 Share on other sites More sharing options...
CEF11E Posted September 22, 2007 Share Posted September 22, 2007 Where have you people who are using R33 heads been plumbing you oil return pipe from the front right hand side of the head? do you get a "T" peice and blumb it into the turbo drain into the sump? cheers Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3366938 Share on other sites More sharing options...
Craved Posted September 22, 2007 Share Posted September 22, 2007 yeh -10 weld ons and then 90 degree fittings have cleared. Shouldnt be a problem chris. Perfect news Michael, cheers mate Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3367044 Share on other sites More sharing options...
CEF11E Posted September 25, 2007 Share Posted September 25, 2007 After a lot of hard work and long nights my RB30det is now in the car. I have spent a few hours tonight trying to get it started and have not got there yet. this is frustrating Fuel pump working - check. CAS working - when i remove it and rotate it with the ignition on the injectors click and the fuel pump turns on everything is wired up bar 1 plug on the AAC valve. the r32 loom has no provision for it. I am still working out the best way to test spark. any ideas? I have had to use R33 turbo injectors and it involved cutting up the original loom and grafting in the plugs but I have done it before for GTR injectors and no problems. the motor turns over fine just does not start when the crank is set to o deg btdc the cams line up with the locator pin marks perfectly. so its fuel or spark i am missing or some electrical gremlin somewhere. if anyone has any ideal please shoot them my way. my goal was to have it running by tomorrow night. so so tired... Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373458 Share on other sites More sharing options...
Cubes Posted September 25, 2007 Share Posted September 25, 2007 Get a timing light on it and crank her over. Will soon tell you if you have a signal from the ignitor. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373465 Share on other sites More sharing options...
sky30 Posted September 25, 2007 Share Posted September 25, 2007 After a lot of hard work and long nights my RB30det is now in the car.I have spent a few hours tonight trying to get it started and have not got there yet. this is frustrating Fuel pump working - check. CAS working - when i remove it and rotate it with the ignition on the injectors click and the fuel pump turns on everything is wired up bar 1 plug on the AAC valve. the r32 loom has no provision for it. I am still working out the best way to test spark. any ideas? I have had to use R33 turbo injectors and it involved cutting up the original loom and grafting in the plugs but I have done it before for GTR injectors and no problems. the motor turns over fine just does not start when the crank is set to o deg btdc the cams line up with the locator pin marks perfectly. so its fuel or spark i am missing or some electrical gremlin somewhere. if anyone has any ideal please shoot them my way. my goal was to have it running by tomorrow night. so so tired... What ecu are you running? If aftermarket, what was it previously tuned for? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373554 Share on other sites More sharing options...
CEF11E Posted September 25, 2007 Share Posted September 25, 2007 I am using the following bits RB30E bottom end RB25DE VCT head from an R33 - removed VCT solenoid and used the hole to feed oil to the head - stock plenum R33 R33 injectors R33 AAC valve R33 tps, (all sensors on the head are R33 R32 CAS R32 ECU remapped to suit the 370cc injectors Will try the timing light tonight. hmmmm wake up at 6am go to work finish work at 4pm. go home work on car till 1am. sleep for 5 hours - repeat for 3 weeks... damn i am tired... Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373561 Share on other sites More sharing options...
GTRgeoff Posted September 25, 2007 Share Posted September 25, 2007 AFM connected? Either that or the timing on the CAS is well out. Try the timing light. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373607 Share on other sites More sharing options...
shanef Posted September 25, 2007 Share Posted September 25, 2007 car should start with no afm, it'll just run like a pig and stall etc etc lol it could be that ur battery isnt supplying enough juice have u checked to make sure theres fuel getting to the rail? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373685 Share on other sites More sharing options...
shanef Posted September 25, 2007 Share Posted September 25, 2007 also check that the cas plug is actually plugged in properly, not just sitting over the cover Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373691 Share on other sites More sharing options...
CEF11E Posted September 26, 2007 Share Posted September 26, 2007 thanks dudes pulled the timing cover off and made sure the cas key is correctly set to the cam key. the afm is plugged in and there is fuel getting to the rail. I am starting to think it is of 2 things. 1. there is no spark. because i have tried advancing and retarding the cas and no difference. and i can hear the injectors pulsing. 2. I have buggered up the injector firing order while making the new injector loom. this wil be a bastard to diagnose and will mean pulling off the plenum again. I will make sure i am getting spark tonight. also battery would be going flat but seems to turn over the motor fine. I am sure it is something silly. it will get there. Also how long should you have to turn over the motor with ignition disconnected to get oil pressure? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3373852 Share on other sites More sharing options...
r33_racer Posted September 26, 2007 Share Posted September 26, 2007 who knows...pull off your oil feed line to the turbo and let it spit into a bucket for a while and then hook it back up. Once it spits abit out of the line there should be oil pretty well everywhere else. It doesnt take long for it to work its way through the motor. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3374125 Share on other sites More sharing options...
mr_rbman Posted September 26, 2007 Share Posted September 26, 2007 may sound silly but a similair thing happened to me on my first start up that cubes will remember, haha! It just turned out that my fuel lines were the wrong way round where they connect near the plenum! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3374580 Share on other sites More sharing options...
Craved Posted September 26, 2007 Share Posted September 26, 2007 may sound silly but a similair thing happened to me on my first start up that cubes will remember, haha!It just turned out that my fuel lines were the wrong way round where they connect near the plenum! HAHAH ive done that before Dash lights are all on when cranking? you can also try the carbie cleaner trick in the TB then crank, if it coughs like it wants to start, then you have no fuel and do have spark. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3374713 Share on other sites More sharing options...
CEF11E Posted September 26, 2007 Share Posted September 26, 2007 Well she is in and running rough as guts but running... mr rbman you my friend are owed beers just before you posted this this afternoon I looked at an RB photo and realized exactly what i had done. I then had to sit at work and look interested for the next 3 hours... race home swap them over and ALIVE! it will not hold an idle and misses loke no tomorrow but it is running. tuning and testing will commence in a few days I have had enough for now Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3374749 Share on other sites More sharing options...
Al Posted September 26, 2007 Share Posted September 26, 2007 Congrates CEF11E!! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3375040 Share on other sites More sharing options...
mr_rbman Posted September 26, 2007 Share Posted September 26, 2007 haha, thought your problem sounded far too familiar! Well she is in and running rough as guts but running... mr rbman you my friend are owed beers just before you posted this this afternoon I looked at an RB photo and realized exactly what i had done. I then had to sit at work and look interested for the next 3 hours... race home swap them over and ALIVE! it will not hold an idle and misses loke no tomorrow but it is running. tuning and testing will commence in a few days I have had enough for now Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3375548 Share on other sites More sharing options...
[200] Posted September 27, 2007 Share Posted September 27, 2007 I have a question re CP Pistons. I know they are off the shelf ones available for the 26/30 combo... Is there anyway that these can be customised to tolerate high horsepower / boost applications? I am going to more than likely get a set with a 22mm pin diameter. I've read that the rings can be moved down on the piston for high boost. Can someone give me some info about getting a set custom made? Also, dry sumps. Has anyone bought a dry sump for the RB30 motor? If so, where did you get it from and how much was it? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3377628 Share on other sites More sharing options...
Spoolup Posted September 28, 2007 Share Posted September 28, 2007 CP will make one off custom sets to order - the price is considerably more. You must be planning to make an immense amount of power as there are a lot of off the shelf CP's out there making spastic power. I have a question re CP Pistons. I know they are off the shelf ones available for the 26/30 combo... Is there anyway that these can be customised to tolerate high horsepower / boost applications? I am going to more than likely get a set with a 22mm pin diameter. I've read that the rings can be moved down on the piston for high boost. Can someone give me some info about getting a set custom made? Also, dry sumps. Has anyone bought a dry sump for the RB30 motor? If so, where did you get it from and how much was it? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3379242 Share on other sites More sharing options...
[200] Posted September 28, 2007 Share Posted September 28, 2007 Yeah I realise that. Just wanted to get a more technical opinion about the best way to get them customised. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/279/#findComment-3379303 Share on other sites More sharing options...
