Hey all just thought i would let you know after almost a year im going to be cranking my 30/25 build over tomorrow just a few wires to go and waiting for the tunner to come around and load in a map.
Thanks to all the guys that had imput into the guide and all the people that have answer my post fingers crossed for tomorrow
just some pics of what it now looks like
Thats a very nice looking engine bad you have there, goodluck with everything!
Just a heads up, I notice youve got a thermofan, but no shroud. I'll be doing the same, but pretty sure the shroud will be needed as the thermo only draws air through the immediate area it's placed against. I'll be mounting mine around 25mm off he radiator so the shroud acts as a funnel and the hole for the thermo fan as the exit point (for lack of a better description)
Can someone recommend me a good sump to use? I was looking at the Hi Energy Pro eliminator...
Contact Leigh from "Extreme Turbo Manifolds"
Tel: (02) 4262 8774
He is currently doing mine. Had to send him my sump, oil pick-up arm, and oil pump housing. The capacity is increased to 7ltrs, the oil pick-up is relocated to ensure optimum position and is surrounded by baffles, the oil pump is modified to suck oil from the right hand side (by removing the welsh plug and inserting a fitting). I will need to block off the factory oil intake, to the pump, in the block.
His manifolds are said to be top notch too :thumbsup:
Question... Using Autronic SM4 in my 33 GTSt (not fitted yet). Looking at my old computer/loom, what needs to stay??? Does the std ecu have to stay connected for a/c, dash, any other ancilleries or can I just cut the loom out all together? I seem to have other wires coming from my std loom going to wiper motor (and some other little orange box back there) not to mention that wires head back from the loom towards the fuse box etc. Anyone else have any of these issues when changing computers?? Cheers for any ideas.
Surely I cant be the only person who needs this info, anyone??
no you dont need the std comp for anything with the sm4, im pretty sure it can control everything you throw at it. If you havent already, go trade it in for the new plug n play version. Will save you a heap of hassle.
200 what sort of racing you going to be doing with your car to justify an aftermarket sump?
Nice build gemini90. Why did you keep the pcv valve there to the manifold? You should ditch it mate.
Nice plenum on there too, i wasnt aware hypertune made them for rb25's? If so, must have cost you a fair bit.
I was looking at a dry sump setup but after reading a few threads I went back to the wet sump idea...
Its my understanding that a hi-energy sump has a few baffles and a trap door in it... Maybe drilling and putting an extra inlet coming from the head might be ok...
I have done a basic run in tune for 10psi and have everything running smoothly.
At 10 psi it makes amazing power and is all in by 2800rpm with a slide hiflow that was making full boost on the 20det at 4000 rpm and it feels fantastic to drive. bucket loads of torque and throttle response is fantastic.
I have a few annoying things to sort out.
the water temp sensor from an RB25 does not work on a 20 computer. so i have to track a 20det one down.
one of the cam seals is leaking. bugger... covers, balancer, camgears, rocker covers, timing belt off to replace it. it is just a drizzle but it has o be done.
I have also had to fabricate some bits that i will replace with original bits further down the track,
I ran out of time and had to put the engine in with the original unmodded mounts. so the bonnet would not close. I removed the bonnet heat shield and cut out small sections of reo where needed and refitted the sheilding and it now fits with 3mm washers between the hinges and bonnet.
I will get the mounts lowered 10mm later and all will be good.
she looks stock as a rock and pulls like a cut bastard! hehe
the whole thing cost me about double what i budgeted (this always happens with conversions) but really was worth it.
I am moving to VIC on the weekend and will not get to tuning till I am settled but will be aiming for 270rwkw with instant response. its still a street car and needs to be daily driven so i am not going to crazy.
hey r33 racer
when i was welding the -10 fittings on the covers i was ment to weld up the hole where the pcv valve gose but i forgot
as for the plenum it is a hypertune one they dont make them for 25 yet but they will be soon
there not cheep but i think there worth the money i want to do some testing on it to see what there like against the greedy and stock items but as you would know its not a easy thing to go changing plenums
^^ I used a 25DE head out of an R32, almost identical the the 20 in terms of layout and sensors etc. Only problem encountered was when I snapped the water temp. sensor, the 25DE item made it run in cold start all the time. Had to robbed one off an R32 RB26 manifold and it worked a treat. Car is running on the 32 gtst ecu so it should be just as easy with the 20 pfc >_<
How do people in QLD go about having there rb25/30 legal? Im looking into building a rb25/30 for my r32. There seems to be plenty of people making big power on stock rb30's. What sort of stock pistons would you use in a rb25/30 to maintain the desirable compression ratio?
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
