How many ponies did it produce?
500 before it blew the welsche plug out, hasnt had full tune done since
How could that happen, unless the joiner is before the turbo (intake pipe)?
yeh intake pipe, the blue 90deg one in the pic
Has anyone seen a low mount tubalar manifold with external gate? I already have height clearances issues and am afraid a high mount manifold will exacerbate the problem :(
I realise that external gate on low mount will be pushing it for clearance down there but thought someone out there might have come up with a manifold design I can buy off the shelf :P
Has anyone seen a low mount tubalar manifold with external gate? I already have height clearances issues and am afraid a high mount manifold will exacerbate the problem :D
I realise that external gate on low mount will be pushing it for clearance down there but thought someone out there might have come up with a manifold design I can buy off the shelf ;)
Clearance on a low mount is not the only problem, you also have to consider accessibility of the bolts/nuts/hoses/etc for installation/fitment.
I really wanted a low mount manifold, but once i starting thinking about installation, etc. i decided to go high mount. Most high mount manifolds (if built properly) would have the turbo sitting below the level of the cam covers, so i don't think clearance is an issue; unless you're fitting a 800+hp turbo.
Only looking at fitting a GT35R and by clearance I meant for everything.. including ratchet and spanner access :P
The majority of the manifolds I have found when looking about have the turbo sitting a good couple of inches above the cam cover. If anyone knows of any specific high mount manifolds that aren't too high.. please, enlighten me :D
Only looking at fitting a GT35R and by clearance I meant for everything.. including ratchet and spanner access :D
The majority of the manifolds I have found when looking about have the turbo sitting a good couple of inches above the cam cover. If anyone knows of any specific high mount manifolds that aren't too high.. please, enlighten me ;)
I am using a custom low mount manifold with a garret 35/40 and 48mm external wastegate, it has clearance everywhere, but it is a bit of a tight squeeze.
I preffer the low mount for lower engine bay heat temps as the hot air can escape out the bottom of the car. All factory turbo setups are low mount, there is a good reason for this.....
Im making my own low mount, GT35R, Got my flanges all drawn in cad (as close to match ported as possible-RB26), & laser cut using 12mm plate for all 3 flanges & steam pipe bends. Will take some pics when I start it. Do have a spare set of flanges to if anyone is interested, also have the cad drawing to get more cut if needed.
bearclaw? is that the model one up from the cameltoe and two up from the mooseknuckle? (you know..."mooseknuckle, because cameltoe has an ugly sister") (sorry)
just ordered the ATI damper i've been umming and aahing about, $500 landed on special from Summit Racing in the US. best i could find was about $745 here, if anyone's interested get in while the dollar is flying high.
cheers
Edited by Scooby
hey wat throttle body do u run with the greddy style plenium ?
80 or 90mm ?
also for those with aftermarket comps do u use the MAF sensor ? or do i need a Q45AFM or a Z32 afm ?
also
i need to know what turbo + manifold i should get ? - high mount or lowmount in a R31 skyline.
internal or external waste gate?
i was considering this.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...A:IT&ih=014
but i was told to stay away from it ?
also going to be runnin tomei poncams.
80 or 90mm ?
also
i think the greddy style ones are for q45 TB's but you can get an adapter for a stock TB
and i would definately stay away from that turbo
Also for aftermarket TB's and fuel rails you can try Buzz Engines in Brisbane. They have done some nice work. http://www.buzzengines.com/
I need to get a decent fuel rail for the 26/30 as I'm running Delphi 680cc injectors and the O ring setup is not optimal with the GTR rail.
thats also something id like to make on our cnc's when they are up and running properly some billet fuel rails....im in love with these machines and they arent even setup fully and running...however next week they tell me!
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
    • Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst. I posted a link to them sometime in the last 2 weeks, I'm sure.
