thats good power but for that ammount of boost, i think there is somthing wrong, the motor doesnt even sound like its really opening up.... it sounds like there is no peak kick thru the rpm...
Den001,
The Rb30's require a larger turbo to obtain the lag and then hard ramp on to boost you are referring too.
That same turbo on the rb25 or 26.. lag lag lag bang kick in the arse. Its the nature of increased displacement. Boost is developed over a wider rpm range.
To clarify.. is that 652rwhp or fly hp?
I tend to agree, a 3L with a gt34r running over 30psi and only making 360ish rwkw?
Are you sure all 6 cylinders are firing?
cheers guys.
firstly fuel car is running shell v - power 98ron pump fuel.
second. it has 2 in tank tomei fuel pumps wired seperately to two relays.both relays are working and both pumps are working
we checked that plus fuel pressure is 3.5 bar too.
graphs i will put up when matt @ the racing line finally gets the car to run..
2.17 bar is not what i will run
the car is mapped for 1.5bar 590bhp/540lbs @ 5500rpm @ the fly
also 1.8bar 620bhp/585lbs @ 5500rpm @ the fly..
the graphs look like the evo graphs, torque and bhp follow each other to the top, car makes boost from 2800rpm climbs quick and steep from 3500rpm.redline at 7000
you are all right for that boost i would have expected 700bhp @ the fly and maybe 600lbs torque.cant understand why bhp is the same as torque.
when i get the graphs i will see more but at 1.8 bar it made 500bhp @ the treads which he says is 620 @ the fly..
bernie. any comments from you guys or tuners would help.
the electrical problem has got all the tuners baffled here.
if this helps the tuner, if you set the fuel map up say from 1000-5000 rpm and the afr goes from 15 at 1000rpm to 11 at 5000rpm, then let the revs drop back to idle. and do it again this time without altering anything at 1000rpm fuel is 20 and as you rev it up it goes up and down reaching 30 in some cases.>>>???? bernie
Edited by rockabilly
26psi.. 500rwhp so around 373rwkw + given its a 4wd dyno so saps just a tinny little bit more power out of the final figure.
Its close enough bah.. Only a dyno figure.
I'm sure it feels fast and will break 3rd gear if your not carefull. lol
What spec cams are you running?
With a s1 R33 25det VVT head can the bulky inlet cam gear be changed to an Rb20 or adjustable one and still retain VVT?
Reason being I'm trying to make it look like an RB20, ie cam covers, coil cover and timing belt cover.
Edited by Alf
the bulky inlet cam is the major part of the vvt, so you would lose vvt by removing it.
If you want it to look like an RB20, then find an rb25de and put all the rb20 dress up gear on it.
It is the cam gear on the inlet side that operates the VVT - so removing it or the camshaft itself will stop the VVT.
You can run a std cam in the inlet with a std cam gear or adjustable one ( so you can use the STD rb20 cover etc ) but you will lose the vvt option.
Den001,
i understand and agree with you totally, but look at the boost its running, thats big boost, for that amount of psi going thru the motor, you would think that the turbo would come into its own and it would be in its efficiency range by far..... have a look at the clip again... listen to the turbo ramping and then listen to the revs of the motor, there is not real much positive gain from the forced induction.... this is what i mean..
im not bagging the motor, it makes power, but the way it makes it is doesnt seem right, to me it seems like its a massivly decompressed motor obviously making the power but look at the boost its eating, it revs way to slow, it eats 2.1bar boost and all on 98 pump fuel.... this is the characheristics of a decompredded motor...
im building a 30/26 now, with 8.8-1 comp.. and i tell you when it comes on boost it will come on... and it will be a t04z with a 1.0rear.... and the aim wil be to make it rev like this machine....
http://www.youtube.com/watch?v=caoHNZFufHU
this is how the engines should be set up... rb30 have in my eyes a very good rod ratio... 1.8-1. if you car rev out a 26 so hard there is no reason why you cant do it to a 30... especially with a twin cam head...
Considering its only a 600hp turbo 650hp isn't a bad figure. http://www.turbobygarrett.com/turbobygarre...2R_714568_1.htm
man ive been missing out here. Gone a few weeks and everything happens. Nice power rockabilly, but thats alot of boost!
Old mate in NZ reckons he can rev out his twin cam 30's to 10k and reckons they will last.
    • Yes. This engine cost a very large amount of money to build. It's a Frankenstein necessitating lots of custom parts and lots of fabrication and fettling to get things like big ends to clear the bottom of the bore, etc etc. The rods and bolts were supplied by the owner. Hence why the rods were Chinesium. Some lessons need to be learned the (very, very) hard way, apparently. I was aware of the stories going back about that far as well. I just wanted to see if the reality was as bad as the fear.
    • Looks great!  The problem with that brace is nobody can see it!
    • Hi and welcome. What are you planning to do to the car or will you keep it stock?
    • https://windowmotor.com.au/collections/02-07-v35-nissan-skyline?srsltid=AfmBOorAnTNYaD1tXzczAKZFqnDkZy23WgPXNfVscyeRKHhVNkiaC-WH https://www.gumtree.com.au/s-v35+stereo/k0
    • Heaps of historical info on this, a quick Google gave dates back to 2012, all talk about identification markings, dimples, shapes of mounting surfaces, washers, that are concave or something to match the fasteners mounting surface, which ARP states that if the washer, if it uses a washer in its application, isn't the right way around, it can cause premature failure,  even if it was torqued up correctly with whatever lube is meant to be used There is even talk about getting the bolts Xrayed to check the structure, one was about some builder getting multiple sets of bolts, having them Xrayed, and picking from those results Nowadays identical "looking" fake parts, in identical looking fake packaging are everywhere, with all the markings and stuff, the only way you know they are not legit is Xray or when they fail I assume if you don't want fake parts, and don't have a Xray machine handy, is to get them directly from ARP in the USofA, aftermarket rod and head bolts aren't something to take for granted  Imagine building a big dollar build only to find you lunch it because of an inferior fake fixture let go 😫
