It appears that the Wolf actually has a lot more features than the pfc.
Here's a quick run down on the features of Wolf v4 plug in for the R33/R32.
Map/Maf Use.
Closed Loop.
Air temp - Fuel/Ign/Boost compensation
Engine - Fuel/Ign/Boost compensation
Boost can be set per 500rpm to what ever value you like, it can also be trimmed to according to tps/air temp, engine temp.
Rotational Idle can be setup by Steve from SST.
Map Switching
Its a good ecu.
Check out the couple of threads that compare the PowerFC to the Wolf3D.
cool about time there was another good cheap plugin ecu. The older wolfs were a little shit, but i've heard the v4's are good. Dunno how they go with fuel economy, heard the microtech uses more, and can't remember if i've heard the same about the newer wolf's
i plugged my PFC in.
BANG. New car.
Wheel spinnage.
awesome power increase.
and after the tune ?? well the tune got me 285bhp
I so love the drivability of the PFC and the hand controller graph views are just totally awesome.
Id suggest the PFC to anyone.
Microtech uses more fuel because it doesn't have closed loop.
i.e as GTST VSpec told me that in closed loop mode it runs up to around 18:1 where as the best you can get from a non closed loop car is what ever the base map is which won't be 18:1.. :D
The dipstick assembly is just an iterference fit in the block hole. If you genty twist it you can lossen it and carefully keep turning back and forth until it comes out. Alternatively you could use the correct size drift and tap it out of the block from below.
OK so how do i get the Crank timing pulley off then. NOT the Crank pulley, the one behind them, in front of the oil pump which the timing belt goes around. Does it come off with the oil pump, cos it seems that the pump is free from the block, but the timing pulley is stopping it and i dunno how to get that off.
Your help is appreciated.
same way you got the oil pump off... tap it off with a hammer. You'll need to take the little key out (the little metal bit that stops the gear spinning on the crank shaft). But have some wood between the hammer and the crank gear cos you don't want to damage the teeth.
My timing gear was seized on the crank as well, and i got a local engine builder to remove it for me, they just drilled small holes in the timing gear from the front, extending from the center of the gear out to the edge, and then just used a cold chisel to create a radial split in the gear, and off it came. obviously a new gear was required.
Have any of you bolted the RB26DETT head on the RB30E?
Im about to do that, I was just wondering if anyone knew the difference in compression ratio?
If the RB30E/RB25DE is 8.3:1, what is the RB30E/RB26DETT?
Apart from tapping the holes in the block is there anything alse that needs doing?
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
