So, are people actually going to answer the question, not give bullshit responses?
How exactly can you fit the RB25/30 into the R33 GTS-t WITH a strut brace fitted, and NO, I'm not putting on a new plenum.
Well if u actually were half smart, or even quarter smart, or had any brain at all, ud realise by now that all the info u need is in this thread, or in the pdf.
but because im not a c**t, ur only other option is to lower the engine by modifying the mounts
What Shane said. You will have to fab up lower mounts.
My setup still just touches at the front. So I'll be using the soft mallet to create clearance when some new engine covers go in. The primary reason I went 26/30 was to have the lower plenum as well as 6 throttle for the racetrack.
Also my machining including a head skim cost $1400 including full balance, fitting slugs, crank deplug and clean and full check then tapped and grub screwed. I used forged rods so no prep of those. It came cleaned ready to give a final wipe and assemble.
Hey man i went same setup as you, rb30/26, but my block cost me like $2300 had 2 re-line bore and all what u metioned, using Mahle forgies, spool rods, 7ltr sump, tomei oil pump h/v.
Any pointers about this setup, just finished block work...
its cost me 482 dollars to get my block preped still ahvent got it balanced as yet the preping of the block includes, acid diped/cleaned, crank machined, re-bored and honed and the edition of some new welsh plugs sending my stuff away now to get balanced and sending my head away for a rebuild cant wait till i can finally start it up :D
I think all this talk about a 1/2 in conversion is a bit of a concern. Firstly is is to M12, not 1/2 in. Secondly, you have to have a switched on engineer do the job on a mill, as its easy to stuff up. A lot of builders dont worry, as the ARP RB25 head studs are able to withstand a lot of cylinder pressure. I upgraded mine to rb26 arp head studs(M12 x 1.75), and am now regretting it. In hindsight, i think its really only necessary once you are looking at getting close to 1000hp
1/2 is just a general term, not sure you can buy imperial studs anymore anyway.
i work with a mill almost every day. i don't see why it's a big job? infact id go as far to say it's an easy job. although i am interested to why you regret doing it?
If you go through, and search for it, you'll find that it doesn't actually state HOW to lower it.
Everyone claims to "lower" the motor 15mm on the drivers side, 12mm on the passenger.
But, they don't say how or WHERE these measurements are from.
Is that nock 15mm off the bottom of the mount?
Is it make the engine physically sit 15mm lower (Which removing 15mm square off the bottom of the mount won't do)
How exactly is it meant to be done?
At the moment, after measuring a few things, I'm just going to remove the strut brace.
There are certainly more imperial stuff made than metric, I had a machine shop do mine with a mill, and the results are bloody ordinary. Unfortunately the size ifference between the two threads isnt a great deal, which can easily result in the thread not cutting cleanly. I just think for the ordinary person, the added expense, and the risk of damaged threads make it unnecessary when rb25 ARP studs do the job fine.
There would also be things like water temp sensors etc which would need to be swapped for the RB20 items.
I'm using the standard intake manifold for now, am building a custom out of a GTR plenum. If you are using a 25DET head then you have the option of Greddy/copy plenums, I don't have that luxury :D
Bonnet currently rubs slightly on the very forward corner of the standard intake plenum and barely on the timing belt cover. No modified engine mounts or anything like that.
do these types of things interchange?
I am going to try and run R32 RB25DE head with my R33 Power FC im guessing I need to change these sensors too? the coil packs will be fine wont they?
so far I have worked out i will also need to change some ecu pins around as the R32 had a different firing order
Edited by dano4127
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
