hey al yeah i bought a new rb25det stock balancer tho i didnt see the point going for an aftermarket version cause i wont be revving it past 7 thou revs anyhow, so will the N1 oil pump fit without modification and do u guys suggest going for an N1 water pump aswell?
It will fit but if you're removing the crank fit a crank collar for peace of mind.
Personally I wouldnt bother with the N1 water pump especially if its a street driven car.
Agreed..
N1 oil pump - good
N1 water pump - don't bother for a street car
can anybody tell me if there is a thead on here that explains how to run the vct/vvt
in an 30/26,and wat else to do to the block so i can boltit together.. and wat page? cant seem to find it and i realy need to get my head and block to the machinests
nz forums suck
cheers :)
I remembered seeing something about how to run the VCT/VVT setup with the RB26 head.
When I first saw your post, I could not find it becuase I did not search for NVCS.
http://forums.hybridz.org/showthread.php?t...;highlight=nvcs
Just wondering if anyone has run a Garrett GT3082R with 1.06 A/R non an RB30DET with an ext wastegate? As far as I can tell these should be somewhere in between a 3076 and a GT35R meaning a good trade off between faster spool-up and less boost dropping off in the high end.
http://www.gcg.com.au/Catalogue_Menus/Garr...ttbb_gt3040.htm
Rotorua Import Pro Shop (RIPS) - Crate motor,
RIPS Plenum,
Boost Worx Stainless Highmount,
Just Jap GTR Style 100mm Cooler
XR6 Turbo - GT3540 IW with the 1.06 rear
POWER FC
HKS Cam Gears
Tial 50mm BOV
Stock injectors for run in then changing to 800cc Sards
Bosch 044 and ARE Surge setup
It has come down to piston choice time. I am currently looking at the arias 9.2:1 and 9.5:1 CR pistons and i am trying to decide which set of pistons to go for. Aiming for around 350-370RWKW (mainly street use occasional track use) using a GT35R turbo. Which compression ratio would best suit my application?
After ppl's thoughts on running a 4 inch dump pipe (using a 4-3.5 reducer at the turbo) reduced to 3.5" later for a GT3582R on a 25/30, is it worth the effort?
Looks like a weapon mate, id be interested to see how your boost responce goes as ive heard some very mixed stories re plumbing it off the housing, some are great, others very average.
Engine looks like a weapon though!
Go the CP 9.0:1, the Arias might be a tad high for the power you are aiming for on pump fuel.
I second that.
I'm using the arias 9.2 comp pistons, after cc'ing the head, the bowls were smaller than standard (the head had been faced more than once before it was in my hands).
With a std thickness head gasket comp would be close to 9.4 so I've got to stuff around finding a thicker head gasket to get it down to 9.0ish.
I only intend using 1 bar on pump fuel and winding it up on race fuel.
While on the topic, what brand is the best bang for $ race fuel?
well my head is away getting rebuilt rang the guy up and he said that there isnt much wrong with the head so that all good and my stuff is away getting balanced, engine is about 40 percent complete just waiting to get my stuff back then we can build it up so far just spent over 7 grand with about 9 or 10 grand to go the only thing i wont be touching is the head besides the rebuild cant wait to get it going it will be exciting :wave:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
