Regardless more than 7.5k and u really should be running an aftermarket balancer.
So its either you go all out or you don't.
Standard rods resized with new bolts.
Price up what you want done to the std rods and then compare the price to spool import forged rods and you will see why its useless spending $$ on the stock rods.
has any one tried their luck with grabbing their series 2 motor from a wreckers then slappping the head on with new head gasket>?
like not touching the rings or bearings in the bottom end???
I know a couple of guys who have whacked together something rough and cheap, seems to be working fine for them pushing decent power? You looking into doing it yourself?
its just an idea at this stage as my motor seems rather heallthy...
the factory hone marks are still looking good.
i was thinking of putting rb30et oil pump and that being the only real change to the bottom end..
will be chucking in head oil restrictors also...
im havingtrouble finding any place tha can suply the tomei press fit oil restrictors...
what kinda of power figures are your mates cars running???
im running a hks T04e turbo.. i cant imagine it flowing enough to get anything over 270rwkw..
ill be happy to get over 200 at the wheels..
i have just brought dahtone racing (from this forum) head from his 32 which has been ported and running gtr valve springs..
all i would be buying would be genuin head gasket a idler and a genuine water pump and thermostat....
oh reallly..... maybe not such a good idea with the restrictors aswell as the 30et pump??
wat pump would you suggest going with...
my other thought was a rb25det pump....
was not sure if you needed the crank collar if you went with the series one oil pump???
cheeeers
cheeeers
yeh i would suggest the rb25det oil pump few of the guys suggested that to me also. you should get 200 at the wheels easy just whacking it together, some guys on the forums are talking fairly big numbers, but even saying that iv been told the factory bottom end can hold upto 500hp.
I saying that say you spend 1g max putting the 30 together on a very cheap its not gonna hurt as much as spending 5-6k and blowing it up right?
you should use a thicker gasket maybe?just an idea but im planning on using a multi layer rb26dett.
Im planning on using restricters with the 25det oil pump? Is this right/wrong?
Edited by Redliner007
Why not to use an RB30 oil pump... well it's just a bit skinny. Restrictors will be good with the 25/26 pump. Don't need to drop the CR at all so just use a single factory 25 head gasket. The collar is a damn good idea, and Nissan eventually made it standard across all RBs I know of after the 33GTSt and later model GTR32s to give a wider oil pump drive.
thanks for the offer geoff....but dad ended up getting a whole 26 head the other week anyway. So i need to change that sig now lol...Even so, we wouldnt have needed the idle control anyway...race car we just do it manually...one less valve, less weight and clutter :thumbsup:
what about leaving the stock rb30 oil pump and not running any restrictors or anything????
i planned on just using a stock nissan rb30 head gasket...
its my understanding that to fit the crank collar the crank has to be removed from the block and fitted professionally, is this correct????
cheeers
ps just ordered my dayco timing belt threw repco, cost me $60 cuz they had to order it..
what has anyone paid for a genuine rb25 idler???
haha yep ripco for sure ay...
spewing. as their is also a sprints in my town too...
oh well repco is just a pushy ride away and already paid for...
where abouts can ya purchase the head oil restritors??
yeoooowww
anyone got a spare rb25 idler sitting around??
haha
I would presume the stock rb30 pump should be ok with stock restrictors.
I remember some one on ct.com had issues with pressure bleeding off on idle with the rb30e pump. Unsure if it was a stuffed bottom end, pump etc.
Wouldn't use an idler. Use 2 x tensioners.
oh okay rekon i go with two tensioners.... its best to determen where to drill the hole for the second one after you have your timing belt?
so to get the right tension kinda thing??
salesman and a half you are dahtone.. haha im already in debt to ya..
does crank need to be removed to fit the crank collar??
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
