from memory it depends which power steering pump you are using, and if the belts line up correctly. Assuming the alternator/water pump belts are the same.
but for the price of the ross units why not just get one of them?
Agreed!
its a standard rebuild that im doing so i dont need the ross
I was going to use my r32 one but for the price i might as well get a new one. I remember sk posting that he uses mostly rb26, i think ill have to do some old fashioned belt checking and see if i can do the same. Otherwise im sure the rb20 one will be fine
Actually cubes will know, where are you old mate?
Edited by Gts30t
  • 3 weeks later...
hey all,
slightly off topic but im in n.z and i have a spare r32 non vct rb25de head that im thinking about selling, just wondering how much should i sell it for?
i have had it vacuum tested,crack/pressure tested and have had the valves all checked and have had it dipped to clean it all up. Only thing wrong is the exhaust valve guides have a tiny bit of play in it. The head is disassembled also but everything is there to put it back together i.e springs,valves,camshaft,gears etc.
I also have a r33 vct head that im thinking about selling what sort of price could i get for that? would it differ compared to the r32 as the r32 head are harder to find?
They both (with manifolds) go for around 1k these days.
The R32 rb25de heads can sometimes fetch a little more due to the no fuss bolt on and go.
The r32 rb25de has 'slightly' smaller but rounder ports compared to the rb25det vct head. Regardless they don't appear to give anything away in the power making vs boost side of things.
Only real issue is both heads are hydraulic of which limits total power output (400rwkw max) on pump fuel due to the inability to run cams with decent lift 10-11mm.
i only have manifolds for one of them which im using for myself. how much do you think i could get just for the single head which is unassembled? A guy has offered me 450 in bits for the r32 head?
Correct but the tomei solder lifter kit requires a cam with a smaller base circle. So extension shimming would be required.
There is a mob I have the number for that apparently converts the hydraulic lifters to solids. Have yet to contact him to find out the details cost etc.
I'd personally machine the heads buckets, grab the tomei solid lifter kit, suitable springs, reco the head and then have Tighe cams grind up a set of billets with 11mm lift or so.
Yeah the only reason i ask is because its a good upgrade for a RB20 i heard and i have a RB20 atm and having the 30 being build (well getting parts together) and just thought i could put them in my RB20 for a upgrade while i wait for the 30 then put them into the 30.
But if i have to machine the 20 head then the 25DE head then theres not that much point as i dont want to do much to the 20.
lol bad boy bubba.. I love cats.. I wouldn't wrap one in gladwrap :kiss:
I looked into solid lifter conversion with some big cams and it came to about $2500 in just parts, then gotta add machining and downtime to that!
I'll stick with my stock NA cams for now..
JHH Engineering in qld does the solid lifter conversion for roughly $450, then add $1250 for cams & gears.
I just picked up a big head from them for a friends car im building (26/30 in a 33gtr), labour on the head was $3130 ($6k head in total)
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
