The bigger the turbo the less it muffles the exhaust, that's why you can get away with a straight through setup on a stock rb20 and still have it bearably loud. With a GT30 the exhaust wheel is that much bigger and doesn't do a good job at muffling so you need a better exhaust setup. Keep this is mind when choosing exhausts people, turbo size influences the noise level drastically.
hey just a quick question,
i have just recently bought a brand new n1 oil pump will i also need to buy the jun crank collar too? and second thing i bought my oil pump from a Japanese tuner shop (st hi tec) and also bought 1 tomie oil restrictor but when buying this soichi cautioned several times not to use the oil restrictor as it is made for a rb26 and most likely to run the head dry and i have been told this by a couple of other guys too but some say to use it. Can anyone help?
my combo is
rb30 block with r32 NON vct head
wiseco forged pistons
shot peined rods
and just a standard recond rb25 head.
Quick question - how long does it take your cars to reach operating temp (we'll go by water temp)
From dead-cold to 80 degrees, it takes my donk about 5-6minutes... is this on par with other RB30s? Overall the engine does run quite hot, especially on the turbo side :P
Sounds about right. I've only recently whacked a new thermostat and water pump in there, before then I'm pretty sure the thermostat was getting stuck open as it would take AGES (read: 15-20mins) to get up to 80deg and would rise past there easily as if the thermostat wasn't opening fully.
Edited by bubba
Yeah the only thing is i only just need to get it rebuilt so it would be cheap, i would add cams but i dont have that much money to spend so thats about it.
I saw it made 344kw on a RB25 not much done to it at 7500 RPM but didnt boost till about 4.5.
Yeah I'm using one... 3" Hi-Flow Metalcat; I wasn't really using it for any performance reasons... more for legality, and also to get rid of the repulsive fuel smells coming from my exhaust which was also coating my rear bumper yellow. Great success in achieving these two goals.
Is it true that the Mazda 323 1.7d cambelt is the same width but 152 teeth long so it can be used?
Yep. half the price too :laugh:
Myself and 3 other guys i know well are running them with no problems.
Hey guys quick question..
Haven't got a block yet, but first thing I do will be to strip it down and go get it checked over before I rebuild the thing myself
I'm gonna get some pricing from some engine rebuilders around me, to help with the planning
What are the things do you guys think I should be asking for?
I hear you don't really need to rebore the cylinders
So just get pricing on machining the deck, acid dipping, repositioning of the tensioner, crack testing? Anything else I should get pricing on?
Plan for worst, hope for the best really.
Can someone confirm for me if its ok to use the RB25DET idler pully and tensioner with an RB26 head? Apparently there are two different tensioners, one for the RB20/25 and another for the 26...
Can't say I've seen any difference. Just use 2 x 25 tensioners as you can have too little slack with the high tensioner/low idler location.
There is no need for a difference as they do exactly the same job. Don't buy from Nissan but go to rolling bearings or somesuch. Should be about $120 for the pair.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
