Not sure if this has been mentioned...
I recently got my RB25/30 running (last Tuesday). I did the mod for the VCT, however, all I did was grub screw the hole in the head, with no other modification. My VCT works perfect. No oil control/lack of oil issues or anything (this was mod was done on the advice of my engine builder).
Discuss.
u mean to say u didnt do either internal(from buckets) or external oil feed to the VCT solenoid and it still works??
Correct. All I did was the grub screw mod to stop oil/water mixing. Bolted the head on (of course all of this on the advice of engine builder) and it works fine. This has been done on my mates twin came RB30 and his also works.
quick question guys, got a 6boost high mount mani and a gt35r turbo,did anyone have to re -postion any of the front or rear housings on the turbo to position the turbo correctly on the mani.my mani is a t3 flange,fits perfetly,so no problem there!
yes you will need to losen the front housing so you can align it properly with where you want it.
make sure the oil feed into the turbo is facing straight up
thought so cheers!i wont be doing it,just a stupid ? really, but there is no stupid ? on here!
ive just gotten hold of a NA rb30 bottom end and gonna to the usual build, ie rods pistons and so on, just wonder a few things...
1. is there any difference with the rb30 NA and Turbo Crank
2. can the rb30 crank be fitted to a rb25 block to get around drilling and taping holes in the rb30 block, read somewhere that this was possible and if not what is the best way about doing the tensioner for the belt if the pre tapped hole is not there.
3. is there any other differences between the turbo and NA rb30 block itself.
Using a 25 head, cheers for any help :)
Edited by fomby639
no
no
no, but there is a small difference between S1 and S2 blocks in relation to the flat area where the tensioner goes, the S2 block is a little easier.
Using a 25 head, cheers for any help ;)
Cheers
Gary
Some of the S1 blocks don't have the turbo oil feed drilled all the way through, check it with a piece of wire and make sure it goes all the way through the block and into the gallery behind the oil filter housing. You can drill it, just need a long series drill to do it. I've only seen one block like that but it's worth a check.
hey guys! Sorry its been a while have been so caught up with work and studies haven't really had much time to spend online or on cars sadly :banana: But i have managed to FINALLY get mine trouble free and tuned. How is all the rb30's out there? Hope all is going well for the festive season.
On a quick note has anyone has issues with the speedometer drive/cable on the bigger rb25det gearbox? For some reason my gearbox keeps shredding the plastic part at the end of the drive, It was all fine until i took it out onto the open road sitting around 100km this is the second time its happened and was wondering if someone knew a way around it?
do most of you guys get more area welded onto the head on the front water gallery i think it is how its different from the rb30 block? i got my head rebuilt but didnt know about getting that bit modded to get more gasket sealing area there. will it be ok to leave it how it is?
its a rb25det head from a r33
Edited by joe blo
How closely are you following the writeups for the speedo sender? are you cutting a new groove and rotating the sender 180'?
too be honest i didnt know there was one lol. Um i was thinking maybe it was because of the bigger motor it was doing this? I have yet to pull the speedo drive out a second time to confirm that it has chewed the plast gears, cutting groove and rotating???? I'm not aware of this
Read the writeups!!
You basically need to rotate the sender 180 deg otherwise the gear mesh is too great and it chews the gears out.
  • 3 weeks later...
hey people, great thread this one has been a great read!!!!
i am just about to do the following
put series 2 stock rb30 bottom end, with new bearings and piston rings
onto a stock series rb25 head.
how much should i be charged for this in labour? i have benn qouted $2500 nearly $3000
bear in mind this is to keep vvt also
any help and advice on whethter this labour price is good please let me know, i think its way too much
Guys I was just doing some casual reading AGAIN on the RB30DOHC guide, and in relation tot heR33 RB25 head, it claims you will need to:
"The R33 RB25 also requires you to plumb in an external head oil return, you can T in to the turbo drain."
What is the external head oil return it speaks of? Is this the standard one at the front of the head that needs to be T'd in?
I'm on my second RB30DOHC motor, and never had this fitted... What issues are normally seen if this isn't plumbed in?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
