  • 3 weeks later...
One of my fav cars at the moment. Engine combo is pretty insane.
Not bad for being built by a cement renderer lol
Can anyone tell me how thick the top of a CP piston for Nissan RB30/25 (86.5mm 9.0:1 comp) is, or roughly what it is?
Any info ASAP would be awesome.
  • 2 months later...
My head and block is getting machined up at the moment. Apparently my pistons were missing there spec sheet so I did a search and came up with 3 thou piston to bore... thought I just read another thread that said 3.5 thou is the standard. Should 3 thou be fine for CP flat tops?
Cheers
-Matt
  • 1 month later...
A big 2 thumbs up and thanks to all those who have contributed to this thread.... Effing fantastic!
Just wondering if there has been an update to the pdf doc? The latest version I can get my hands on is November 2007? btw this is not the one listed on page 1, that one is 2006.
I'm currently in the planning/purchasing stage of my RB30 build up. I currently own an R34GTT and I'm planning for more of a "budget build" where my max power at the rears will be capped at 250-300KW....eventually. With a shit load of torque of course for that V8 feel! Apart from the S2-RB30 block I'm planning to keep everything as is. Sitting at the correct height by modifying the engine blocks I'm hoping to use my standard R34 head, then bolt everything back up for a standard looking engine bay. In the beginning I'm even planning to use my standard R34 turbo etc. Might end up getting it high flowed and keeping it coz the cops here in SA are nazi's and I drive this car everyday.
I don't want to be that guy who after 350 pages still asks "does anyone know..."? But if anyone has any thoughts I'm open to ideas, more importantly if anyone knows the right people to speak to here in Adelaide it would be appreciated.
Cheers in advance guys.
the 25 head needs to be modifed around the vct feed. the vct feed needs to be welded up and then the head re faced. also doesnt hurt to chuck whatever gasket your gonna use against the head and make sure the surrounding water gallery will seal properly
hey guys i'm abit confused with something that info it says head needs to be modified but doesn't say what needs modifying. what does this mean by that?
ohh ok so my s2 R33 rb25det head wouldn't be a straight fit onto an already built rb30 block that was used for the rb25/30det set up previously would it? if the head needs to be faced...
Has anyone played around with a RD28 diesel block... Ive seen that the Allout R33 is using one and running quick times
Kind of off topic but I would also like to know if anyone has done it and wants to share some information... would love to know the rev limit set in the Allout R33?
Why are you not keeping the vct? Costs very little to do - there is even a thread on doing it without an external feed.
couldn't be bothered doing the extra work haha & you only lose acouple hp with out so i've been told...
got any links for the threads anyone?
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
