http://www.skylinesaustralia.com/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/
its way too easy to not do just for the sake of laziness. peak hp doesnt change at all without vct but you lose torque below 4500 rpm, something RB's need every bit of. for 5 mins of stuffing around its definately worth it
couldn't be bothered doing the extra work haha & you only lose acouple hp with out so i've been told...
got any links for the threads anyone?
hey people i'm doing this conversion my self & noticed on the rb25det there are an extra line from the head running to the block. what could these be used for? & what do i do with it as the rb30 block doesn't have a tapped hole on the block to fit it...
here's a pic of the rb25det block with the line>>
& here's the rb30 block that doesn't have a tapped hole to fit the line>>
If you have ever driven an rb25 without it you will know it is definitely worth keeping. Up to 10-15kw in the midrange on low throttle conditions.
alright i've worked out that line is the oil drain...
in that info guide it says (The Yellow highlight towards the rear of the block is the water return.
Water feed is provided from a hose/steel pipe assembly that feeds from the opposite side of the block) MY rb25 block has this blocked off do i run a water line from the other side somewhere?
  • 1 month later...
Hi everyone I'm slowly building up my 30 was wonderingwat computer will run a rb25/30 will a normal r33 apexi power fc work or do I need the pro version first time I've mucked around with computers thanks guys
it doesnt work without an oil feed. the solenoid simply feeds oil into a section of the cam which causes it to advance 20 degrees, no oil feed means no vct
Well mine does, and so do a few others I know of - has been checked by three workshops and an engine builder.
But I'm not going to argue with you about it (moreso the fact I don't fully understand why it is working, but it was the engine builder who did the modification without the feed knowing that it would still work).
Edited by cactus
There is a thread on how to supply the vct with oil internally instead of with an outside line:
  • 4 weeks later...
Can anyone tell me if there are any fouling issues with the RB30 sump into a R34. The guide says that with the 32's and 33's it's fine but nothing about 34's. I won't need to drop the engine any lower either as I'm not running the standard plenum.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
