  • 1 month later...
Hi guys, is it possible to run a rb2530 (det head) with a nistune?
Just pick the nistune based on the head you are using, or you might have to chop and change sensors and looms. However R33s don't have nistunes, so you would need an rb20det computer or z32 to run it. Pretty straightforward to setup, email nistune themselves and see what board they recommend you.
Edited by Rolls
I have the z32 ecu so that'll work? If so I will speak with Pete from nistune for more details.
Thanks for your help guys
  • 1 month later...
I need some clarification after weeks of reading different info if anyone can help
Im planing on doing the rb30 conversion using the rb25det neo head.
Can anyone confirm the cc's of the turbo neo head, Ive read anywhere from 52cc to 60cc ?
Also im running an auto tranny and it shifts at 6800rpm (I cant change shift points) from what I have read standard rb30 rods dont like to be reved over 6500 without letting go. Is this correct?
Do I need to get the crank balenced to rev to 6800rpm?
I hope someone can enlighten me.
Thanks
Balance your crank rods flywheel and pressure plate to prevent unwanted vibrations at high revs that will cause problems
Neo 25 heads i have seen here at the machine shop i work at vary from 52-55cc's
non neo 25 & 26 heads I've seen vary from 63-66cc's
Did you get your 25/30 back together? How'd it go?
yeah i got it a JEM at the moment gettin a E85 tune.. should get it back within the next week.. ill come past your work and show you man..
hows your car been going?
awesome, i think my 26/30 is killing the non syncro rb20/30 gearbox, will upgrade to the rb25 in the new year, just hope it can last
  • 3 months later...
Power porting the compressor and turbine covers is not something I have ever considered. I have done cast iron exhaust manifolds, works very well. I have not experienced any restriction in an RB25DET inlet manifold or throttle body up to 525 bhp so I doubt that it would be worth the cost. Over that, an RB26 top end with inlet manifold is a cheaper proposition when you add it all up. If you are intending to use the GT35R to its potential, then that would be my suggestion.
Hope that helps:cheers:
Hi.
What kind of flow gains did u get power porting the standard rb25 ex manifold? Thanks
  • 2 months later...
Ive finally got my head off time to drill and tap into the head for external oil feed.
first question Ive been trying to find a way to find all attached images within this thread.
looking at what people have done in the past for vct feed.
Also. Is there a particular spot alont the vct feed gallery where there is alot of meat to tap into.
Someone had suggested building up the alloy on the head before drilling and tapping. Whether its necessary or not I would rather find out before I pick a spot to start drilling into.
this is what i done>
hey thanks for the nice shots, that second shot where you have drilled into it you wouldn;t be able to send me a high resolution copy at all would you?
looks like quite a large line what size thread is that tapped? I was looking at tapping to suit a 3/8 NPT bung.
From the shots I'm guessing that particular area has a wall of 4mm would that sound about right?
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
