  • 1 year later...
Hey everyone, am nearing completion of my RB25/30 build, but I seem to be stuck on setting up the timing.
I have drilled and tapped the block above the water pump for the timing belt tensioner, am using a RB25 idler below the water pump, crank is at TDC, but am unsure on where my cams are supposed to be at. I also have adjustable cam gears to go onto the cams, once the motor in full is set to TDC correctly. To make it easier, the block is a standard A6 VL N/A block, and the head is standard aswell, valves, cams, with the exception of the VVL being blocked off in the head.
If someone could help me out with this it'd be muchly appreciated. Have tried searching in this thread alone and also the whole of SAU, but cant find a definite answer. With 359 pages worth of thread here, I tried looking, but it seems a lot of people like to talk shit in here too which makes it all that much harder..
Install the adjustable cam gears straight off and use the markers as per Ben's comment.  Then pay someone competent to degree your cams.  Hint: this is far easier and less time consuming to do on the bench/engine stand.
  • 1 year later...
Hey team.
Massive thanks for this thread. It's amazeballs.
Just wondering if a factory 25DE ecu could be used to get a 30DET running. Just temporarily so I can check everything for leaks and I'm eating myself noises before it goes for dyno tune.
Not sure what ecu I'm going to use yet will speak to the tuner before to see what brands they are familiar with.
Once again cheers guys
  • 1 year later...
I know....Rb25/30 boredom (not build ) question...but opinions will be cool
Need to know some real Hp/Kw figures for my build...just your guesstimation possibly.
Build
25neo head.+1mm over int/exh..rear head drain
Stainless valves ..performance springs
Tomei cams (poncam)
Ati balancer ...prp collar..n1oil pump..forged gears..prp billet crank sprocket washers...billet backing plate to n1 pump..7L sump.. Stock crank acl bearings...87mm rb30 block..CP flat top pistons...Max peening H beam rods.
Fuel cell...1000hp fuel supply..1400cc injectors.
6boost exh...45mm hypergate.
Haltech elite2000....flex fuel.
Real reason is so i know if my gearbox is going flying...
Build
Tomei cams (poncam)
No turbo so approx 180kw
  • 4 weeks later...
  • 1 year later...
On 19/10/2021 at 11:15 AM, jaychen said:
Is this still the thread to read with regards to high hp sohc rb30 applications?
Most stuff on here will relate to DOHC heads.
What info specifically are you chasing?
  • 2 years later...
Just thought I would bump this 20 year old thread because the Skid Factory have just posted up a video summarising a lot of the content, format might be more familiar for newer members
  • Like 2
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
