Hi Joel, I like it when the guys go and do their own research. It's much better than me telling you stuff, that you will forget tomorrow. If you do the work, you may not remember the answer, but you will always remember how to find out if you do forget.
The answer is that the optimum squish zone will result in improvements in Economy, Emissions, Performance and Response. Because there is a much higher chance for the fuel and air to burn completely. Since it takes out some unburnt fuel, it also improves the bore lubrication (no washing) and therefore engine life.
One of my favourite quotes comes from RaceTech Inc;
"On many engines, a squish or quench area is used to negate combustion in certain areas to avoid knock. By having a matched area where the piston and combustion chamber come in close proximity at TDC, the gasses are kept cool enough so that they will not ignite until the piston has moved down the bore and cylinder volumes are increasing. This keeps the rate of pressure rise below the knock limit. Some people are dismayed when they install a thicker head gasket to lower the CR and have knocking worse than before. This is because they have negated the designed-in quench effect. A large squish area also tends to promote increased chamber turbulence which is important for mixing and power at high rpm."
There is plenty of other squish zone reading around, a couple of guys in the US wrote a mega thesis on it a few years back. Do a search, it's there somewhere.
Ok here is what I have so far.
Sydney kid.. Would you be so kind as to have a look at the cam belt setup and let us know if this is how you did your's or if this is the best way to do it?? Thanx :D
File is 86k.
Hey Joel ... all seams all right just for a few things .....
1 . why not go a copper head gasket std head gaskets cant hold high boost pressure ..... ?
2. a compression ratio of 7.1 is perfect for turbos just think of it as the more air and fuel you can cram into the cylinder the more bang you get ......
my car runs on around 7.5.1 comp and loves the boost ...
and remember the higher the comp ratio the less off a wack youll get when u hit boost itll more feel like a v8 at 9.1 ...... just letting you know due too experience in the engineering side ...
Hu?
I've used a multi-layer metal headgasket that has its middle layer with a O-ring around the bore, it saved me $80 compared to using a stocker head gasket with a machined O-ring in to the block. Every little $$ counts when your at Uni and on $200 p/w. I havn't been out for a long long time, which is good for the studies though. :D
The comp ratio is around 8.2:1 by my calcs and Andrews calcs.
The only issue with the RB30 forged pistons is the comp would have been around 7:1, perfect squish but crappy comp. I didn't want 7:1. Every one told me not too.
Lowest I was told to go was 8:1. At the time I wasn't aware of Squish hence why we ended up settling on Wiesco RB25DET 14cc dome pistons that gave us around the 7.8-7.9 comp. Then shaved 20thou off the block to bring it up to 8.2:1. Should have done another 20thou or even 40thou.
Im unsure sure how it will affect the engine as I can't find any results on the net of how a engine has performed after its squish has changed by 3 fold. By the looks of it the difference is minimal, well from the little i've found on the net.
Remember for every .5 of a cr you dorp you need approx another 2.9psi to achieve the same final compression.
Drop to 7:1 and that means you will have to run an extra 6psi to make the same power if you were running a 8:1cr. So realisitically using the measurement of "I can run 2bar no problems now" is pretty usless as the final comp. ratio after the boost has been pumped in and compressed is the same.
Hi Joel apparently you asked ..............
Did I answer that?
hehe I can't remember, I could go through all the posts again but havn't got time. I've left a law subject essay to the last minute. :P Too busy stuffing around with the RB30 last weekend.
I really didn't have much choice in the matter as the Dayco 94407 was the only belt I could track down. The powergrip I was told didn't exist.
But out of curiosity how have the RB30DET's you know of been done?
Found an what looks to be an issue when using the stock RB20/25 exhaust manfifold on the RB30DET.
Pic 1.
The RB20 setup. Note the how water galley that is situated at the top of the block sitting a few mm down from the deck. It extends from the front of the block (end of the water pump) to the back of the block. (6 small of welsh plugs)
Pic 2.
The RB30 setup. Note the how water galley that is situated at the top of the block sitting basically flush with the deck.
It looks like it is way too close. Especially being where the lower exhaust manifold bolts are the water galley has a rise that flattens outhence fouling the manifold.
The RB20t block definately has a LOT more clearance.
Pic3.
Misc pic.. Came across that poster a while back in a Wheels Mag.
It states - "Nissans new Godzilla on wheels aims to slay the Sierra. And its here soon"
Lol they obviously wern't too worried about the V8's back then.. :)
Pic4.
My 91' R32 Bathurst GTR.
Have a read of this peoples.
http://www.racehelp.com/article_racing-10.html
It contains some interesting info regarding quench & piston design among other things.
<span style='font-size:9pt;line-height:100%'>It appears that for a high reving engine which is classified as 6500+rpm the quench or squish gap/clearance is around the .050-.055".</span>
This is due to the standard cranks felx & pin flex etc..
Well apparently according to one engine builder.
sent an email to gates in USA a while ago
"I'm trying to locate a particular belt of yours somwhere in Brisbane.
The one I am after is the Gates POWERGRIP GT2 p/n 1200 8MGT 30
it measures 1200mm long, 8mm pitch on teeth, 150 teeth.
If you would be able to tell me where I am able to purchace this belt
it would be greatly appriciated."
Reply
"Either Consolidated Bearing Company or Powergrip Industries in Brisbane
should be able to help you out with this one.
Best Regards,
Peter"
hope that helps anybody
I too have emailed gates australia regarding the Powergrip belt. Two issues.....the belt needs to be cut down from 30mm to 25mm (factory width), not sure who can do this.
Secondly, The powergrip GT2 belt has a lower temp rating than a cam timing belt.
I asked if there is an equivelent to an RB30 belt, but 1200mm long. The response from gates is as follows....
I have just checked with our global database and it appears you are in
luck. T306 is the same profile as the T175 (RB30 belt) and is 1200mm
long with the 8mm pitch and has a top width of 23mm.
We currently have the T306 belts available and the list price is
$120.65
The T306 may be the way to go? I haven't ordered one yet, so cannot confirm the above.
hehe I can't remember, I could go through all the posts again but havn't got time. I've left a law subject essay to the last minute. :) Too busy stuffing around with the RB30 last weekend.
Hi Joel, we mount the tensioner high and generally use a standard idler in the standard (low) position. But when we machine the head and/or the block (to get the compression ratio where we want it) we use a second tensioner in the idler position. We use the Dayco 94407 belt.
Hope that helps
It's good to use VCT up to a certain horse power level (maybe 250rwkw???) with the standard turbo or a mild turbo upgrade, then after that you ditch the VCT and go with adjustable cam gears to get better results from different cams and bigger turbo kits.
just a note to some ppl
a mate has just done a lot of work building his engine for his vlt
its a stock n/a 3l bottomend , fully prepped though , and a 25 head , vct welded up.
now it was made apparent to him and many others that bolting a 25 head to stock vl bottom would result in approx 8.3 comp , well after many hours work , we cc'd it all and it turned out to have about 64cc , which gave a comp ratio of bout 8.8:1 , too high for a performance engine as timing would be stupidly low.
i know most ppl using this great thread are using forgies aswell , but just check out some things before going ballistic on ur new engine.
anyway we are now going forgies for this engine , etc etc etc
good luck to all who do the conversion , its a top idea
andrew
andrew
Hi Andrew, I have done this conversion more than once and the compression ratio is 8.3 'ish always. I suggest you get them to check it again. Standard compression ratio on an N/A VL is 9 to 1 with 58 cc combustion chambers (SOHC 2 valve). If you do the mathematics you will see that with 64 cc combustion chambers (DOHC 4 valve) there is no way you only loose 0.2.
If you want to post the dimensions you used I can probably verify where the error is in the calculations.
Secondly, who says 8.8 is too high for a performance engine anyway?
See that car at the bottom, it has over 1,000 bhp (now that's a real "performance engine") and it runs 9.3 to 1. I would argue that 8.8 to 1 is too LOW, in fact I have many times.
I suggest you read Joel's posts of 23/3/04 and prior, he covers the reasoning behind this very well.
Hope that clears up any misconceptions
sydneykid
thanks for ur advice mate , i respect what u say , i have read many a response from u and u seem like a very knowledgeable chap
i will let him know the points u have made.
my mate works for tighe cams , he is an engineer , i dare say he did his calculations correct but who knows.
anyway , we planned for a cr of bout 8.2-3:1 , while using custom zorst manifold , gt35 or 30/40 dunno which one , custom inlet etc etc , anyway i will see what he says , also will try and grab the specs and post em up
thanks again
andrew
OVL..
I don't know exactly as I'm still reading in to it but here's my best shot.
Try to ignore the static compression ratios, thinking of them as only a base compression ratio that means in practice very little when you start to fiddle with cam timing, after market cams, turbo efficiency range etc.
It comes down the the dynamic compression ratio.
Rememeber this. For every .5 of a CR you drop in static comp you will be required to pump in another 2psi to make the same power/dynamic compression. Approximately that is.
Lets see what this looks like on paper.
An RB30DET with a static CR of 9:1 on 1 bar of boost makes 260rwkw.
An RB30DET with a static CR of 8.5:1 will require an extra 2psi (makes it 17psi) to achieve the same dynamic compression ratio hence 260rwkw.
Only real difference is that the RB30DET with a static comp of 9:1 will have better response, fuel economy and spool the turbo a little earlier.
Say you were to drop to 8:1. You would need an extra 4 psi (hence 19psi) to make the same power as a RB30DET running a 9:1cr with 15psi of boost.
Work the turbo's efficiency range in to this with a required power goal/ fuel used etc and you will find the 9:1cr is pretty much on the mark.
Running a higher static comp also leaves the door open for much better performance for when you or if you decide to slap a set of cams in it.
I've started to realise there is so much more involved when looking for a certian amount of power. So many variables that all work hand in hand to achieve the most responsive, fuel efficient engine.
I'm sure we have all read or heard at some stage or another that when you cam up an engine it is best to up the compression ratio. And why.. Dynamic compression ratio.
Having to pull timing out of a higher comp engine simply states that the burn is more efficient. It isn't a bad thing.
All this has started to make sense when I have heard tuners say with stock RB25DET's they tend to pull a little bit of timing and tend to richen it up a little if running on the limit around peak torque. Peak torque you will find occurs around where the engine is running at its highest VE (RPM of which most air is able to fill the cyclinders) hence at the peak torque the dynamic compression ratio is at its highest.
Do a bit of googling.. Definately worth the effort if you are building up a motor.
Guys,
I have noticed in the RB25 Workshop manual it says to first Torque the head down to a small number... like 25-30pounds all round...
Then torque to 70-75 (100Nm) and then back to 0!!? then back to 101Nm??
Why?
Doesnt this create unnessacery stretch on the head bolts, and doesnt the gasket loose its "mojo" (tensile)
Do you guys tension the head a diffrent way?
Cheers,
Trev
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
