HI all
Joel WROTE
There is an issue.. Apparently the RB oil pumps have a different size gear i.e NA and ET pumps have a different size gear how is the over come?
looking at the oil pumps the diffrence is in the width of the gear ,I will use the oil pump from my 25t as the gear is considerably wider and as such will pump more oil / flow.
have got oil squirters installed ,what a mission!!!, the Rb30 block has only 3-4mm metal in the casting before you enter the oil gallery (the 25t block has over 10mm).Ended up having to tap out to 3/8 bspt thread and installed the squirters into brass plugs,height of sqirters is a real issue as the crank has minimal clearance to the block,alot of mucking around I hope it is worth it.
Mayby someone can shed some light on the effectivness of the oil squirter install,I suspect that unless its a high boost+high rev drag motor the oil squirters are not really necessary (they are painfull to install).
Motor is about 1/3 reasembled ,im off to carry on.
cheers
Well basically I image it is why the RB25's and RB20's are able to make so much power before having forged pistons fitted.
For example the VL Turbo isn't able to make 260rwkw on standard pistons. The ol' VL Turbo's have many story's of melting pistons.
Originally posted by 25t
HI all
cheers
Yep 25t,
i was looking into the oil pumps to see if there was some size diffrences between all the RB motors and there is.
The difference is the gear width:
RB30E - 10.8mm wide
RB30ET - 13.4mm wide
RB26DETT - haven't measured, but looks like about 15mm wide or so to the eye.
Now, this wasnt measured by me. But from this we can accuratly say that running a RB26 Oil pump wouldnt hurt. Also i think the water pumps are diffrent also. (slightly) I will take a look tonight once i get the package. (RB26DETT oil & water pump)
Trev,
Doh...
I've got a series 1 calais. Do u think i would be better just getting a turbo block or a series 2 block?
On another note...Where you saying that the standard rb30 rods and pistons and suitable for this conversion? I know they are probably not recommended but what sorta power do u think they could withstand?
Cheers
The crank & rods are all the same in the NA and turbo motors.
Gotta luv nissan :)
Have a look on previous pages it states how much power/torque the standard rods can handle.
Don't get a turbo block.. Why? Its the same as a NA block with lower comp pistons.
A quick question, how much machine has to be done to make the rb20 head fit a rb30 block as I want the standard look with less turbo lag, stacks of torque and around 200kw at the treads.
I already have a spare rb20 det thats why i'm asking and I can get the machining for free.
Hi Rowdyr32, RB20 head won't fit RB30 block, bore size is different (78 mm versus 86 mm). RB25 and RB26 are 86 mm like RB30 so you can use a RB25DE or RB25DET or RB26DETT head on RB30 block.
Doing an RB30/RB25 hybrid for 200 rwkw would be a waste of time and money. You can easily get 200 rwkw out of an RB20DET and still have a broad power band, you just have to tune it right and select the right turbo and support systems. Check the posts, there is plenty of info on how to do it.
Hope that helps
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
