Hey guys theres an engine being sold on ebay if anyones interested RB25 headhigh mount extractors for a t04 turbo with t3 flange worked with stock cams two inlet manifolds and an rb 25 block Rb 30 block pistons and rods i think for the 3.0l rb block $500.Plus i think all the hard work like matching the head to the block has been done allready.He claims that he has made 770 hp from it in his race car?????Its worth being checked out.But the price may go up because of the bidding.....Worth a look. :flamed:
Thanx Gary,
Which valve springs do you use? A set of GTR springs should will do the job?
Hi Joel, when I said "we always upgrade the valve springs" that includes GTR's. We use Iskenderian.
rob from RIPS is a nice enough guy but what he charges for the work he does its bloody highway robbery... he want 3,400+ shipping for a rb30 converted to take a 4wd sump??????? then wont tell you what your getting done for your money???? WTF
Plus he said that would be standard internal put new bearings???? again WTF
PRIMO check back a few pages the issues of the 4wd system on the rb30 have been discussed there, if you are keen to hold off a few months i am doing all the work required to make this work and will gladley tell you step by step what it takes to make this work its not really that hard as long as you have a good machinist shop you can talk to and access to some cluey engine builder!!!
S13drifter ok when you get urs done let me know i assumed it would not be hard if you had all the machining equipment ,
It is only a slab of steel used to replace the main bearing cradle and also bolt to the exsisting sump bolts ussing resessed bolts the utilising new bolt holes for the 4WD sump am i correct ?
i would assume this would relieve any stress on the block also.
HOLY CRAP. I started at page one. I looked and there was 8 more pages so i went to last and i find out there is 50+ pages.... eek... Anyway great thread. I am looking to to the RB30E.
Does anyone know what the stock specs on the RB30E is? I love in the states so where would be a good spot to buy an RB30 clip or motor set?
The RB26 main bearing cradle is separate from the sump mounting system, same as RB30. The only difference between the RB26 block and the RB30 block at the sump mount is the RB26 block is much wider (mostly at the rear) and has extra threaded holes (further out) to mount the sump, diff and transfer shaft to.
Guys;
Has anyone actually done this and had good long term success in terms of durability and power? I'm keen to do it but a shop in Sydney who has a lot of experience with GTRs and the RB30 conversion on other cars has warned me against it, saying that RB30 blocks are too weak to continually take the torsional stresses of a high power 4wd and are prone to cracking (whereas a 2wd will just light up the rears). I'd be more than happy with 400 4wkw, which it won't see regularly and as it's a daily driver it's the torque I'm after.
I understand RIPS in NZ has a strong GTS4. They don't appear to have a website so I've sent an email and will follow up with a phone call later to see if I can find out more from them.
Thanks for any feedback.
Done some more research on suitable timing belts. Dayco have a belt the same profile as a 94407 (152 teeth) but with 150 teeth, Part no. 94777. This could be used with 2 adjustable tensioners in the factory locations as per the Gates belt setup in Joel's guide. Only issue is this belt is 23mm wide rather than the factory 25mm. Dayco tell me this is not a problem, but they also follow up the e-mail with a disclaimer.... "however please be mindful as we don't list this belt for this application you have requested there will be now warranty to cover consequential damage should something go wrong - we'll cover the belt, but that's it." Probably standard arse covering fare, but it makes me uncertain if it will do the job.
I realise the 94407 will do the job, but why drill & tap another hole and risk ****ing it up if i don't have to.
I'm interested to hear others thoughts on the 23mm belt. Will it hold up to 500 BHP??
heres a rough pic of what the spacer/girdle has to look like to adapt the rb30 block to the rb26 sump (sorry for the crudness of the picture had to be made small and rough to fit).. PRIMO as gary mentioned the crank girdle has nothing to do with the conversion exept the rb26 one has the windage tray as part of the girdle and the rb30 has it in the sump you can either tap holes and fit it to the rb30 girdle or as im doing use the rb26 girdle and get the block and girdle squared and line honed!!!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
