Fitzpatrick Speed Works Posted June 17, 2004 Share Posted June 17, 2004 try this pic instead!!!! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-895113 Share on other sites More sharing options...
w1ngzer0 Posted June 17, 2004 Share Posted June 17, 2004 try this pic instead!!!! here you go guys. I don't know if this site was posted or not but there are 50 pages so i hope not. http://users.esc.net.au/~cobra30/twincam.htm provides pictures and explantions Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-895184 Share on other sites More sharing options...
GTR-Ben Posted June 18, 2004 Share Posted June 18, 2004 Get Joels guide or skim through the pages here. A bit more up to date and more info than that guide. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-895578 Share on other sites More sharing options...
Cubes Posted June 18, 2004 Share Posted June 18, 2004 That reminds me I have to update a couple of things.. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-895608 Share on other sites More sharing options...
w1ngzer0 Posted June 18, 2004 Share Posted June 18, 2004 Get Joels guide or skim through the pages here. A bit more up to date and more info than that guide. His guide didn't cover some things so between both i got everything i needed Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-895683 Share on other sites More sharing options...
Cubes Posted June 18, 2004 Share Posted June 18, 2004 Just a couple of pics for some ppls to look at. 232dur 7.3mm Lift R32 RB25DE Exhaust Cam & Water galley lumps under the exhaust stud that must be ground back so the exhaust manifold doesn't foul it. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-895701 Share on other sites More sharing options...
Cubes Posted June 18, 2004 Share Posted June 18, 2004 What was it that the guide missed? Please let me know and I will slap it in there. This guide is a group thing.. Every one has helped put it together. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-895717 Share on other sites More sharing options...
Jaws Posted June 22, 2004 Share Posted June 22, 2004 We use Iskenderian. How much and where can they be bought from?. What valve springs would be best for 600 hp at the flywheel with an r33 rb25det head?. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-902418 Share on other sites More sharing options...
Sydneykid Posted June 22, 2004 Share Posted June 22, 2004 http://www.iskycams.com/ Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-902469 Share on other sites More sharing options...
JNR24 Posted June 26, 2004 Author Share Posted June 26, 2004 Hi guys, i need a hand... any help would be much appreciated: http://www.skylinesaustralia.com/forums/sh...ead.php?t=44432 Cheers, Trev Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-908482 Share on other sites More sharing options...
Jaws Posted June 27, 2004 Share Posted June 27, 2004 I have purchased a GT35R (0.82 exh housing) rated at 700hp. The RB25DET head has the standard valve springs and valves in it. There's no doubt the head will need new valve springs but what LBS should i be looking for?. I intended to get all the power I can from turbo, would the head benefit from porting and to what extent would it need?, before fitting the new valve springs. Keep in mind that the standard cams will be replaced with aftermarket ones later on along with adj cam gears. Anyone know some good places for head work in the gold coast/brisbane area? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-910320 Share on other sites More sharing options...
Sydneykid Posted June 28, 2004 Share Posted June 28, 2004 Hi Jaws, You are no doubt aware that RB25's have hydraulic followers and that you would be limited to ~256 degree cams with ~9.2 mm lift to retain the VVT. This means no change in valve springs is neccessary. If you wanted to run cams with larger lift or longer duration (therebye loosing the VVT) then you need a change to solid followers (as in GTR's). This should be done at the same time as the head is off. It is also worth noting that if you want more than ~9.5 mm lift, some very minor machining of the head (to clear the lobes) is also necessary. As for porting, polishing of combustion chambers and matching combustion chamber volume it is always worthwhile doing while the head is off. Hope that is of some help Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-911378 Share on other sites More sharing options...
Guilt-Toy Posted July 6, 2004 Share Posted July 6, 2004 Can someone please confirm that you can close the bonnet on a R33 with the RB30 conversion with standard engine mounts? My mechanic said that it wont close.. Is this true ? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-922295 Share on other sites More sharing options...
Gradenko Posted July 6, 2004 Share Posted July 6, 2004 Guilt-Toy, I can't close the bonnet with a modified factory plenum. I think it would be very, very close with a standard plenum too. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-922329 Share on other sites More sharing options...
Guilt-Toy Posted July 7, 2004 Share Posted July 7, 2004 Anyone know for sure ? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-923133 Share on other sites More sharing options...
riceline Posted July 8, 2004 Share Posted July 8, 2004 Yep its true My bonnet wont fully close... It closes and catches fine. Just the frount left section (where my pod is) is up a little.. (provides an AWSOME cold air intake to the pod) Can take a photo later on if you like. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-925395 Share on other sites More sharing options...
GreySky Posted July 8, 2004 Share Posted July 8, 2004 Guilt Toy Bonnet definately wont close on an r33. I know a mechanic in Newcastle who has done 3 of these conversions to r33's and he buys a custom made plenum everytime to solve the prob. If you want his number pm me. Does anybody know why my r32 rb2530 will cut out sometime at the top of the rev range in third gear. Im assuming I have maxed out the afm, but does anyone know what the built in cut outs/defenders are and how they feel. Mine will cut all ignition to the motor until i remove my foot from the accelerator, it will just coast, then it goes again as if nothing happened. Any ideas and how it can be overcome are appreciated. Grey Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-925625 Share on other sites More sharing options...
the phantom Posted July 8, 2004 Share Posted July 8, 2004 Hi, I couldn't close my bonnet with the standard setup and Rb30 conversion. I probably could have but didn't try forcing it. I didn't want to disturb the hood liner let alone the bonnet with the natural engine movement. Doing the mods to lower the engine is quite straightforward...i.e. cheap. You dont need to modify plenums or anything that drastic. You simply get a 10mm plate that sits between each mount and engine. The plate has eight holes. Four countersunk in the standard position to bolt the plate to the block, and 4 threaded, about 25mm lower to bolt the mount to the plate. Then you extend the mount slots on the crossmember as the mounts will naturally stick out a bit further due to the plate width. Remember to also trim the radiator shroud slightly to allow for the slightly lower position of the fan. The engine to gearbox braces also need minor relieving to clear some lines. Its all quite simple and easy, and will not look obvious. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-925626 Share on other sites More sharing options...
Cubes Posted July 8, 2004 Share Posted July 8, 2004 GreySky, I get a AFM cut around 5000-5500rpm when running over 16psi of boost on the stocker turbo with the RB20t. It literally kills everything and scares the crap out of you the first couple of times it happens. First time it happened I thought I majorly stuffed something is it is a very harsh cut out. The cooler it is the easier or earlier (psi) the afm cut will occur. The most boost I can run on a cold morning/night is around 14psi, ~15psi and she will cut generally if winding out third, 16psi will cut during second etc. Only way around it is either a fuel cut defended (which is dodgy if you don't check the car on the dyno after installing) or get the ECU tuned/powerfc. If you are still maxing out the afm after the ecu/powerfc then you will need the Z32 or Q45 afm as they output a lower voltage for a given airflow. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-925759 Share on other sites More sharing options...
Cubes Posted July 8, 2004 Share Posted July 8, 2004 Phantom, As you have lowered the engine a little has this introduced any vibrations or extra wear on the universal joints tail shafts center bearing? Bit like the ol' VN/VS. VN's where pretty bad aligned, VS's wern't to bad but I still went through a center bearing after 50,000km's. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/52/#findComment-925762 Share on other sites More sharing options...
