Cubes Posted May 20, 2003 Share Posted May 20, 2003 A 3ltr really wouldn't make that much difference to hit the 11's as with a 2.5ltr you have the power to hit the 11's just not the traction. Even cracking in to the 12's is a lot harder that you think. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-335915 Share on other sites More sharing options...
Zdenko Posted May 20, 2003 Share Posted May 20, 2003 then y is everyone wanting to go 3 L?? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-335920 Share on other sites More sharing options...
Sydneykid Posted May 20, 2003 Share Posted May 20, 2003 Hi Zdenko, you asked "then y is everyone wanting to go 3 L??" If you are into drags and want to do 8's, 9's or low 10's then 3 litres is the go. If you want high 10's, 11's or 12's then RB25 will do it. If you have a clapped out RB20DET and want to upgrade, why go RB25DET, when for the same cost you can go RB30E/RB25DE hybrid. Ditto if you have a stuffed bottom end on a RB25DET, cheaper to go RB30E bottom end than fix the RB25DET bottom end. Both RB25DET bottom end and RB30E bottom end will handle 450 bhp, so you might as well have the faster spool up, better throttle response and more off boost torque from 20% more capacity. Cost versus bhp, the RB30 is hard to beat. But if you have a perfectly good RB25DET, I wouldn't bother unless I wanted to get over 500 bhp and was prepared to spend $20K on the car to use it. Hope that clarifies. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-335952 Share on other sites More sharing options...
GiJOr33 Posted May 21, 2003 Share Posted May 21, 2003 i'm doing the conversion, but the problem i'm faced with at the end is that i'll have this bullet proof motor capable of something like 800hp, but will have to tune it only for 500hp as i don't want to be replacing the gearbox all the time and i can't afford an aftermarket gearbox! Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338013 Share on other sites More sharing options...
Zdenko Posted May 21, 2003 Share Posted May 21, 2003 arnt our gear boxs good for 400rkw?? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338030 Share on other sites More sharing options...
GiJOr33 Posted May 21, 2003 Share Posted May 21, 2003 i heard 550hp at the engine is what they'll handle... but a couple of people have also said that there are 650hp skylines on stock boxes. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338065 Share on other sites More sharing options...
MetBlue_GTST Posted May 21, 2003 Share Posted May 21, 2003 This is an awesome thread and i have been following it closely coz i'm plannig on going the RB30 conversion near the end of the year... I know for a fact that the Rb26 gearbox can handle 650HP at the rear wheels, but if abused the 3rd gear will strip itself... as for the 25 box, i know they are strong, but not sure how much power they will handle... Does anyone know if the Rb26 box can go onto the 30 block??? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338086 Share on other sites More sharing options...
rev210 Posted May 21, 2003 Share Posted May 21, 2003 same as the RB26 box internal wise. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338094 Share on other sites More sharing options...
GiJOr33 Posted May 21, 2003 Share Posted May 21, 2003 what are they good for? reliably... no point saying they can hack 700hp if only one car has done it. What power rating (at the engine) do they start breaking? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338130 Share on other sites More sharing options...
25t Posted May 21, 2003 Share Posted May 21, 2003 Hey guys how do you do the qoute thing? I said a wee while back the series 1 na blocks are stronger/thicker castings,the only fitting not in the series 1 casting is the turbo water return line,which isnt a really big problem, i was wrong,the water line is there ,the fitting that is missing is an oil drain from the head into the sump ,will plum it into the turbo drain line cheers Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338528 Share on other sites More sharing options...
Cubes Posted May 22, 2003 Share Posted May 22, 2003 25t just above the post reply button their is a quote button that will quote the person.. Oil drain from the head into the sump? Sounds strange. Any pics? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338706 Share on other sites More sharing options...
Skyrine-Dave Posted May 22, 2003 Share Posted May 22, 2003 i think what you mean is missing is the oi return line from the Turbo!. this line gets plumbed into the sump i think?... i think you can get your sump "spiked" to allow for an oil return line to be plumbed in do all the R31 skyline blocks have the oil return ? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338714 Share on other sites More sharing options...
25t Posted May 22, 2003 Share Posted May 22, 2003 hi all no i mean that the head has oil return/drain line that is plummed into the block just above the sump level, Dave the turbo drain point is on the block / i plan to plum the head drain into this point as well will take a pic to explain my rambling. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-338871 Share on other sites More sharing options...
DennisRB30 Posted May 22, 2003 Share Posted May 22, 2003 Cool thread guys. What about the legalities of the big block? Its an older engine and that could cause probs right. What mods have to be done to the R33 to get in to fit in if any, engine mounts ect? Is there plenty of bonnet clearance? Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-339440 Share on other sites More sharing options...
JNR24 Posted May 22, 2003 Author Share Posted May 22, 2003 same clearance as RB25, RB30 Block bolts down to original RB25 engine mounts. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-340551 Share on other sites More sharing options...
DennisRB30 Posted May 23, 2003 Share Posted May 23, 2003 I thought the RB30 was taller by a few CM? Joel, you can take a boost controller off. Its *slightly* harder to change the bottom end Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-341036 Share on other sites More sharing options...
Cubes Posted May 23, 2003 Share Posted May 23, 2003 The RB30 block is around 3cm's taller. You wouldn't even notice it. Everything looks the same. Providing you use a RB25DE Non-vct head. If you applied for the modification to be approved i don't think you would have to many problems. Even though this is 'wrong' if you were to have RB30 block stamped with a RB20 or RB25 engine number it would most probably go un-noticed providing the rest of the car looks relatively stock.. I.e no high mount turbo's. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-341126 Share on other sites More sharing options...
Sydneykid Posted May 23, 2003 Share Posted May 23, 2003 Hi guys, a couple of questions popped in since I last read through this thread. Having looked at the internals of RB25DET gearboxes and RB26DETT gearboxes I can confidently say that they are physically identical save for the transfer case and associated parts. It is pretty much well recognised that GTR boxes will take 650 bhp and that is with the extra traction of 4wd. So there is sound logic in saying that a RB25DET box, being 2wd, will handle at least the same power if not more. I'm about to put my money where my mouth is, the new RB31DET (RB30E/RB26DETT) will fully test the capacity of the RB25DET gearbox. It has a twin plate clutch, 2 way LSD, will be running on "R" type tyres and the suspension has plenty of grip. If it survives a few races I can definitely then vouch for the above. All of the RB30 blocks (both N/A and turbo) that I have seen, have blanked off holes for turbo water feed and water return and turbo oil feed and oil return. It is simply a matter of drilling and tapping the holes for the fittings in the block. Don't let that put you off, it's a piece of cake. If I had an RB25DE on one engine stand side by side with an RB30E on another engine stand, I reckon in one day I could have a 450 bhp capable RB30DET ready to go in the car. It is basically a bolt and unbolt exercise. When you buy a new block from Nissan to replace a broken one, it does not have an engine number stamped into it. This is so you can stamp it with your original (broken) engine number. Conversely, when you put a long stroke crank in your engine or bore it out, you don't have to tell the rego guys. It's got the same engine number, that's all they care about. Think about it? What are they going to do? Tell you to pull the head off the engine so they can measure the bore and stroke to see if you are over the limit. And if they are wrong, they will have to pay for a rebuild. Ain't gunna happen. Emissions is the only way they are gunna do anything about it. A well tuned high performance engine, running unleaded fuel and a cat will have no problems passing that. Hope that adds to the discussion. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-341377 Share on other sites More sharing options...
matlowth Posted May 23, 2003 Share Posted May 23, 2003 You're right... I was running 124mph which is good for 10's (With traction), and the best run I managed was 12.3... Most of the others were 12.7. No traction till 3rd gear (which is what most of you with this power will get) will hamper any chance of getting a really quick time on street tyres. Cheers, matt Originally posted by -Joel- A 3ltr really wouldn't make that much difference to hit the 11's as with a 2.5ltr you have the power to hit the 11's just not the traction. Even cracking in to the 12's is a lot harder that you think. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-341394 Share on other sites More sharing options...
matlowth Posted May 23, 2003 Share Posted May 23, 2003 Sydneykid - some food for thought - while the gearbox is physically identical, but you're forgetting that the tailshaft and driveshafts are a lot smaller than that of a gtr... I'd be more inclined to say that one of my driveshafts would go before the gearbox... In any case, I'm sticking to single plate clutches just in case! Cheers, matt Originally posted by Sydneykid Hi guys, a couple of questions popped in since I last read through this thread. Having looked at the internals of RB25DET gearboxes and RB26DETT gearboxes I can confidently say that they are physically identical save for the transfer case and associated parts. It is pretty much well recognised that GTR boxes will take 650 bhp and that is with the extra traction of 4wd. So there is sound logic in saying that a RB25DET box, being 2wd, will handle at least the same power if not more. Link to comment https://www.sau.com.au/forums/topic/15420-r33-rb30-conversion/page/6/#findComment-341406 Share on other sites More sharing options...
