87mm bore is safe providing you don't go silly with the horsepower and the bores have been crack tested. i.e 600+hp
Over that you would also want to make sure you are running a set of forged rods.
Thanks for the info Joel.
I'll start with getting the block pressure tested and cleaned, it's no loss if it's no good it was free after all. :cooldance
What over size pistons and rings did you guys use?. I'm looking at the arias RB30E forged pistons to suit the twin cam conversion, but they only come in 20 thou as I know of.
I'd rather have the bores bored out to a minimum to keep the cylinder walls as thick as possible just for peace of mind.
Does anyone know what the size of a virgin bore is? and can it be measured easily? :Pimp2:
86mm.
The stroke is 85mm. :cooldance
I used Wiseco forged pistons.
If I were to do it again I would go custom and get the quench/squish setup exactly. But you learn as you go along.
This has been my first engine build so at the start of it I didn't even know of quench/squish.
The only difference that i've noticed between the 20t and the 30 sump is at the very front where the sway bar slips in underneath.
The RB30 sump has less clearance as it has a slope to one side where as the 20 sump is horizontal.. in otherwords.. straight. :P
If you are having sway bar issues Ben I would definately go the rb20 sump.
I can't say if the 25 sumps are the same as the 20 sumps.
At the very front of the sump.. The sway bar resides underneath.
On the RB30 there is a slope that runs from the passenger side down to the drivers side.
The RB20's section at the front does not slope, it stays at the same level.
Hope that makes sense.
I'll post a pic if you need.
That I do..
Darren used the RB20 sump and has lowered his motor to the point where the sump base is sitting ever so slightly lower (either that or its perfectly level) than the x-member.
Just have to be carefull not to loose the arse end out and mount a gutter. :P
Well yeah.. but we install trust sump extensions onto quite a few GTR's.. which drops the sump a lot!! and never had one rip off yet.. :P
I was thinking more about the problems with the gearbox/driveshaft with having the engine 30-50mm lower..
Thats exactly why I was umm and arrring about dropping the motor.
The last thing I want is for it to have the driveline alignment issues of a VN Commodore.. lol :D
BA V8 Ford bonnet here I come.. lol
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
