I'm really not sure what you mean.
The RB30 block has a predrilled and tapped hole for the new tensioner location as an RB30 only uses one tensioner and no idler on the drivers side or when looking at the block the left side of the block.
Found a pic of my block as it was being built up.
As you can see the flat surface around the place where the tensioner will go.
Mine was a Series II VL Wagon Exec NA Block.
Are the blocks you have Series 1 blocks? Do they have the oil and water lines already tapped? If not they are series 1 blocks.
Are you going to use stainless steel welsh plugs or brass ones as per pic 1?
EDIT: Also the fuel consumption I am getting is pretty damn good..
Slightly better than what the rb20t was getting. :D
The RB20t was getting around 11L/100km's.
heres the pics. i have 3 blocks like the first pic and the other is a genuine vl turbo block
I have a VL na S2 block and it looks like this.
Now I know that VLT and VL na S2 blocks are the same but if you look under the engine block number it will have a number.
6=na
8=turbo
mines a 6 :D
well its all tapped for turbo gear from the factory so its a bit wierd!
also i have another turbo block that doesnt have the machined surface for the tensioner.
so its 5 blocks in total all of which are tapped from the factory.
2 turbo blocks wearing an 8 under the engine number.only 1 has the machined surface!
3 na blocks all of which have no machined surface
dnb My block is the same as yours and it has all the oil and water lines tapped aswell. I have already had it Torqueplate bored, honed and o'ringed so I was thinking of making a washer the right shape and fill around it with devcon (steel putty) and file it back level with the other surfaces. I have bought a second tensioner instead of the idler. I also have to make an adopter plate to fit a 4wd sump as it will be going into a GTS4.
what about the na blocks that ARE tapped but have no machined surface?.
you deleted your post alf! now this looks silly
sorry, getting confused here.
Ok, i've had this convo about rb30 na blocks before with several knowledgable ppl.
Everyone says the s1 rb30 block doesnt have tapped holes for oil and doesn't have the machined surface.. but the same ppl have seen a few s1 blocks with tapped holes.
haha yeah ive had that block done aswell;( its cool though as im selling my old sohc set up to a guy who will buy this block off me as its ready to go. i was gonna do the devcon trick aswell but since i have the option to unload it and i have another block sitting there i will just get the other one machined up.
i think this had better be mentioned in the rb2530 conversion guide!
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
