Give us the part number of the pistons, rod length and bore.
I will work out the approx comp ratio.
I am 99% sure you will not have a 8.2-8.3:1 comp ratio.
The only pistons Wiseco sell off the shelf that have a dish are the RB30DET pistons. They give a 7:1 comp ratio. All the others have a 14cc dome.
Obviously you will have a little more comp ratio if you have a zero deck height.
BUT that will depend on the rods and how much you can deck the block if it is indeed possible to get the zero deck clearance you are after when combined with the compression height of your pistons.
Tell me the specs on the rods.. Are the EXACTLY the same size as the rb30 ones?
I'd be interested too.
DnB the rods look identical to the ones I have, SCAT modified chev rods.
The SCAT rod looks to be approx 1mm longer than the stocker.
Mine require a thicker rod bearing which needs to be chamfered to fit. I havent had it fitted/measured yet.
check this link. i have a thread on it over on our rb friends site calaisturbo
http://www.calaisturbo.com.au/showthread.php?t=30077
did you measure that with the standard chev little end bush? its bigger than the nissan one so it would measure longer if you went overall measurements rather than centres
NO, the rods had bushes fitted to handle 1000hp plus for an rb30 when I bought them.
I bought the rods through a mates contacts, he works at Gold Coast Porsche.
I put the scat rod against the stock rod and compared it by eye.
Just a couple of quick questions,
Does the RB25DET oil cooler bolt straight to the RB30 block, or is it different somehow, maybe the filter bypass valve is different or something?
I haven't removed it yet for actual inspection myself, but im sure someone would know?
Also what is this extra drain for, i assume oil? Should i extend the line and plumb it into the sump?
Because I have seen a few conversions where this line has just been crimped shut, therfore no drain, is it critical.
Once again I havent removed it yet for actual inspection.
Cheers for any help :D
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
