Not quite finished yet but heres my soon to be Triple Garage with built in Store room.
GTR is to sit down the back.
Dos'nt look that big in the pics but it is quite a large area >_<
Edited by PSI_GTSII
  • Replies 46
Posted Images
Wow, very nice, thats exactly what i want when i eventually become a home owner.. post up pics when its finished. Unfortunately this is where my car resides atm:
Edited by r32line
how much was your car cover?
Like $80 at autobarn, it wasnt the most expensive one there, but it hasnt been the best, it tears very easily, at the seams it has splits in 3 places at the momnet and im careful every time i put it on, im thankful for electric folding mirrors everytime i put it on though :thumbsup:
Car covers can sometimes do more damage than good, especially if they are cheap.
The process of removing and fitting the cover can in time damage the paint; also wind, etc, will cause the cover to rub on the paint.
Just my 2c
Just my 2c
yeah thats fair enough, but its not that cheap the one i have, its just the seams where it joins arent well stitched, but the material is very soft and im sure it hadnt affected the paint!
Yeh GTR rears, but over fenders nicely moulded in..........
added more intercooler pics for those whom requested, intercooler is HUGE, 140mm thick to be near exact, id add a couple more cm to it, its near 146 or something
cheers fellas
OK guys I finally cleaned up my garage. Here it is (not including skyline)
Cheers vidospace
Makes me feel much better. My parents don't let me park my car in their garage, so i'm hiring a garage from a little old granny. Like you, it is only have a single garage. It is actually a townhouse garage so this thing is narrow as.
It's pretty difficult to work on the car in there, but hey, it keeps the car clean, and it beats working on the car outside iwth all the mozzies etc.
cheers fellas
Is that your track car?
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
