these items plus aftermarket ECU and injectors made 320RWKW on 18 pound on my current RB26 GTR
i am selling a few bits and pieces from my GTR all parts minus air box have only been on the car for roughly 15,000kms, air box kms are unknown and probably needs a new filter, parts inlude,
Trust T517z 8.0cm turbos X2 $2800 the pair, $1500 each
Trust front and dump pipes to suit turbos $1000
Tomei - Pon Camshaft Duration: IN 260, EX 260 Lift: IN,EX 9.15mm $600 the pair
ARC Air box (polished) suits standard air flow meters $500
Custom Top pipe (Polished) with air splitter fitted to stop air flow colliding $250
$4600 the lot pick up preffered melbourne area.
dont hesitate to ask any question if more photos are required just ask
https://www.sau.com.au/forums/topic/154241-300kw-package-trust-t517z-turbos-x2/
HEY MATE I GOT R34 GTR...
IM LOOKING AT THIS HKS GTRS TURBOS FOR 2900 ONLY DONE 3000KMS
I JUST BOUGHT POWER FC DJETRO AND I STILL HAVE MY STANDARD AIRBOX, DUMP AND FRONT PIPES..
HOW MUCH WOULD YOU SELL THE TRUST FRONT PIPE ONLY COS IM LOOKING AT THIS 2.5 DUMP FOR 600 BRAND NEW WITH SCREAMER PIPE.. WHATS THE SIZE OF FRONT PIPE..ANY DAMAGE???
YOU GOT EXHAUST MANIFOLDS???
I MIGHT CONSIDER YOUR SETUP??? THE WHOLE THING..WHY YOU CHANGING IT ANYWAY IM JST SCARED OF BUYING SECOND HAND PARTS BECAUSE DONT KNOW THE CONDITION AND WHATS THE GENUINE REASON OF SELLING.YOU KNOW WAT I MEAN.
SEND US YOUR NUMBER OR CALL ME ON 04 2203 2203
sorry DATS IT im not looking at seperating the front and dump i would llike to get rid of them together, im just running standard manifolds.
Im getting rid of the set up as i removing the engine and replacing with a standard engine as i am looking at selling the car. My engine being short motor had an extensive rebuild (rods, pistons sump ext etc,etc) so i am gonna keep that so thats why im getting rid of the other stuff. :happy:
P.S. thanks nigelp for the bump :sorcerer:
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
