post-12377-1170242689.jpgpost-12377-1170242789.jpgpost-12377-1170242717.jpgpost-12377-1170242744.jpgpost-12377-1170242766.jpgInterior
Full electrics
Tinted Windows
Dr.Drift remapped ECU tuned by XTC (139rwkw)
GTR seats
HKS T/Timer type 0
Autometer boost gauge
Immobilizer
Alarm
Central locking
Pioneer speakers
RAZZ gear knob
Autotechnica steering wheel.
Pioneer 6 inch rear speakers.
Pioneer CD player.
Exterior
Apexi Boost controller
Fujitsubo 2.5 inch exhaust straight through
Adjustable front/rear suspension
Strut brace
GTR Front bar/guards
HD clutch
16" stock black gloss rims.
Just bought new tyres as well.
New HC3 globes.
Car has done 130k's.
Neat and tidy inside,out.
Serviced it in November 2006.
Reason for sale is because i'm going overseas soon!
Registration till August 2007.
I'm asking for $11,000 + RWC.
Can personally vouch for this car.
If i had the money on me now i would buy it back... i sold this to Vip over 2 years ago. Dr Drift knows the entire history of it in Aus too pretty much.
This was a limited edition anniversary model... which came with the GTR style interior (ie. the material on all the seats and panels were the same suede etc in the GTR). Seats were added after and not part of the edition.
Good luck with the sale Vip!
  • 1 month later...
If you havent already called, last i heard it was still for sale... so give him a buzz.
Nth - yes this is a genuine Type-M and as stated was a limited edition anniversary model with the nicer updated interior (which is even better now it has the GTR seats).
If i ever get another R32 i will make sure it has the same interior (if i can find another). Its so much better then the std GTST interior.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
