Iv got a custom plenum and i cant find where to put the blowby hose. I got the plenum with the car and im lost where to put the hose as im starting to detail my engine bay and keep on the good side of the cops. any idea where it goes or what to do?
Cheers
Dave
MY ENGINE
https://www.sau.com.au/forums/topic/154299-custom-plenum/
I got the plenum with the car so i have no idea where to get one or how much its worth.I like the catch can idea where could i place it in my bay and is it a defect, If it is i recon welding a nipple on would be the next thing i would do but will this change the engine performance in any way?
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2872095
i bought one of those relocated throttle body plentums and my mechanic refused to put it on unless i had a safc or something,
he grabbed a genuine greddy one and showed me/explained how these stock ones front goes low then high then low presure so you will have different volumes of air in the plentum.. when the greddy ones start high and wide then thin/lower towards the back to keep the presure the same across all cylinders..
he rebuilds engines allday and has every kind of machanical degree so i sold it ahah anything he doesnt like i wont buy but ohwell i respect his knowledge n experiance.. i really liked it though ahaaha
before and after dyno runs would be very interesting
just looked at your photo and you can see how they incorperated what i was talking about into that one, looks rediculously clean and very well made !!!
Edited by 2gceffy
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2882926
So ur mechanic recoommended a Greddy intake over the cut and shut stock item?
I see what he is saying about airflow, makes perfect sence. I think i will take his advice too.
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2884749
For those who want a longer cable for there forward facing plenum. I used a throttle cable from a u12 bluebird with an sr20de in it and it fits perfectly.
just to let u all know not to do the front facing conversion on the factory one
i had one on my car they dont work at all
as the other guy said the air flow goes straight to the back and goes in the back cylinder there for the back cylinder is putting in twice as much fuel and air then the others.
thus in this wears out ur motor and use alot more fuel and gives u lest horspower
https://www.sau.com.au/forums/topic/154299-custom-plenum/#findComment-2884916
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
