Hi all,
Thinking of changing from Shell Helix Ultra to something different and just want to see what oils people are using and how it has worked for them.
Thanks,
BiGMaN
Im using NEO engine oil atm, 10W40 - so far I think its the best ive ever used, I came from using Motul 300V - its damn pricy (1x5L will cost you the same as 2x4L of 300V), but the car is as smooth as a dream and its still honey coloured after 3000ks. Supposedly you don't have to change this stuff until 10,000ks.. not that I'll be taking that chance, though.
https://www.sau.com.au/forums/topic/154314-engine-oil/#findComment-2869794
NEO 10W40 is an excellent oil. I would reccomend it for sure! U pay for what u get...
As for waiting 10,000kms, I'd rather not but like u said it supposedly can.
https://www.sau.com.au/forums/topic/154314-engine-oil/#findComment-2870544
After reading this magazine that put up all the expensive oils and all cheapo oils as in price range from $30 - $120+, the ones that were around $120+ rated the same as the Valvoline DuraBlend for 40 odd bucks... 10W-40 semi synthetic, I think fully synthetic are more for higher performance engines... i'm still a newbie but just going by what i've been told by tuners and people with first hand experience... i'm using it at the moment and its very good for its price but my motor isn't heavily modified everyone will be different i suppose.
https://www.sau.com.au/forums/topic/154314-engine-oil/#findComment-2871162
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
